tim_s wrote:
Tim,
Top pic is the idle speed increase signal to the ECU (should be black/white). It goes to 12v when you switch the A/C on. Hopefully you can get MS to perform this function.
Bottom pic shows that you have an A/C heater box from an earlier car. The white connector plugs into the back of the heater control knob, and controls the heater solenoid valve. The black plug should plug into the rear of the heater sliders. On earlier cars, you could only engage the A/C when the middle and bottom sliders were in a particular position. It was designed to stop the evaporator from freezing up. Later cars don't have this connection, but may have a different evaporator temperature regulator (the large relay looking thing on the side of the heater box) that stops the evap from freezing up.
Regarding dryers. You should be able to use anything that physically fits. If it's r134a compatible, then it should also be okay with r12. You can't however use an r12 dryer with r134a.
No probs running an E36 compressor from E30 electrics. Both are only expecting a 12v feed to engage the compressor clutch. You may have to get funky with the pipework though. The E30 system uses regular threaded connections, but the E36 generally uses a totally different style of fitting. It's a sort of metal block that secures with a single screw.
Cheers,
Ian.
