Instrument Cluster disassembly - SI board & odometer gea
Morat
Post Tue Nov 07, 2006 5:08 pm
ooh calibrated fuel gauge? Were they available in the UK?
Chris
Post Tue Nov 07, 2006 6:15 pm
Piper, u'll have to get the coding plug then.
I believe with the older L-Jet. The ECU governed the difference between 6 and 4 cylinder engines and then feed the info to the rev counter, or they use the same number of pulses per rev on the 4 pot and the 6 pot.
So yes go and nab a coding plug from the front of a scrapyard cluster and you should be okay.
PiperZero
Post Thu Nov 09, 2006 10:10 am
Timmyboy - don't ya just hate it when you discover what the previous owner messed up? :mad:
Dingbat - I saw an example of the coding plug on ebay (plugged in, it looked like a white piece of plastic from the front), so I'll scrounge around the scrappies this Saturday :D
timmyboy
Post Thu Nov 09, 2006 4:53 pm
sure do. hope u find what u need mate good luck
(00=[ll]=00)
Image<embed></embed>
95-540iLE
Zone Newbie
Post Fri Nov 10, 2006 5:47 am
Have you plugged it all in and had it working in the car? I am always concerned when changing the cluster out of a newer car into an older car that there will be compatability issues. And like you, my E30 has had battery leak issues with some intermitent faults as a result.
I will shortly be looking for a new cluster and want to make sure the one I buy will work.
PiperZero
Post Fri Nov 10, 2006 6:32 am
540i (is your the one with the V8? Absolutely droolicious... :P ) - I haven't found the coding plug as described by dingbat, so at the moment, the tacho's dead.
I'd love to find a scrappie that has 1983-84 E30 parts, but most of the ones I go to have the later versions :?
Good luck in finding your cluster and if you find any spare coding plugs, I'm more than willing to engage in international trade... :D
95-540iLE
Zone Newbie
Post Fri Nov 10, 2006 7:06 am
Yes - 4.0L V8 with 6 speed manual and 1995 M5 running gear (from the factory).
I will keep in touch re the coding plug/instrument cluster issue.
