Recomend a wideband
e30_Turbo
Boost Junkie
Post Mon May 12, 2008 9:36 am
I've had a few of these now and use mine everyday.
It's basic thinking to calibrate it regular, mine gets done every week, removed, checked and cleaned.
My first went mad and read like a NB, think the water/oil/exhaust mix it got one day was the end of that one, the current has been fault free so far.
I've set my crossover point to slightly less than 14.7 so even and stoich I'm a little richer, if they read under anyway I'm well safe.
@ Paul, I have set a AFR map for my engine and it seems to work fine, now off the EGO and running live on the map, still a few areas need a tweak but the main driving is fine, could you help me set up a AFR map?
Or maybe you could have a look at mine? I just based it on what I have seen, heard or found out myself.
Thanks, Mark.
ShepsEvo3
Master of go faster
Post Mon May 12, 2008 9:47 am
Mark, you have pm mate :wink:
www.sabre-tuning.co.uk
e30_Turbo
Boost Junkie
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon May 12, 2008 2:19 pm
Learn anything interesting mark - I'm in the same boat as you atm wrt wb and ms :)
lol - so many acronyms :)
FlappySocks
Post Wed May 14, 2008 2:13 am
ShepsEvo3
Master of go faster
Post Thu May 15, 2008 6:11 pm
Thats a JAW dropping price :D :lol: and a nice install into the E36 rev counter, although at night I would think it would be a bit annoyingly bright?
oldroydsr4
Post Thu May 15, 2008 6:18 pm
its looks good but wheres the flux capacitor?
FlappySocks
Post Thu May 15, 2008 6:46 pm
oldroydsr4 wrote:its looks good but wheres the flux capacitor?
Lol, it does look at bit like that. One might confuse the AFR reading with the year.
chu346
Post Thu May 15, 2008 8:01 pm
I don't think this would work with MS, would it?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Thu May 15, 2008 9:58 pm
MS can work with any O2 system but some may be harder than others to configure. Not sure on details of this particular one.
FlappySocks
Post Fri May 16, 2008 1:11 am
Yeah should work fine. I'm launching my new MS/Motronic kit next week, and fitting one to my cab project. I have a new LC-1 ready, but I'm tempted to try one of these instead.
