Toyo R888 tyre wear problem - advice needed
Francisco
Thu Jan 31, 2008 4:35 pm
38psi, 30-32psi hot is OK for a slick tyre but on R888's (at least if you're pushing REAL hard) will make them overheat and flex. Don't take my word for just browse the internet for Toyo's recomendations.
The rule of thumb is inner edge and center at Xºc and outer edge X+10ºc.
UweM3
Fri Feb 01, 2008 10:13 am
Francisco wrote:I'm running Uwe's camber plates and I definately recommend them. Easily reversible, the rubber keeps the car civilized when running over potholes and VERY reasonbly priced.
P.S. I run 888's at an optimum 38 psi. BTW, tyre temperature should NOT be the same across the tyre there should be a 10º diference on the outer edge.
thanks for the free advert :D
I will have more mounts soon. Parts are with the machine shop and I hope they don't let me down with the deadline given.
JimmyC
Wed Feb 06, 2008 2:22 pm
How muh you after for a pair??
Jimmy
UweM3
Wed Feb 06, 2008 2:34 pm
was asking for £69 plus P&P last time and I hope the zinc plater doesn't rip me off again. Otherwise it may go up a squid or two. But this DOESN'T inlcude the rubber mounts.
JimmyC
Wed Feb 06, 2008 2:44 pm
Just boggo top mounts with them? ie the £16 ones from euros??
Are you at Bedford with Gary at the end of the month, would like a looksie on yours if poss, if not where you based
May be able to shift some on the race guys for you too
UweM3
Wed Feb 06, 2008 3:52 pm
Will be in Bedford and have some fitted to my car. I am also working on a solid (simple) mount.
Would that no be better for race application? Will also lower the fron a little with the solid mount.
Looking forward speaking to you, have some other parts in the draw as well.
JimmyC
Wed Feb 06, 2008 3:59 pm
Cool, will have a chat at Bedford then
northloop
Wed Feb 06, 2008 8:23 pm
I look forward to having a look at these at Bedford too
iguana
Wed Feb 06, 2008 9:45 pm
38psi on the 888s? felt like crap when i ran em that high, I payed about a bit & 34 hot was my fave, so circa mid to high 20s cold & bleed down to 30 or so after 1st session & they get to temp jubbly
www.lizardlogistics.com
Vehicle Transportation Specialists
Francisco
Wed Feb 06, 2008 10:18 pm
What was the ambient temperature? The issue with 888's is that (unlilke the Sport Cups for isntance) they tend to go off after a few laps in hot weather (which is the case here in Portugal) so increasing the cold pressure base line and leaving it on the high 30's sorts this by reducing the flex and contact patch (i,e friction). In cold weather the tyres can evacuate the heat better and cope with lower hot pressures therefore increasing contact patch and putting them up there on their working temperature range.
This is one of the set back of the high silica contents which makes them so good at slight wet/damp conditions (actually better than sport cups that useless on the wet.
