Lee Parkes' E30 Alpina B10.
leeparkes
Post Sun Apr 17, 2011 8:08 pm
The plan was to paint the centres Gunmetal the same as my BBS's, still undecided :mad:
Ive got two sets of BBS Mahles, a set on the car and a set up the loft :wink:
Thought about sending a pair of them to these guys to get banded
http://www.rindt-felgen.com/index.html
Post Sun Apr 17, 2011 11:37 pm
Wheels looks good to me Lee, deep dish for better traction winkeye :cool:
Have you got any pics of the E28 radiator connected up, i'm struggling with the bottom hose :-x
leeparkes
Post Sun Apr 17, 2011 11:51 pm
Bottom hoses are a nightmare on the E28 rad, my tip is to soak the end of the hose with boiling water so it becomes more flexible then lube it up 8) im sure i heard waxoil is a good lube to use, think it was yoda who said it.
Rimz are up for sale,
http://www.e30zone.net/modules.php?name ... 94#2142394
I bought them on a whim :) then after having them on the car for the day i decided i prefer the Mahles :mad:
Post Sun Apr 17, 2011 11:57 pm
Mine doesn't fit at all, not long enough. Going to have to get something custom made or get a flexible hose and bend it into shape :?
leeparkes
Post Sun Apr 17, 2011 11:58 pm
Is it aout 4 inch from where it should be, ie needs to stretch 4 inch to fit?
leeparkes
Post Mon Apr 18, 2011 12:04 am
This is what i did (and its still there) piece of M20 exhaust pipe, cut a piece off, file the edges down and clean all the soot out :)
Post Mon Apr 18, 2011 12:13 am
23" long pipe is what's needed IIRC. I've got a metal turbo pipe in the way at the bottom as well so reckon i'll be better off with some flexi pipe, easier to work with :)
leeparkes
Post Mon Apr 18, 2011 12:19 am
Ah, id forgot aout the turbs in there :)
leeparkes
Post Sun Apr 24, 2011 9:23 pm
Zaust is on....
Pics of the modded manifold fitted to the old engine.
Bolted up in situe, there's loads of clearance now 8) well about 20mm anyway :)
After this i let rip and got the whole system fitted, pics of the back box straps fitted up.
^^^Ignore the brake discs 8O i have a fresh set ready to go on.
Final shot 8)
Well the conversion is now done but i havent drove it yet as i have other issues to sort out :( but the engine sounds fantastic and spins up very quick, it isnt as smooth at idle but im guessing thats down to a feather weight flywheel and lumpy cam or even the fact the engine has sat a while and needs a good Italion tune :D
Post Sun Apr 24, 2011 9:26 pm
Where's the Rimzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz???????????????????????????????? :?
leeparkes
Post Sun Apr 24, 2011 9:34 pm
Bottom of page 21 Ravster :)
Post Sun Apr 24, 2011 9:38 pm
I take it your keeping them then??
leeparkes
Post Sun Apr 24, 2011 9:47 pm
For now, yes. Ive already started refurbing them :)
Post Sun Apr 24, 2011 9:50 pm
Post Sun Apr 24, 2011 9:51 pm
Exhaust looks spot on :cool:
Thought you might be keeping the rimz, all about the dish :D
leeparkes
Post Sun Apr 24, 2011 10:44 pm
ImysE30 wrote:Thought you might be keeping the rimz, all about the dish :D
Cant beat a bit of dish 8)
Bristol_Jer
Post Mon Apr 25, 2011 11:42 am
Nice work Lee 8) I'm going sort the exhaust on mine this week, just need to get some more studs, nuts and springs for the downpipes.
With regards to the bottom hose, I've got an e28 m535 rad and bottom hose, and it all fits together perfectly
gareth
Post Wed Apr 27, 2011 8:24 pm
That's an unreasonable amount of manifold clearance! :)
Do you have a E30 rack still or is that a E36 or Z3 one?
leeparkes
Post Wed Apr 27, 2011 8:55 pm
Thats an E36 rack Gareth :)
gareth
Post Wed Apr 27, 2011 9:22 pm
Sweeeeet! :D
I really must stop faffing about and get my E36 rack fitted then!
Top work as usual though, keep it up :thumb:
Post Wed Apr 27, 2011 10:04 pm
"Nearly" as much as my RS's :mad:
leeparkes
Post Wed Apr 27, 2011 10:50 pm
Show off :D
Bout time you got them on the car though moosh...
Post Wed Apr 27, 2011 10:54 pm
Haha, you can only 'nearly' be as good as rav innit :D
So is this going to be at pod on the right day this year? Show us what a proper M30 can do :D
Post Wed Apr 27, 2011 10:58 pm
They're under my bed atm, :mad:
leeparkes
Post Thu Apr 28, 2011 12:09 am
I showed you what a proper M30 could do last year, albeit the wrong day :) id double booked :o:
Ill be there this year.
Rav, Id be frightened to put them on my car, how much are they worth? 2k?
Post Thu Apr 28, 2011 8:24 am
And a bit more :?
leeparkes
Post Thu Apr 28, 2011 7:28 pm
Rav335uk wrote:And a bit more :?
8O
Have you test fitted them to the car yet, what are the specs of them,9j 10j??
Post Thu Apr 28, 2011 8:06 pm
8.5j fronts and 9.5j rears
leeparkes
Post Fri May 06, 2011 9:45 pm
Well ive finally got to the bottom of my dodgy idle problem :D
After testing everything possible the last thing to do was a compression test, started pulling all the plug leads off then noticed number 6 plug lead had a hefty split in it.
Ignore the gimp gloves :D im sick of my hands looking like a miners..
Well number 6 lead is the one with the pulse wire on it :banghead: what a pita that is trying to feed the wire round the front of the engine. All the leads were fine before the engine went in as i checked them, im guessing the lead got caught on something as it was going in as that area is very close to the battery tray, i dont know?
Anyway, put it all back together and hey presto silky (ish) smooth idle
8)
MOT next week :roll:
charlE30
Post Sat May 07, 2011 9:26 am
Nice one Lee, it's nice when you find an obvious defect causing a running issue like that.
Why the :roll: about the MOT, surely it'll fly through it?
BMW F31 335d xdrive
leeparkes
Post Sat May 07, 2011 3:49 pm
It should fly through but i never count my chickens till there hatched :D
leeparkes
Post Tue May 24, 2011 8:54 pm
My plans went out the window a couple of weeks ago regarding the MOT but it went today and...
Passed :banana:
The car went to the MOT station on a trailer but with a clean bill of health i drove it home :twisted:
Well first of all compared to the compact the E30 feels very old and noisy and i wasnt keen for the first mile or so until i floored it on the dual carriageway and then the fun began :D
This new donk feels just like a normal M30 below 3k but after that it just loves to be revved and pulls hard all the way to the limiter, normal M30's run out of breath at around 5k, this thing doesnt 8)
Problem is this though it doesnt feel like a 260hp lump, if i had to guess using my arse dyno id say its around 240hp. Its quicker than when it was normal M30 and its quicker than the compact but i was expecting a bit more :? mind you ive only drove it about 5 miles so not realy got the feel for it yet plus i couldnt really go beserk as there's no tax on it :D
Also when i got home the brakes felt like they were seized on a bit, they were fine when tested on the MOT rollers. :mad: so thats something else ive got to sort out, and maybe haltering performance a tad :)
Anyway, im well pleased and all i can say is....
Bristol_Jer
Post Tue May 24, 2011 9:00 pm
:drive:
Pleased for you mate!
Post Tue May 24, 2011 9:02 pm
Nice one mate 8)
Kedge
Post Tue May 24, 2011 9:16 pm
Nice one fella, do like this car :cool:
Instagram - Kedge85
