donuts
maxfield
Mon Sep 10, 2007 11:01 am
Saturday... Haven't seen it yet mind :)
1an
Mon Sep 10, 2007 11:14 am
what happened to the iS then?
maxfield
Mon Sep 10, 2007 11:17 am
My dad bought a car as it was cheap and had a good shell. It won't be far off iS spec once I've fiddled with it.
1an
Mon Sep 10, 2007 11:20 am
sounds a bit like mine then, mine is full iS spec now bar the engine.
good to see you got an e30 though,
Ajay325
Mon Sep 10, 2007 11:33 am
any e30 will go sideways in the wet, not a wise thing to do on UK roads though.
Rik178m
Mon Sep 10, 2007 11:50 am
Is there more difference between a standard e30 and an IS then just the mtech suspension and ARB's?
Obviously a different engine I know
maxfield
Mon Sep 10, 2007 11:52 am
16v engine.
Different suspension as you mentioned.
Rear disks.
Recaro interior.
Black headlining.
iS front lip and rear lip.
Rik178m
Mon Sep 10, 2007 11:55 am
Gotcha. when you say different suspension are the shocks stiffer? Got mine lowered 60mm and over some bumps they rub! Need to sort it pronto
maxfield
Mon Sep 10, 2007 11:57 am
Not sure about shocks they're bilstein though. An iS is also dropped 15mm from a standard E30.
Rik178m
Mon Sep 10, 2007 11:59 am
Would bilstein be stamped on them anywhere? not just a sticker as it'd be long gone by now!
maxfield
Mon Sep 10, 2007 12:00 pm
Not too sure never looked at a set...
Would guess you can get them from part number...
And they're usually yellow shocks...
Rik178m
Mon Sep 10, 2007 12:03 pm
Guessing mine arent bilstein then cos they aren't yellow. Cheers mate
1an
Mon Sep 10, 2007 12:14 pm
i have bilstein shocks in my car and they are black.
