Idle control - HELP!!!!! - NOW IT WONT F'ING START!!!
GDBN
Mon Aug 14, 2006 8:17 pm
Best way to find an air leak is to spray with wd40 .. do a bit at a time.
If it settles down then you've found it.
G
Mon Aug 14, 2006 8:27 pm
is there any difference between the ecu for a facelift car with the lower compression lump than what you have in there (earlier higher compression engine)
has the car misbehaved since the transplant of engine? What's the score with the timing sensor which is on the front of the later engine and on the flywheel on the earlier version isn't it?
massive
Mon Aug 14, 2006 8:35 pm
E30BeemerLad wrote:is there any difference between the ecu for a facelift car with the lower compression lump than what you have in there (earlier higher compression engine)
Yes, I followed Ant's instruction on how to do it properly keeping the original 173 ecu incl swapping the CAS.
Its never idled properly since the transplant, which did question whether my mechanic hasnt done something he should have :squint:
Mon Aug 14, 2006 8:39 pm
you questioned TPS earlier - throttle position sensor.
on the bottom of the throttle body. As soon as the throttle is opened ever so slightly you should hear a click from this. Worth taking tps off and giving a clean with ignition cleaner or something similar
apologies if this has been answered already
massive
Mon Aug 14, 2006 8:46 pm
E30BeemerLad wrote:you questioned TPS earlier - throttle position sensor.
Yes it clicks. Ive had all the t/b off and its sparkly clean. Problem was after cleaning the icv, t/b and afm it made it even worse.
Fcuk knows whats going on. A trip upto Ant is in order i thinks winkeye
Mon Aug 14, 2006 8:51 pm
indeed, good plan, getting it to someone who knows what he's doing :wink:
massive
Tue Aug 15, 2006 6:25 pm
SOMETHING IS SERIOUSLY FCUKED NOW!
I had a spare hour to take off all the hoses around the t/b and icv. Found that a hose from the icv to the t/b wasnt 100% on properly. So sorted that out in a hope it might sort the idle problem out.
Yes its sorted the idle but now it MISSING like fcuk....sounds like a lawnmower chugging (like the timing is out)......What possible could cause that. It was fine before!!!!
Cant drive the f**ker now :x
massive
Tue Aug 15, 2006 8:42 pm
anyone? :(
deian
Wed Aug 16, 2006 3:42 pm
i think you need to get another e30 side by side with yours and play spot the difference, maybe a pipe is routed the wrong way, or missing, or wrong place.
good luck
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Aug 16, 2006 3:57 pm
U aint knocked a spark plug cap or coil lid off liek i've done before :cry:
massive
Wed Aug 16, 2006 3:58 pm
cliffybabe wrote:U aint knocked a spark plug cap or coil lid off liek i've done before :cry:
Na mate, didn't touch or go near any of the spark plugs or anything else which could cause a miss....thats what i cant get my head around.
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Aug 16, 2006 4:00 pm
Have u unplugged any of the engine control wire's??? liekt he bottom of the throtle body, Did u but it home all the way reconnecting???
massive
Wed Aug 16, 2006 4:03 pm
they are all plugged in mate, where they should be. Ive checked, double checked and checked again.
The wire at the bottom of the t/b is for the cat, so thats never been plugged into anything
Didnt understand this
thanks
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Aug 16, 2006 4:06 pm
Sory mate i type submit then read and relize im a tit, I didnt know that connection was just for a CAT my car i s a post face lift yet ti still has that plug
Basicly i meant did u ut the connections all the way home (in)
stuartgallafant
Wed Aug 16, 2006 5:04 pm
you should type, read, then type again, and then submit, TIT!!!
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Aug 16, 2006 5:13 pm
stuartgallafant wrote:you should type, read, then type again, and then submit, TIT!!!
:gives: :flipbird:
massive
Wed Aug 16, 2006 5:53 pm
Sorry CLiff, still not getting it?
jonbuoy
Wed Aug 16, 2006 7:07 pm
Nothing more to say on this then Stu???......seeing as you work for BMW :? :roll:
This symptom sound's like the plug is'nt on the TPS properly!
And remember......the throttle stop screw need's re-adjusting as the position it's at, it will be idling too low.
HTH
samy_tee
Wed Aug 16, 2006 7:27 pm
had similar idling problems with my 316i...also got worse when it was warm
i used advice off my mech to clean icv but with no luck
i took it to his garage and he put it on the computer
the computer said no problems
the next mornin i went to start my car and it wouldnt fire up.
tryed everything... i mean everything
towed it to the garage and the computer said the crank sensor had fucked.
put a new one on
car fired up but ran like a bag off shite. was missing and sounded like it was flooded all the time. undrivable
computer said it was fine when it blatantly wasnt.
garage had my car for 2weeks untill mech got adviced by someone to change the ecu
and guess what
it runs as sweet as a nut now
massive
Wed Aug 16, 2006 8:26 pm
Thanks,
Even when the screw thing is completely undone it idles at 1700rpm, obviously some sort of problem there. Once its fixed I can adjust the screw accordingly
massive
Wed Aug 16, 2006 8:27 pm
samy_tee wrote:had similar idling problems with my 316i...also got worse when it was warm
put a new one on
and guess what
Intersting I'll bear that in mind, thanks
and WELCOME! :D
jonbuoy
Wed Aug 16, 2006 10:16 pm
Thanks,
You said that the idle had dropped and now it's missing????
Ant
Retired Team Member
Retired Team Member
Wed Aug 16, 2006 10:30 pm
Dude, where is this car ??
its annoying me now :lol:
massive
Wed Aug 16, 2006 10:44 pm
Thanks,
Idle has dropped to 1000rpm but now its not running right (will only drive at 30mph....missing like fcuk) , so not 100% satisfied the idle is sorted until ive got the misfire done.
massive
Wed Aug 16, 2006 10:48 pm
Ant wrote:Dude, where is this car ??
Unfortunately too far from you, its W-mids near the welsh border. I've got a mate at the stealers so if off there tomorrow.
Will reveal all once i know. Drove it there 2 hours ago and it wouldn't do over 30mph and was chugging along holding up all the traffic :D
d6dph
Wed Aug 16, 2006 10:54 pm
massive wrote:
jonbuoy wrote:
massive wrote: Thanks,
That sounds like when i forgot to plug my afm back in (yes yes yes, im a plank - Made Ant laugh tho!)
Anymore than 1500-1700 rpm and it tried to stall. can you not borrow an afm off of some one to test with? i have a spare one but i think its fooked.
jonbuoy
Wed Aug 16, 2006 11:18 pm
I wondered when you'd perk up! :lol:
massive
Thu Aug 17, 2006 4:34 pm
Had a phone call off the Stealers earlier about the car.....
"We're are not sure exactly whats wrong with it, we have found that the engine terminals are corroded so would like to change this first, however it might be that this is not the fault. 2 hours labour plus £15 parts.....approx £200 - would you like me to authorise the work"
I said "Na its ok, I'll pick it up later if thats ok"
Went to pick it up and got a bill of £46.95 for the time spent looking at it. Got the keys and ITS FINE, misfire has gone???? WTF? :D
HOWEVER the idle is back to being all over the shop :cry:
Could corrosion on wiring loom plug pins cause a fcuked up idle?
samy_tee
Thu Aug 17, 2006 6:17 pm
JESUS.
thats steep for labour prices.
i would try doing that, u never know it could work. but do it urself
also have u tryed lubricating the throttle cable and moving parts etc...
or get someone to rev the car while ur under the bonnet to see if its sticking at all
massive
Thu Aug 17, 2006 6:58 pm
samy_tee wrote:JESUS.
works out over £90 per hour 8O
Do it myself....i wouldnt know where to start mate! When ever i touch it something else goes wrong so I think a trip upto a zoner one sunny weekend winkeye ....any takers?
Oh to add to the problems, it now also has trouble starting, turns over for ages before it starts.
Ant
Retired Team Member
Retired Team Member
Thu Aug 17, 2006 7:11 pm
gotta be the conector under the intake is Fubar then dude.
the temp sensor, and main power/ground feeds and returns are all routed through the one plug.
Quite common to find them U/S
either get the repair kit ( £Â£Ã‚£ ) or cut the connectors out and splice the wores with quality crimps, or better still solder them , be sure to weatherproof them though !
Keep us posted fella 8O
massive
Thu Aug 17, 2006 7:58 pm
Also what I forgot to mention (yes there's more) Is that the idle is not just stable at any one point. It sharply jumps up and down the rev range from 1000-2200 like someone is switching a button. Its like its confused and not got a clue what its doing (bit like the driver lol).
Having said that, driving to football earlier, it was doing the above for the first mile when stopping at juctions etc but then i was stuck in traffic/slow moving for 25mins and it was idle fine at 1000rpm.....whether now its happier at max temp I dont know....what I do know is that its really pissing me off! :x
I'll try the above on the weekend Ant, thanks to everyone for their reply's on this matter...much appreciated
massive
Fri Aug 18, 2006 11:53 am
Started fine this morning, drove to work. Left for 3 hours and now just WILL NOT start - turns over for ever without a single attempt to fire up. Ive checked the obvious things but nope, doesn't wanna know!
What a c**t :x :soap: :banghead:
deian
Fri Aug 18, 2006 2:39 pm
it's not something else completely is it? fuel pump on it's way out maybe?
massive
Fri Aug 18, 2006 3:26 pm
Fuel is getting to the injectors fine.
Just tried it again, and not a hope of it even attempting to fire up. Looks like a walk home for me then :(
