want to buy mine for £10kstevetigger wrote:but I might buy another E30 Sport!
BTB Zone 6 branch fitted !
billgatese30
billgatese30
dazleeds
- old skool raver
Bang goes another potentialy good thread
www.oldskoolfantasy.co.uk
billgatese30
yeah, sorry Iain, anyway,
post a sound clip so we know what to expext this weekend
massive
You would think, but my brothers VR6 leads were cheaper than golf gti ones - how they come to that conclusion i dont know318-is wrote:you reckon four will be cheaper than six?best of luck mate
gazm3
Thats rich.
Thats rich.
Templ8e30
I've got a waterproof microphone coming so I can video my Nurburgring trip so when it arrives I'll use that to make a clip. The exhaust sounds much better under load than just revving itbillgatese30 wrote:yeah, sorry Iain, anyway,
Simon, much easier to undo 1 nut and jack the engine up than fanny about removing 12 studs that were tightened in.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
gazm3
Many thanks Ian for the disc!.
See you at Ferrybridge.
Cheers Gareth.
Cheers Gareth.
billgatese30
i can't wait, either that or i'll hear it at the weeekend
oguz327
- Captain Armco
The btb 6 branch gets deeper aswell, done about 400 miles with mine and its getting more bass now.
Well pleased with it, so addicted to the sound you just wanna red line it everywhere
Many thanks Sal for the btb and Simon for fitting it
Just wondering what can if anything can be done about the low end loss in power?
Not too bothered as ive got used to driving it more like a 16 valver
Will have to see if i can get a sound clip together.
stuartgallafant
M5pilot
Oz,
A remap will help towards getting some low end torque back.
Look forward to hearing the car!
Sal
Sal
reggid
Strokeroguz3001 wrote:Just wondering what can if anything can be done about the low end loss in power?
what are your engine specs at the moment?
stuartgallafant
M5pilot
OK, 2.8 M52 Crank based then
more work for no gains over 2.7M5pilot wrote:OK, 2.8 M52 Crank based then
oguz327
- Captain Armco
ffs dont start you twoSimon13 wrote:more work for no gains over 2.7M5pilot wrote:OK, 2.8 M52 Crank based then
To be fair i am quite happy with the performance as it is for now allthough you can never have too much power its fine for the time being.
I thought about cam but i thought this would only give more power further up the rev range once again same situation.
Remap would be cool but can this be done considerering i have a tech1/early engine managment system?
All of the above are over £400
oguz327
- Captain Armco
Just out of interest, where did you get your big valve head from or who did you get to modify yours?Templ8e30 wrote:I fitted all new stainless studs a month or so ago when I fitted the big valve head !Simon13 wrote:i assumed u took all the studs out the head and fitted new studs and nuts!
if all the studs are out of the way it will fit without raising the engine off the mounts
No more rusty crusty exhaust studs for me![]()
Iain T
stonesie
MS with a maf conversionRemap would be cool but can this be done considerering i have a tech1/early engine managment system?
e30_Turbo
- Boost Junkie
or Ms in alpha N mode and no maf either!stonesie wrote:MS with a maf conversionRemap would be cool but can this be done considerering i have a tech1/early engine managment system?
Or there is the later management on the early engines, a few bits needed but supposed to work well plus you can get a Zone chip too!
HTH, Mark.
Templ8e30
I had the headwork done by this place http://www.impulsedevelopments.co.uk/ not cheap but top quality work.oguz3001 wrote:Just out of interest, where did you get your big valve head from or who did you get to modify yours?Templ8e30 wrote:I fitted all new stainless studs a month or so ago when I fitted the big valve head !Simon13 wrote:i assumed u took all the studs out the head and fitted new studs and nuts!
Iain T
Cheers,
Iain T
M5pilot
Correction - there are gains, the low end torque is more - I've driven Adam Patchton's 2.8 and while it doesn't make huge power top end it certainly beats a 2.7 for low end grunt and midrange power.Simon13 wrote:more work for no gains over 2.7M5pilot wrote:OK, 2.8 M52 Crank based then
Sal
M5pilot
Just fitted a BTB 6 branch to a zoners car but with a difference. The downpipes are made to fit BTB's single pipe system which is also on the car now.
I've not heard anything like it! The GUG (which resides in ireland now) is also getting the same 6 branch and exhaust fitted. Should go alot better than it did before with the blown scorpion and the old manifold.
Ant is coming over tommorrow to do some work and we will attempt to make a video clip.
BTB's stuff is pure class if a little expensive.
Sal
Sal
i've been in Adam's car and that just isn't true. Infact it went very well but didn't pull like a good 2.7
Maybe Adam's car would of been better if bexleys hadn't cocked the maf up.
How can u honestly think that a manifold made by btb can be better than a firm like Racing Dynamic's?
I'll have the two manifolds next to each other 2moro, i'm sure the bore size on the btb is smaller for a start.
Iain why didn't u fit bigger valves to 2.5 head?!
M5pilot
You've not driven Adam's car, you've been in it. You've not even driven karan's car......I have. The Silver C2 had more grunt than karan's cr and patchton's has more low end than that.Simon13 wrote:i've been in Adam's car and that just isn't true. Infact it went very well but didn't pull like a good 2.7
Adam complains about the MAF conversion because of it's poor cold starts which has no effect on performance once warmed up - get your facts straight.
I'm in a better position to you to comment on this. The only real experience you have of a 2.7 is your own 180bhp version (with RD manifold - I wonder what it does without).
Since when did bore size mean everything in manifold design? BTB actually said the Bore size of the RD was too big. Joe (owner of BTB) is a highly respected individual in the autmotive industry. BTB have a fantastic reputation amongst engineers also.
The ONLY reasons you have issues with BTB are:
1) I sell their stuff and your anti Sal/E30zoneshop and everyone knows it.
2) You don't have one
3) Everything you have automatically becomes better than everything else.
Sal
oguz327
- Captain Armco
Would upgrading slightly to the newer engine management be that much better than the older style one or just easyer tune?fozzymonster wrote:or Ms in alpha N mode and no maf either!stonesie wrote:MS with a maf conversionRemap would be cool but can this be done considerering i have a tech1/early engine managment system?
Or there is the later management on the early engines, a few bits needed but supposed to work well plus you can get a Zone chip too!![]()
HTH, Mark.
Would i be right in thinking it wouldnt be an easy swap aswell?
- Homo Hair
its not all that difficult afaikoguz3001 wrote:Would upgrading slightly to the newer engine management be that much better than the older style one or just easyer tune?fozzymonster wrote:or Ms in alpha N mode and no maf either!stonesie wrote: MS with a maf conversion
HTH, Mark.
go MS
M5pilot
If your going to do anything get rid of the AFM. You can't do a MAF conversion with your current management anyway.
MS running simple Throttle Angle with barometric will see a massive transformation in throttle reponse, noise and power.
You may lose even more low end torque though as losing the AFM for a hollow tube will further slow down intake airspeed.
I'll be able to explain practically when the C2 comes back from paint shop (if owner is around to give me keys.)
Sal
Sal
oguz327
- Captain Armco
fair few options, interesting stuff
stuartgallafant
Templ8e30
For a start bigger valves would not fit in the 525e piston pockets without having them machined.Simon13 wrote:Iain why didn't u fit bigger valves to 2.5 head?!
I use the car as a daily driver so I couldn't afford or be arsed to have the car off the road for a week or so so I could strip the engine again and have the machining work done.
Also bigger valves would mean a more peaky/revvy engine which I don't want.
Cheers,
Iain T
Sy_325
i got a full exhaust system made by BTB for GUG. the gains are impressive to say the least, here are a few snaps before i put the system on about a month ago... single bore system now replaces the standard dual system...
quality outfit, big thanks to sal for helping me out with this system!
oguz327
- Captain Armco
That looks horny as
tomson
Iain,Templ8e30 wrote:I had the headwork done by this place http://www.impulsedevelopments.co.uk/ not cheap but top quality work.oguz3001 wrote:Just out of interest, where did you get your big valve head from or who did you get to modify yours?Templ8e30 wrote: I fitted all new stainless studs a month or so ago when I fitted the big valve head !
Iain T
Cheers,
Iain T
what did you have them do to your cylinder head? Im almost ready to get mine sorted and im wondering if i should use these guys, their web site looks like they know what they are doing....
Tom
