E30 S50B30
drifty325i
Post Thu Feb 21, 2008 9:28 am
tubby17s wrote:drifty have you done a full write up on your car yet? some guy on eurocca treid pointing people in this direction but i coulndt find your write up only your exhaust one.
Na i havint really mate, ive almost forgot alot of it lol. Ill do a decent full post when ive fianally got it to were i want it
tg318is
Post Thu Feb 21, 2008 10:47 am
Nice car man! where bouts in sydney you live?
tubby17s
Post Thu Feb 21, 2008 11:26 am
St Ives
tg318is
Post Sat Feb 23, 2008 1:31 am
nice.. I'm in Glenhaven
tubby17s
Post Sun Aug 31, 2008 9:30 am
Well the engine hasn't lasted too long and the result is this..
July 28th the engine died.
Back onto jack stands...
once the head was lifted off this was the poor sight that was to be seen.
The block... the sleeve has been pulled down (through the seat and oil squirters and onto the crank
And the piston.....
so a new engine was purchased..
This time a M52b28
August 18th
A customer of the place im doing the work at was having a S50B30 conversion done and had not received a lot of the crucial parts one being the entire EWS set up.
His engine was also down on compression on cylinders 3 and 6. So after a couple of beers the decision was made to swap engines.
So on the 21st i removed the S50 out of the customers E30 and put it on a engine stand and bolted the supercharger up to it..
I then started pulling the S50 down and installed the M52b28 into the customers car
S50 pulled down
Found this damage to the bore on cylinder 3
the spacers that go in between the throttle bodies and the head
And now i also have the headers that Matt at the workshop modified for the customer. Im not 100% sure what i going to do with these yet.
Yesterday i took the block up to the machinist to check what size pistons to order. He will be bore the block, be checking the eccentricity of the crank mounting, shave the block mounting surface, finish the cranks conrod mounting surface's and the cranks mounting surfaces. The head is also going to be reconditioned.
I will be ordering the internal parts as soon as he lets me know what size pistons to order.
Post Sun Aug 31, 2008 9:53 am
Nice swap! :D
Damn those alloy blocks though :) Did you get any dyno charts of your 2.5?
tubby17s
Post Fri Sep 19, 2008 6:20 am
nope no dyno charts
tubby17s
Post Fri Sep 19, 2008 6:44 am
well recieved my parts yesterday, so will hopefully start building it next week when i get my stuff back from the machinest
NatDJ
Dyson deviant
Dyson deviant
Post Fri Sep 19, 2008 7:29 am
This thread never ceases to amaze me. What an amazing build! Make sure you keep a diary this time with the new lump going in. This'll be the danglies when finished (again).
AUS325IS
Post Fri Sep 19, 2008 7:53 am
Hey mate i'm in australia just wondreing where did you get your kopi wheels from i'll be after a set of 17's soon
FormerMember
Post Fri Sep 19, 2008 9:59 am
Really clean and properly built! Great motor! :)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
tubby17s
Post Fri Sep 19, 2008 1:49 pm
Yeah this one will be documented.
I have had the copy "RG" wheels for 4-5 years (just sold my genuine set last week)... best bet would be to buy a set of genuine alpinas from either Germany or the UK. A nice set of 16X7 and 16X8 make the car handle really well
tubby17s
Post Sat Sep 20, 2008 11:02 am
Got my M5 flywheel, clutch plate and pressure plate today.
Will possibly need to change the ring gear over or change the cog in the starter motor.
tubby17s
Post Tue Dec 16, 2008 12:26 pm
Just a small update. been busy with work
got my engine back a fair while ago. cleaned it all up, sanded the outside and painted it.
installed the crank, pistons and rods..
mmmmm coated bearings for the rods and mains
block finished
Just waiting on 3 boxs with all brand new genuine parts to complete the base build of the engine. then i can assemble the rest of the engine over Christmas
savvi
Post Sat Dec 20, 2008 11:41 am
thats my sort of xmas putting a m3 motor together for an e30 , im jelous, good work
tubby17s
Post Fri Jan 02, 2009 5:38 am
So with all my boxs of parts it all down to building the rest of the damn thing.
Here is the new oil pump that has to be converted to 5 series pick up. (s50 is the longer arm)
new crank nose swapped over and all new timing chain and oil pump chain guides and the oil pump installed
Found out the old oil pressure relief valve was full of silicon so would have not worked.. so installed the new one
timing case goes on
pistons 1 & 6 are moved to top dead center ready for head install. I am using a VAC motorsport multi layered steel gasket
tubby17s
Post Sat Jan 10, 2009 6:04 am
bit of a picture update
this is the o-ring kit you get... a pain to find the right o-ring as they all seem almost the same size..
putting the water pipes together
Picked up another exhaust cam sprocket from parramata prestige
got them machined with the hardening taken off and slotted holes put in.
trial install
exhaust cam put in so that the valve clearances can be checked which seem to be a fair way out. Then shims will need to be swapped or new ones bought
Does anyone know the specs for a S50B30 valve clearance?
boybimmerm3
Post Sat Jan 10, 2009 9:11 pm
Inlet and exhaust clearances are the same for the s50 b30 which are 0.28-0.33mm. ( cold ).
tubby17s
Post Sun Jan 11, 2009 2:11 am
thanks mate.
tubby17s
Post Wed Feb 11, 2009 5:16 am
sooo ive started heading in a different direction again as the supercharger is going to be dificult to fit where i would like it to go. so i have choosen to go turbo. Meaning my supercharger will be up for sale.
i have orded my shims finally as this has been a great pain the the backside but i am still waiting for them to arrive. so in the meantime i have thrown the engine in to test fit it.
turbo purchased
I decided to mount it low as there seems to be more advantages than disadvantages for me.
going to have to make a new engine arm so the dump pipe can fit.
a picture of what it would look up top.
JungleGus
Post Wed Feb 11, 2009 9:23 am
what the hell happened to the M50 to have that happen?!?!
love s50's, awesome project!
why not just stay N/A? the stock s50 isn't exactly slow
tubby17s
Post Wed Feb 11, 2009 11:06 am
Bad tune by the person that tuned it.....
Because i bought a new m52 to bolt everything back up to but a customers car was missing all the ews for the S50 so he asked if i wanted to swap engines. I said yes and became the new owner of the S50. Then i was going to rebuild it and use the supercharger because i all ready had it and i was going to replicate what was used on the tauber built car but with twice the amount of boost.
Now i have decided that instead of running the supercharger down the bottom on the exhaust side i may as well just run a turbo.
ricey46
Post Wed Feb 11, 2009 4:33 pm
Nice project mate, I remember reading it a while back but it's fair moving on now, good luck with the S50 turbo build, I hope you get this one tuned right so you don't have to do this all over again :cool:
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
BigBavarian
Post Wed Feb 11, 2009 6:19 pm
That will be a truely awesome machine when its done> what sort of power you going to be running?
Richard
tubby17s
Post Fri Feb 20, 2009 1:14 am
Soo took the engine out to make the manifold.
another parcel arrived today.... Thanks to David (DJS...)
BigBavarian i am looking to run abotu 400bhp at the wheels but will be able to wind it up if need be.
tubby17s
Post Wed Mar 04, 2009 12:21 am
another parcel arrived today the SP2000 is for the E30
waiting on a wide band kit as well to come in a week or so when they have them in stock.
SUMPCRACKER
Post Wed Mar 04, 2009 7:50 am
:eek:
tubby17s
Post Sun Mar 08, 2009 11:41 am
Small update. Mounted the intercooler yesterday. had to make a little room for it as its 130mm thick.
punk_sy
Post Sun Mar 08, 2009 12:26 pm
very nice mate love the intercooler :)
tubby17s
Post Fri Mar 20, 2009 7:20 am
Recieved another 2 parcels today.
Wideband kits
Collector
Post Fri Mar 20, 2009 9:20 am
Tubular manifold? Where will that go! :eek:
tubby17s
Post Sat Mar 21, 2009 1:50 am
i am hoping that it will all fit. front/low mount turbo.
Just need to find a place to buy the manifold pipes.
tubby17s
Post Fri Feb 12, 2010 5:53 am
So after spending some time away from the project i decided to go back to NA and had to rebuild the engine again with forged CP stock compression pistons. I have run out of time and motivation to turbo or supercharge this car. Plus we are running out of tracks to go on in this part of australia and the prices are only going up.
had to put in a locating dowel for the magnet to pick up the cam angle
underside of the plugs
there are also plugs for the rear cam sensor pick up holes
reinforcement bar for the front
ready to leave to go to the exhaust shop. first time its hit the ground in 2 years...
exhaust work
now back at home to finish off
kristov
Post Tue Feb 16, 2010 6:04 pm
Do you still want to sell the supercharger?
Post Tue Feb 16, 2010 6:30 pm
Hurrah for getting it back on the ground! :D
I dont blame you for leaving it NA, much better to have a working car than a long term project 8)
Why are you running out of tracks?
