Mtec1 Kit what a Bitch, Front Val & Rear now on
cliffybabe
- Powered by Nelly
rear should be going on tonight fingers crossed then i need to move my exhaust around to get it right between the gap
stuartgallafant
cliffybabe
- Powered by Nelly
stuartgallafant wrote:aza used his towing eye when we pulled him out the ditch!!GDBN wrote:It's a BMW ... don't need a towing eye !!!
cliffybabe
- Powered by Nelly
The rear valance is now on thank god, Is there any tips on fitting the end caps on ie bolting them to the car ro is it a case of drilling???
Neil
Neil
GDBN
I am fairly sure I used the same screw from the old one. Should be a hole behind the panel ... stick the screw in from the back and wiggle til you have contact. Then just tighten it up.
G
G
cliffybabe
- Powered by Nelly
Cheers mate thats what iwas gonna try when i get homeGDBN wrote:I am fairly sure I used the same screw from the old one. Should be a hole behind the panel ... stick the screw in from the back and wiggle til you have contact. Then just tighten it up.
G
duffs17
quality!cliffybabe wrote:stuartgallafant wrote:aza used his towing eye when we pulled him out the ditch!!GDBN wrote:It's a BMW ... don't need a towing eye !!!forgot about that, guess i better get some or avoid these sort of signs
stuartgallafant
