Questionaire/Survey E30 M20 Head Problems/Performance
WillG
Post Fri Dec 08, 2006 12:04 am
this one 8)
reggid
Post Fri Dec 08, 2006 12:09 am
Andyboy wrote: That's why the header tank is above the cylinder head.
If proper maintenance is carried out i.e. there is enough coolant.
How much does the coolant level need to drop for the head to become the highest point?
mwarrior
Post Fri Dec 08, 2006 12:19 am
you cant get rid of airlocks by bleedding unless the airlock just happenst to be in the place where the bleed screw is, the pressure of the water should push all the air to the highest point after its been running for a while. i squeeze the pipes starting from the bottom to get anything thats left. its just like getting air out of centeral heating systems and i should know because i do it every day. by the way this is my first reply to this wonderfull site as i bought my first e30 two weeks ago. its been a great help so far reading the forums to iron out the small problems that came with the car. havent driven it yet as its booked in the garage for monday to have the bushes in the back axle done. cant wait to drive it properly, winkeye
tim-ix
Post Fri Dec 08, 2006 10:29 am
The header tank is the highest point in the cooling system, but there is a dip between the head and the header tank, so you can get an airlock in the head if you're filling the coolant system from a very low level. You've got the bleed screw/valve on top of the water pump to bleed the air out when you're refilling the system.
If you are regularly filling the system and needing to use the bleed screw then your engine's knacked, like mine.
Hopefully it won't cost you a fortune though (fingers crossed).
Done 203,000km or 120,000 miles by the way, and the coolant isn't making it onto the oil.
Post Fri Dec 08, 2006 8:28 pm
the manifold theory makes some sense, have u ever put a straight edge on a cast iron manifold? most are like a protractor they are that pissed. A 6 branch at least is on 2 pieces.
i've had 4 2.5/2.7 engined E30's and all have been ok. one was on 66k the lastest is on 220k and is the original head. I think the head issue is a bit over hyped on these engines tbh
Griffen motorsport had a go on this, if u bought a stage 3 head or higher off them they welded the head up on the waterways. Karan's old 2.7 sport led the most horrendous life and was fine, so maybe it was doing something.
Simon
Post Fri Dec 08, 2006 9:08 pm
My old sport (now billgates) cracked a cylinder head at just over 100k, was a FSH car too, cracked in the usual place under the cam.
Got a green 325i in my garage which I've had about 2 years, also with a cracked head, not removed it yet to find out where...
Had a 325i engine dropped into my touring recently, and I think I've got a head problem developed in the last couple of days, high temp readings, and coolant system under a lot of pressure... :cry:
Post Fri Dec 08, 2006 9:23 pm
under alot of pressure when u take the cap off and the engine is cold?!
Simon
Post Fri Dec 08, 2006 9:30 pm
Simon13 wrote:under alot of pressure when u take the cap off and the engine is cold?!
Hot or cold, lots of froth!!
