So, we are 1 year on and I thought I'd update you with what a year with a 530i mSport is REALLY like.
I'll state now that despite all of the below, I'm still loving it. It's now up to 103k, so 10k in a year ain't too bad.
Windback to just before Xmas and the final stage resistor threw a wobbler. Got out the car, locked it. "whats that noise?" Heater fan still running. So had to disconnect the battery overnight and Barry (BSS325i) brought a new genuine one home from work (£67). And the fault promptly rectified itself
Then the PDC started throwing a constant tone as soon as reverse was selected. This was during the snow so I left it as was until I got a chance to look at it. When the snow cleared, it rectified itself
During the deep snow in January, I got lazy one morning and thought" 4 inches of snow? wipers'll clear that". Did they f*ck! they jammed and from then on the wipers just had a mind of their own. Did some research, came up with the brown double relay so replaced it. The same
Lived with it for a while until:
Service time came around. Barry to the rescue again, booked it in on a Saturday for me and completed an Oil service and the all important gearbox filter oil change. These are sealed for life boxes and I have to say, 100k on the same oil just mystifies me. While it was on the ramp, Barry cleared any codes and drilled down on the wiper fault. Came up with the return sensor on the motor. Service was £240 in total and I ordered a new wiper motor @ £220 and once fitted, all was
Then the final stage resistor went completely so the new one was fitted.
Then I smelt a whiff of coolant. Opened the bonnet and the fan had flicked coolant up the air filter and p/s resovoir. Nothing drastic but allegedly, you don't want to cook one of these
. So a pump was ordered along with a new serpentine belt (via Barry again!!!) @ £92 for both and fitted.
A new screen was fitted as it was in a bad state and chipped. Then it cracked in the frost so insuance sorted it. God I love a new screen
Then I smelt coolant!!!
The top hose plastic section was split. I can't tell you if it was that all along but at least it's had a pump now
. £26 for the top hose.
Now due a set of pads which I bought. Full set of Pagids from ECP at just over 70 quid ain't too bad. Just need to fit them.
Plans??? Just bought an HID kit for it. Straight plug and play they say! Yeah right. Spent last night fiddling and farting to get one to fit a spare angel eye headlight. I'll get there in the end.
So there you go. A bit of expense but all in all it could have been worse. Imagine the expense if I'd paid BMW labour rates!!!!!
Big up to the BAZZLAAAA, Barry. Cheers for all the help with the parts and service pal.
