Big power,HOW?
Turbo-Brown
Boost Junkie
Thu Apr 28, 2005 1:43 pm
Karan wrote:turboing is cool....
but ure never gonna have response of a tuned NA engine.... but u also cant beat the turbo shove
Not sure that's absolutely true, although it depends how you go about it.
N/A tuning tends to move power up the rev range which means you have to wait for longer untill you get the full hit.
Contrast that with a lowish boost F/I system where off boost response is pretty much the same as a N/A engine, but then you've got the turbo whack to look forward to :)
True though that bigger boost systems with lower CRs will reduce throttle response :(
Jos
Thu Apr 28, 2005 1:52 pm
I think if I was going down this route, I would fit a turbo to a standard block, run it at 6-7psi to make sure the engine didn't blow, make sure I got a nice gearbox, not 100% sure on which gearboxes fit the m20 but I think the Getrag 265 was the strongest box fitted to BMWs, but it's for the M30(also the e30 M3 used it). Hard to get the 265 now though I think.
http://www.mye30.com/dogleg.php - ok it does fit.
Diffs are not really and issue as they will take it, get a finned diff housing, or one with an oilcooler on it.
Run with that in the meantime then buy another 325 engine and start uprating bits at your lesiure, then when its done, swap it in and start uprating the old engine. That way you have the car fairly quickly and cheaply and you are halfway to rediculous power. Then swap in the uprated engine and you are there, and with a spare engine :)
'94 e36 tree climber
ravenhill
Thu Apr 28, 2005 6:06 pm
Ive`read all your comments, i now need to start looking for a cheap runround as my e30 is my everyday transport! I think this conversion is gona have to wait until the winter as i dont want the car off the road in the summer.
Especially as the show season is upon us, not unless you guys think it can be turbod in a couple of months?
Thanx again guys, your always so helpfull :wink:
Simon
Lowm3
Thu Apr 28, 2005 6:22 pm
i think the main appeal of the beemas is that engine noise, it sounds great!!
If you want power how about an audi TT 225 lump, thats 225 out the box, revo'd to 270 brake, revo remap cost about 500 quid. Lots of these engines and parts available, mounting might be a problem though.. i can see a lot of custom made bits and bobs coming into play.
I have been on the vw scene for a bit because of my brother, and a friend working for stealth racing has a corrado with a TT lump, chipped, and he ate an e36 m3.
Worth a look if you want power, all the golfs are doing it now too, just dont expect too many mpg. 8O
ravenhill
Thu Apr 28, 2005 6:32 pm
I was in to the golf scene in a big way a few years ago, hence my car sits on bbs rs001 split rims! I just couldnt put a veedub motor in there it would be like down grading the car! sorry!!!!!!!! Plus a four pot is never gona sound as good as a 6!
Lowm3
Thu Apr 28, 2005 6:35 pm
yeh you cant beat that sound from the beemas, even the 2 litre engine sounds beefy!!
Don't you find the genuine beema scene is better than the dub scene? It gets very clicky over there.
