B3 3.2 Touring its suddenly getting old
Post Sun Feb 26, 2012 7:10 pm
In that case rip the coont out, you can leave the auto plugs tied up and shouldnt have any issues with the ECU unplugged. With a 3.15 diff you will want an overdrive 6th for civilised motoring, you dont have to use the M3 fly/clutch, id stick to an M20 jobbie
e301988325i
Post Sun Feb 26, 2012 7:12 pm
Simon13 wrote:well i don't drive it like a gay, but i've not been ragging it as much. The record was 250 miles to a tank and at nearly £80 to fill up i can't cope with that. Thats when the switchtronic action started and now its more like 310 to a tank. I've just done an m-way tank and its done 320 miles with a 1/4 left. I've got to go to gatwick later but i don't think it will do another 90 miles. I might take the jerry can and see!
I'm not against LPG but theres no stations near me. I've looked into it before. Closest ones are 15 odd miles away and in the directions i don't travel to really. I'd have to make a point of going that way everytime i wanted LPG.
Bad luck about the stations that sucks, you'll just have to fit a giant tank!
£80 / 250 is 32p / mile, ours is running 13.7p/m.
I said:
e30topless said:
lock the wife in there
Post Sun Feb 26, 2012 7:13 pm
Luckily the E36 has loads of room under the carpets!
Dan when you had my ecu did you do anything to the copy to make it run on your car ie tell the ecu its now a manual instead?
a 6 speed box is £500 though a 5 speed is £50.
With a 5 speed box and this LSD it would be geared like a 3.0 M3 which can't be all bad. I'm not rushing into it yet.
Post Sun Feb 26, 2012 7:17 pm
The ECU thing didnt work out the box, I only drove the car a few miles and it runs like a bag of shite, no go at all. It might be something simple but ive not been arsed to look into it and have now got my hands on a B3 ECU for keeps
6 speed or keep the auto IMO!
Post Sun Feb 26, 2012 7:21 pm
I've found a online calculator type thing. the 3.0 M3 gearing is nuts, way to revvy it would fly though i expect and still be 22mpg! 70mph in 5th is 2960rpm
If i went 6 speed with a 3.15 diff it would give me nearly identical crusing RPMs as it is now. But with the go of manual in the first 5 gears. So 70mph in 6th would be 2457rpm.
With my car as it is with the 3.46 diff, 70mph in 5th is 2406rpm
The 6 speed box uses nearly identical ratios to the 5 speed but with an overdrive 6th gear on top. This has to be the way then, so M20 flywheel will work with this?! i clutch choice has to be right though
Dezzy
CR24v it's a lifestyle
Post Sun Feb 26, 2012 7:24 pm
My 3.0lt has a 5 speed box, lightened m20 flywheel and 3.15 LSD. IMO the gearing is perfect! 3200 rpm at 80mph and pulls right off the clocks :cool:
Post Sun Feb 26, 2012 7:32 pm
Well with the 6 speed box desmond you can have same that go in 5th also, but with the overdrive 6th for the economy too. Has to be in my mind, i'd keep the 3.15 diff with the 6 speed box.
Check this
328i
4.20
2.49
1.66
1.24
1.00
2.93
M3
4.20
2.49
1.66
1.24
1.00
3.15
M3 Evo
4.23
2.51
1.67
1.23
1.00
0.83
3.23
Ready for a santa pod show down with a have ago hero in an Cr24v e30
Post Sun Feb 26, 2012 7:33 pm
Uprated cover will do it, mine has a standard 228mm dual mass setup
Post Sun Feb 26, 2012 7:44 pm
Leave it alone. Going manual sounds like a lot of aggro for 3 mpg and a bit of c0ck action f :(
Obviously if the box poos itself, then it is another matter.
Dezzy
Post Sun Feb 26, 2012 8:11 pm
I really need a 6 cog box. Not sure weather I can be arsed to risk the Evo box with all it's bad press
Post Sun Feb 26, 2012 9:15 pm
Dezzy wrote:I really need a 6 cog box. Not sure weather I can be arsed to risk the Evo box with all it's bad press
Use an E46 M3 box.
bodger
Post Sun Feb 26, 2012 11:36 pm
why buy a 3.2 auto barge then come on here moaning about your mpg :? , sell it ffs before it blows up and buy a e46 320d
Dezzy
Post Mon Feb 27, 2012 7:30 am
Use an E46 M3 box.
Is that a straight swap using my M20 flywheel set up them?
Post Mon Feb 27, 2012 8:33 am
Nope, you will need a custom clutch
Dezzy
Post Mon Feb 27, 2012 8:51 am
As I thought mate. That's why I dismissed it was an option last time we spoke. Box is fooking massive aswell.
Post Mon Feb 27, 2012 4:46 pm
bodger wrote:why buy a 3.2 auto barge then come on here moaning about your mpg :? , sell it ffs before it blows up and buy a e46 320d
will you f**k off and die your about the thickest, robbing c**t i know. You don't like getting abused so why come back for more all the time
Post Mon Feb 27, 2012 4:52 pm
I was waiting for that one! Seems to love a bait Si.
my pennys worth. Will making it a manual REALLY improve matters? It will change the make up of the car from something you can sit back and relax in (Auto) to a rag worthy tool which is begging for a thrashing???
I'd give it longer legs with a diff and see how it pans out. It's not like it can't handle taller gearing. It must have torque coming out of it's arse.
If it's still an alcoholic, then move to a manual conversion.
Post Mon Feb 27, 2012 5:06 pm
i just think i'd like it even more if it was manual. I loved my 328 slag, and this could be even better! With the LSD too it would be a proper move up from the C2 wagon which as they are is much more of a drivers car.
I'm thinking out loud really.
kitch
Post Mon Feb 27, 2012 7:48 pm
Lmao, pure gold.
I think you should convert it. You obviously want to, and it will save you fuel in theory.
Dezzy
Post Mon Feb 27, 2012 8:57 pm
Lmao, pure gold.
Si just ignore the fool. He look's a t1t everytime he posted. No matter what the beef was 2 years ago, keeping on being a tale on build thread is so gay!
No need to reply. The more he writes the gayer he looks!
bodger
Post Mon Feb 27, 2012 9:05 pm
why do i look a fool?, i gave my opinion on what simon should do with his car, did i mention anything from 2 years ago, no
some people on the zone need to stop brown nosing :bow:
Post Mon Feb 27, 2012 9:12 pm
your opinion isn't welcome, is that easier to understand without me using the retard comments thrown in for good measure.
bodger
Post Mon Feb 27, 2012 9:13 pm
yes thats fine, i wont comment anymore on this
Dezzy
Post Mon Feb 27, 2012 9:21 pm
bodger wrote:why do i look a fool?, i gave my opinion on what simon should do with his car, did i mention anything from 2 years ago, no
I brown nose no man. I say what i think. If I thought Si (or anyone for that matter) was being a massive t1t, I would and do say so.
I think we all know your motive for such gayness. No matter who or what was to blame for all that. You need to move on now. Having all that resentment inside you isn't good for your health.
Belt up!
Post Mon Feb 27, 2012 9:31 pm
But Si is a tit! :wink:
Dezzy
Post Mon Feb 27, 2012 9:39 pm
B7 wrote:But Si is a tit! :wink:
He's not the only one. I'm not bothered either way. My post has nothing to do with who I like or don't. I just hate the pointless bating and b1tching after all this time. It should be dead and buried by now!
That fact that someone can't move on is very gay!
Post Tue Feb 28, 2012 12:02 am
talking of tits i've had no paypal for that tool? i could of sold it 15 times literally by now.
Post Tue Feb 28, 2012 6:32 am
You said or the ace cash? I'll paypal it now.
Post Tue Feb 28, 2012 6:36 am
Done.
tim_s
Post Tue Feb 28, 2012 11:23 am
Si I've had the same thoughts about sticking a manual in mine, would be proper! I've an e46 diesel 6 speed box somewhere (a mate of mine with a 330 5 speed keeps on threatening to stick in that but it'll never happen!)... If I weren't selling, I'd be tempted! Does seem a bit wrong to drop the switchtronic, I must admit that it's grown on me over time.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Post Tue Feb 28, 2012 3:41 pm
No you said paypal and you'll pick it up before ace as you need it. Your going mad!
You've been once to ace in 18 month literally!
Post Tue Feb 28, 2012 7:32 pm
Simon13 wrote:
B7 wrote:
Simon13 wrote: talking of tits i've had no paypal for that tool? i could of sold it 15 times literally by now.
One day we will all be as old as Trevor ! :(
hennared323i
Post Tue Feb 28, 2012 8:47 pm
pacerpete wrote:
Simon13 wrote:
B7 wrote: You said or the ace cash? I'll paypal it now.
Zone clique alert :D popcorn on order
hennared323i
Post Tue Feb 28, 2012 8:48 pm
Simon13 wrote:i just think i'd like it even more if it was manual. I loved my 328 slag, and this could be even better! With the LSD too it would be a proper move up from the C2 wagon which as they are is much more of a drivers car.
JFDI
