E30 M3 nut & bolt rebuild
BMG
Fri Aug 12, 2016 10:44 pm
x-works wrote:Beautiful work!
Thanks, Brian. Your rebuild thread is a constant reference at each step and proving invaluable. :cheers:
Sanchez
Sat Aug 13, 2016 1:07 am
Wow. Lovely work.
KW355
Sat Aug 13, 2016 10:12 am
Amazing attention to detail. I look forward to updates.
jimbom30cab
Tech 1 freak
Sat Aug 13, 2016 10:21 am
Best thread on here at the moment IMO
:cool: :cool:
maxfield
Sat Aug 13, 2016 10:25 am
Epic!
tha881
Sat Aug 13, 2016 1:00 pm
"new bushings in the pedals" are you serious!
This is an amazing rebuild, thanks for taking the time to share it with us.
kdevitt
Sat Aug 13, 2016 6:41 pm
Amazing work. Am kicking off a new project, which is a light resto - might need to avoid this thread or I'll end up spending a lot more cash than I want to :D
aimlessrock
Sat Aug 13, 2016 8:30 pm
the attention to detail is epic...if i had the time and the beans i would love to do a resto to this standard.
E30 320i Convertible (1989)
190 Mercedes (1988)
s62
Sun Aug 14, 2016 7:38 pm
Inspirational - nothing less!! 8)
M-Sport
Sun Aug 14, 2016 11:23 pm
Nice work so far BMG, can't wait for next update :)
This has got to be at the top with the x-works resto thread.
Mods can thread be stickeeeeeed?
mattmk1
Mon Aug 15, 2016 6:55 pm
Great project, love the exploded views!
Do you have a link for the borescope...looks an interesting addition to the tool box!
BMG
Tue Aug 16, 2016 12:38 pm
Thanks for the kind words. I should point out that I'm merely bolting small bits back together so far and the major parts will have to be done by professionals, as I'm unable to weld, do body work, paint or rebuild engines. I'll be doing as much as I can, but comparisons to XWorks rebuild thread don't do justice to his work or skills.
I consider Xworks thread a gold standard of internet car rebuild threads, not only for the excellence of the work, but because he was able to do it all himself which is really what sets it apart. That he also wrote a 'how to' guide is something that's also made it much easier for me to follow in trying to replicate what he has done.
The borescope is low quality , but for the money has proved useful and handy to keep around. I don't have the link to the one I bought, but search on eBay for ' phone borescope' or 'android endoscope ' or similar and it'll bring up no end of results
DawieM3
Fri Sep 16, 2016 10:30 pm
Hi Brian,
Glad too see that you have started the process of putting it all back together.
I`m nearing completion of a full rebuild on my track car in the FINA livery.
Give me a call sometime and lets meet up as may be able to arrange a visit to a mate of mine, to see the ex Bristow Helicopters UK.
cheers,
Dave
E30 M3 Track car S14, 2.5l
2002, 2.0l fuel injected
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
2002 E10 -M57 on e46 floorpan
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
BMG
Wed Sep 21, 2016 12:41 pm
HI Dave,
Will give you a call and catch up sometime. Would be good to see you and your track car again. Thank God you went FINA and not Warsteiner !
BMG
Sun Apr 16, 2017 11:36 pm
Time for an update. Slowly been doing bits and bobs as time allows.
Heater box time. The unit was looking a bit tired and the foam was breaking up and the metal parts a little corroded.
Evidence the heater valve has been leaking a little.
Foam on the various flaps all broken up.
Image20160827_164854 by e30 m3, on Flickr
Image20160930_152608 by e30 m3, on Flickr
Pulled apart and cleaned
Image20170210_140025 by e30 m3, on Flickr
Image20170210_140048 by e30 m3, on Flickr
Cut some new foam and cleaned up the various parts
Image20160903_153958 by e30 m3, on Flickr
Image20170210_140209 by e30 m3, on Flickr
Motor gets a check over for play in the bearings and bench tested with a power supply. Bracket gets zinc plated and duct work cleaner of 20 odd years of dust, crisps and other assorted crap.
Image20170210_140349 by e30 m3, on Flickr
New foam gaskets, new heater core, new heater valve and cleaned the contacts on the resistor.
Image20170210_140529 by e30 m3, on Flickr
Reassembly starts with putting the two flaps and duct in place.
Image20170210_144818 by e30 m3, on Flickr
New bit of O-ring cord to seal the two halfs
Image20170210_145308 by e30 m3, on Flickr
The wiring look gets cleaned, checked over and then wrapped in loom tape.
Image20160904_104251 by e30 m3, on Flickr
Built up
Image20170226_124853 by e30 m3, on Flickr
Image20170226_124812 by e30 m3, on Flickr
Mounting brackets plated.
Image20170411_154524 by e30 m3, on Flickr
Fitted.
Image20170411_154554 by e30 m3, on Flickr
Finished unit. Minus the brackets which were out for plating at the time.
Image20170226_124927 by e30 m3, on Flickr
BMG
Sun Apr 16, 2017 11:59 pm
The prop was paint stripped and both joints weren't that great. These are staked in joints and not replaceable without specialist machinery, so sent away for this.
Image20160820_125129 by e30 m3, on Flickr
Painted with new lock and clamp ring.
Image20160903_135821 by e30 m3, on Flickr
New bearing
Image20160903_135716 by e30 m3, on Flickr
New rubber doughnut ,new nose bushing , nuts and bolts
Image20160903_135724 by e30 m3, on Flickr
Finished unit
Image20160903_135750 by e30 m3, on Flickr
The brake servo was looking a little tired.
Image20160530_140606 by e30 m3, on Flickr
Image20160530_140616 by e30 m3, on Flickr
Image20160530_140707 by e30 m3, on Flickr
Image20160530_140639 by e30 m3, on Flickr
I cleaned it up and gave it a paint job.
Image20160828_151800 by e30 m3, on Flickr
Image20160828_151717 by e30 m3, on Flickr
The cap and tank have been in my new garage toy, an ultrasonic cleaner.
The master cylinder ins't serviceable and only have a clean and new seal.
Image20160828_151549 by e30 m3, on Flickr
New hose, locking nuts , foam gasket and decal from Pukar
Designs.
Image20160828_151517 by e30 m3, on Flickr
There is meant to be a foam air filter under the bellows which is NLA and missing in this pic.
Image20160828_152009 by e30 m3, on Flickr
Found this open cell foam on eBay being sold as a fish pond filter which got cut down to fit.
Image20170319_124016 by e30 m3, on Flickr
Finished item came out well.
Image20160828_153645 by e30 m3, on Flickr
Image20160903_135922 by e30 m3, on Flickr
Kos
Mon Apr 17, 2017 12:18 am
Nice work :D
www.pukardesigns.com
IG Pukar.Designs
BMG
Mon Apr 17, 2017 12:32 am
The wiper motor was also looking a little bit tired and rusty.
Image20160910_121508 by e30 m3, on Flickr
Corrosion on both ends
Image20160910_125127 by e30 m3, on Flickr
Image20160910_124853 by e30 m3, on Flickr
Cover removed and the old grease is looking a little thin.
Image20160910_190250 by e30 m3, on Flickr
Gave the ends a light bead blast
Image20160920_110902 by e30 m3, on Flickr
Built back up with new nuts, washers and o-rings.
Image20160920_113912 by e30 m3, on Flickr
Freshly painted frame , greased motor and plated hardware.
Image20160920_114427 by e30 m3, on Flickr
Image20160924_154404 by e30 m3, on Flickr
New bushes.
Image20160920_113836 by e30 m3, on Flickr
Completed the pedal box with a new cylinder.
Image20160908_140433 by e30 m3, on Flickr
New hose.
Image20160908_140445 by e30 m3, on Flickr
Made a new hard line up to spec.
Image20160916_160246 by e30 m3, on Flickr
New clutch cylinder
Image20160916_160537 by e30 m3, on Flickr
Not much I can do with the ABS unit other than clean it up.
Image20160610_153115 by e30 m3, on Flickr
Image20160610_153047 by e30 m3, on Flickr
Image20160610_153127 by e30 m3, on Flickr
Image20160610_155218 by e30 m3, on Flickr
Image20160924_143833 by e30 m3, on Flickr
Image20160924_145316 by e30 m3, on Flickr
Image20160924_145242 by e30 m3, on Flickr
Finished up the throttles when the studs came back from plating
Image20160924_165632 by e30 m3, on Flickr
Same on the plenum
Image20160925_130743 by e30 m3, on Flickr
The oil cooler and lines were pretty rusty and shot and couldn't be saved, so new cooler and lines
Image20160907_125148 by e30 m3, on Flickr
Image20160907_125206 by e30 m3, on Flickr
BMG
Mon Apr 17, 2017 12:50 am
Shifter linkage gets a clean and new bushes etc. Not sure if I'll change out the old work shifter for something else yet.
Image20160206_152418 by e30 m3, on Flickr
Image20160206_152435 by e30 m3, on Flickr
Image20160924_153509 by e30 m3, on Flickr
Header tank was fitted not long before the car came off the road, so just cleaned up.
Image20160813_144417 by e30 m3, on Flickr
Image20160813_144534 by e30 m3, on Flickr
Image20160813_144519 by e30 m3, on Flickr
New cap and replated mounting.
Image20160924_150227 by e30 m3, on Flickr
Ally water rail has been off for some vapour blasting. The steel line has been powder coated , new sensors o-rings and hardware purchased.
Image20160907_123817 by e30 m3, on Flickr
M3 heatshields are NLA. 325 items are only slightly different and should be OK with the different ( smaller ) exhaust I'll be using, although the back one may need cutting, so purchased one before they too possibly went NLA.
Image20160830_143313 by e30 m3, on Flickr
Image20160830_143413 by e30 m3, on Flickr
Image20160907_130439 by e30 m3, on Flickr
BMG
Mon Apr 17, 2017 1:25 am
I got tempted to rebuild the diff myself in an effort to keep costs down, so pulled it out from storage and set about having a look. Looks pretty crusty but had no obvious leak or problems.
Image20170218_133909 by e30 m3, on Flickr
Image20170218_133923 by e30 m3, on Flickr
Image20170218_134012 by e30 m3, on Flickr
Image20160324_172959 by e30 m3, on Flickr
Back cover removed and we can see the LSD unit.
Image20170218_133942 by e30 m3, on Flickr
Output flange removed.
Image20170218_154430 by e30 m3, on Flickr
LSD unit removed and showing the pinion
Not chunks of diff or bearings found, so looking good.
Image20170218_144040 by e30 m3, on Flickr
Pulled the LSD unit apart and found more expense.
Image20170228_140817 by e30 m3, on Flickr
Both ramps torn up.
Image20170228_141128 by e30 m3, on Flickr
Time to clean up what we have.
Image20170301_160546 by e30 m3, on Flickr
Image20170305_103730 by e30 m3, on Flickr
Image20170305_103117 by e30 m3, on Flickr
Cleaned up with new seal, o-ring, bolts, lock ring and original spacer.
Image20170305_103103 by e30 m3, on Flickr
Image20170305_103351 by e30 m3, on Flickr
Full bearing set, clutches, seal, lock washer, crush ring.
Image20170305_103620 by e30 m3, on Flickr
Back cover after vapour blasting and new parts
Image20160803_162913 by e30 m3, on Flickr
The diff will be off to see Gareth for a rebuild and repair on the LSD ramps.
BMG
Tue Apr 18, 2017 7:02 pm
The diff case has been away to the powder coating shop for a blast clean and coat of satin black powder. Very pleased with the results.
Image20170418_163917 by e30 m3, on Flickr
Image20170418_164012 by e30 m3, on Flickr
Image20170418_164142 by e30 m3, on Flickr
Been having a few things vapour blast at TSR and pleased with the results. Had this spare upper oil pan on the shelf and got it done with a batch of other bits. www.tsrvapourblasting.co.uk/
Image20170402_100519 by e30 m3, on Flickr
Bought a little polishing mop kit for use on a 6 inch bench grinder and cleaned that up and had the bolts and oil drian return plated with a new bolt on the corner for the earth strap.
Image20170415_094617 by e30 m3, on Flickr
Little dab of Loctite on the bolts and another part ready to be boxed and ready.
Image20170418_144929 by e30 m3, on Flickr
This sorry looking mess is the fuel pump and filter.
Image20160213_160533 by e30 m3, on Flickr
Image20160213_160501 by e30 m3, on Flickr
Not much can be saved except ( and just about ) the brackets and clamp ring.
New Bosch pump , filter, hose, clamps, mounting rubbers and hardware.
Image20170418_144655 by e30 m3, on Flickr
Image20170418_144546 by e30 m3, on Flickr
The fuel rail was another part that had a visit to the powder coater.
Image20160517_115937 by e30 m3, on Flickr
Image20160517_115952 by e30 m3, on Flickr
Might as well put a new regulator on, new hose clamps and hardware. The injectors will be refurbished when the engine is close to being complete as its not wise to let them sit a long time after refurbishing.
Had the powder coated mask the cups in which the injectors and regulator sit so they were blasted or coated. Powder being quite a thick coating and could possibly interfere with the fit and seal of the injectors. Don't want petrol leaking everywhere....
Image20170418_145401 by e30 m3, on Flickr
Image20170418_145320 by e30 m3, on Flickr
The oil separator got a bath in the ultrasonic cleaner , bracket got plated along with the mounting bolts and new hoses purchased along with an idle valve.
Image20170418_145726 by e30 m3, on Flickr
Slowly been buying bits as they come up for sale cheap, one of which was a new genuine water pump.
Image20170418_184108 by e30 m3, on Flickr
Image20170418_184125 by e30 m3, on Flickr
New thermostat.
Image20170418_184006 by e30 m3, on Flickr
No option then but also get all those unique BMW only hoses. No point trying to salvage 27 year old rubber parts on this car.
Image20170418_184031 by e30 m3, on Flickr
Water pump pulley is another powder coated item with new plated bolts
Image20170418_184514 by e30 m3, on Flickr
BMG
Tue Apr 18, 2017 9:43 pm
Been working on the steering parts.
The rack was leak free from what I remember, but tatty. Given the streering feel is one of the things the M3 is praised for, would be a shame not to make sure everything is in tip top condition.
Most of the oil on it is from I guess the S14 above it.
Image20151003_152232 by e30 m3, on Flickr
Image20151003_152256 by e30 m3, on Flickr
Image20151003_152307 by e30 m3, on Flickr
The oil leaks didn't stop corrosion setting in on the steel main tube.
Image20151003_152415 by e30 m3, on Flickr
Image20151003_152431 by e30 m3, on Flickr
Starting pulling it apart. Under the small cover, water has got in and rusted some of the parts
Image20170311_130503 by e30 m3, on Flickr
Image20170311_130759 by e30 m3, on Flickr
Image20170311_130835 by e30 m3, on Flickr
Image20170311_131149 by e30 m3, on Flickr
Put the steering to center and marked the position of the parts
Image20170311_132400 by e30 m3, on Flickr
Image20170317_123531 by e30 m3, on Flickr
Removed the valve housing and pinion
Image20170311_133047 by e30 m3, on Flickr
Pin wrench tool is needed to remove the large nut that secures the main steering rack tube to the aluminium casing
Image20160521_210459 by e30 m3, on Flickr
Image20170311_133703 by e30 m3, on Flickr
Image20170311_133809 by e30 m3, on Flickr
This is the rack piston.
Image20170311_134438 by e30 m3, on Flickr
With the main tube removed you have the rack and a smaller tube that sits inside.
Image20170311_140647 by e30 m3, on Flickr
Image20170311_140658 by e30 m3, on Flickr
With the rack removed you can see a spacer and oil seal inside one end
Image20170311_140947 by e30 m3, on Flickr
This is the other end of the small tube.
Image20170317_121703 by e30 m3, on Flickr
Inside one end of the main tube is a spacer, oil seal and this bearing sleeve. You can remove this with just a pic. You'll then need to remove the seal.
Image20170311_150344 by e30 m3, on Flickr
This is the o ring and and snap ring on the other end.
The top valve housing has a bearing and oil seal ( seal already removed in this pic ) to be replaced.
The bearing has to be removed first which was done by heating with a heat gun and fell out before I even tried to drift it out.
The seal can then be knocked out.
Image20170311_153110 by e30 m3, on Flickr
Image20170311_153153 by e30 m3, on Flickr
The lower case also has a seal and bearing.
Image20170311_133110 by e30 m3, on Flickr
Image20170415_135432 by e30 m3, on Flickr
Word of warning on taking the rack apart. I could only find one of the three bearings in the rack and the ETK listed ( 32 13 1 132 798 )seal repair kit appears to be the wrong one. I also bought another generic Febi branded E30 kit and mixed and matched .
The only bearing I could find was for the lower case and it being a generic drawn cup part. The one on the pinion and in the top valve housing I couldn't find. See here for part numbers on the bearings I pulled from mine.
https://s14net.vbulletin.net/forum/s14/ ... ering-rack
With is all done, the parts all get a bead blast and bath in the ultrasonic cleaner.
Fit new top oil seal.
Image20170415_135530 by e30 m3, on Flickr
Refit the old bearing.
Image20170415_135609 by e30 m3, on Flickr
Fit new bearing in the lower case.
Image20170415_135343 by e30 m3, on Flickr
New oil seal in the lower case
Image20170415_135405 by e30 m3, on Flickr
Image20170321_163653 by e30 m3, on Flickr
The oil seals fitted on the valve part. Under each of the 4 white ( nylon ? ) rings is a rubber o-ring to be replaced first.
Image20170415_135646 by e30 m3, on Flickr
Image20170321_164809 by e30 m3, on Flickr
These are piston parts on the rack.
Image20170321_192247 by e30 m3, on Flickr
Under the white seal is the rubber o-ring
Image20170321_192615 by e30 m3, on Flickr
The wiper seal and parts
Image20170321_164305 by e30 m3, on Flickr
Image20170321_164439 by e30 m3, on Flickr
Replated parts
Image20170415_134845 by e30 m3, on Flickr
The small tube with new parts and another problem. The spacer under the oil seal that came out the rack had a chamfer on one side which the replacements didn't and which required me to cut one in.
Image20170321_163757 by e30 m3, on Flickr
With these first few parts sub assembled, this is a layout of the rest.
Image20170415_134723 by e30 m3, on Flickr
I polished up the rack to a mirror like finish and had the main tube replated and was just about to reassemble but wasn't happy with the plating. Doesn't show up in the above pic, but I should have prepped it better as the plating shop will just acid clean and plate.
It bugged me so ended up sanding it all back and polishing the tube ready for another plating try, but may this time buy a small zinc plating kit and do the remaining parts my self.
Image20170416_153337 by e30 m3, on Flickr
That's it for now on the rack rebuild until the tube is plated.
The power steer reservoir gets an ultrasonic bath. New power steer hoses purchased and replated.
Image20170418_143903 by e30 m3, on Flickr
Image20170418_144031 by e30 m3, on Flickr
Bracket and hardware replated.
Image20170418_144007 by e30 m3, on Flickr
New sticker from Pukar designs finishes everything off nicely.
Image20170418_143950 by e30 m3, on Flickr
MPOWERCRAZY
Wed Apr 19, 2017 12:03 am
love it! impressive work mate! hope it gets completed quickly, can't wait to see the finished results!
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
bigbird76
Fri Apr 21, 2017 7:19 pm
Bloody hell, this is a great build..
Kos
Tue Apr 25, 2017 2:57 am
IG Pukar.Designs
mani
Sun May 07, 2017 10:54 pm
This is a proper build you don't see many done like this, well done mate .
aimlessrock
Mon May 08, 2017 8:03 am
This build is epic-loving it.
190 Mercedes (1988)
M5London
Mon May 08, 2017 11:50 am
Amazing build and coverage !
Can't wait to hear what Agreed Value Insurance figure you go with :) !!!
E30 M3 1987 - Diamond Black Metallic / Black Leather
E34 M5 1995 - Arctic Silver / Black Leather
E39 M5 1999 - Carbon Black Metallic / Caramel Nappa Heritage Leather - Supercharged
F06 M6 Gran Coupe 2015 - Imperial Blue Xirallic / Silverstone Merino
crossie
Thu May 11, 2017 12:56 pm
How bad was the shell?
Any photos?
SHAKEELE30
Boost Junkie
Fri May 12, 2017 10:26 pm
thats some serious attention to detail there, wish i had your talent and skills...need to do the same but dont know where to start :mad:
BMG
Sat May 13, 2017 8:20 pm
Thanks all. The shell isn't too bad, more just the usual E30 rust spots. That said, I haven't done anything with the shell yet, so no doubt more to uncover. No pics yet, but will post up when I get on to working on the shell.
Olie92
Wed May 17, 2017 3:49 pm
Wow...just joined this forum and stunned with awe looking at this thread...super great work!
BMG
Sat Jul 22, 2017 8:46 pm
Been finishing off the steering rack and had it replated. Here's the main tube and associated parts.
Image20170527_141619 by e30 m3, on Flickr
The main seal, spacer and guide in place.
Image20170603_132637 by e30 m3, on Flickr
The main tube , inner tube and rack.
Image20170603_151506 by e30 m3, on Flickr
Together.
Image20170603_151900 by e30 m3, on Flickr
Main piston in place.
Image20170603_164151 by e30 m3, on Flickr
Main tube gets its locking ring and seal.
Image20170603_171615 by e30 m3, on Flickr
Rack inserted into the main tube.
Image20170603_172456 by e30 m3, on Flickr
Lower housing in place.
Image20170603_195446 by e30 m3, on Flickr
Pinion in place.
Image20170603_201201 by e30 m3, on Flickr
Upper housing in place.
Image20170604_102201 by e30 m3, on Flickr
Center the rack and add top cover.
Image20170604_102608 by e30 m3, on Flickr
Back of the rack .
Image20170604_102630 by e30 m3, on Flickr
Pressure piece , spacer and spring in place.
Image20170604_102824 by e30 m3, on Flickr
The cover get bolted down with a bit of sealant to stop the previous water ingress and light rust.
Image20170604_102927 by e30 m3, on Flickr
Replated parts.
Image20170605_123136 by e30 m3, on Flickr
Pipes in place.
Image20170605_125803 by e30 m3, on Flickr
Image20170605_125806 by e30 m3, on Flickr
Finished rack.
Image20170605_125739 by e30 m3, on Flickr
Image20170605_125826 by e30 m3, on Flickr
Coupling gets a clean-up and new pinch bolts and nuts.
Image20160813_153021 by e30 m3, on Flickr
New inner and outer tie rods purchased. Bought Lemforder parts ( same as BMW use/supply ) from a parts specialist and much cheaper than a BMW dealer. The only problem being Lemforder sell them unpainted , so a quick paint job needed.
Image20160227_143239 by e30 m3, on Flickr
Tie rods and gaiters in place and the rest of the steering parts .
Image20170709_125038 by e30 m3, on Flickr
Mounting parts and shear bolts.
Image20170710_115034 by e30 m3, on Flickr
BMG
Sat Jul 22, 2017 9:54 pm
The diff is back from Gareth and looking good.
Image20170521_123913 by e30 m3, on Flickr
Image20170521_123824 by e30 m3, on Flickr
Image20170521_123758 by e30 m3, on Flickr
Fuel filler pipe has been powder coated. New cap, rubber sleeve, mounting bolt and restrictive flap insert.
Image20170423_102756 by e30 m3, on Flickr
The in tank lifter pump was a touch rotten...
Image20160324_152810 by e30 m3, on Flickr
Image20160324_152754 by e30 m3, on Flickr
New one much needed.
Image20170420_134108 by e30 m3, on Flickr
Image20170420_134047 by e30 m3, on Flickr
The fuel tank is away being painted. New parts for that include hoses and mounting brackets along with replated cross over tube and tank brackets .
Image20170419_142553 by e30 m3, on Flickr
There's not a short of new bits needed, so a new Bosch ignition coil purchased and painted black. Bracket replated.
Image20170420_133219 by e30 m3, on Flickr
New subframe mounting parts.
Image20170419_140959 by e30 m3, on Flickr
Image20170419_140825 by e30 m3, on Flickr
New wishbone bushes.
Image20170419_135836 by e30 m3, on Flickr
I changed the roll bars years ago after getting a good deal on a Racing Dynamics set. The mounting bracket for the front gets a powder coating in black and and the bush clamps replated.
Image20170419_141736 by e30 m3, on Flickr
Powder coated bars.
Image20170723_104938 by e30 m3, on Flickr
The original spot lights were sold years ago and replaced with Sport Evo brake ducts. Going back to stock means shelling out more cash...
Image20170421_152500 by e30 m3, on Flickr
The original headlights were an odd set ( one side Bosch , the other Hella ) and stone chipped to hell with rusted adjusters. So more credit card flexing on a new set of Hellas.
Image20170420_134527 by e30 m3, on Flickr
Image20170420_134410 by e30 m3, on Flickr
New intake gaskets purchased, replated hardware.
Image20170419_141536 by e30 m3, on Flickr
The plater also did some other bits like the engine parts.
Image20170419_140354 by e30 m3, on Flickr
Door parts.
Image20160414_112034 by e30 m3, on Flickr
Replated bits.
Image20170419_141317 by e30 m3, on Flickr
Alternator bracket plated.
Image20170419_142324 by e30 m3, on Flickr
New bonnet rollers purchased, the other parts were just replated.
Image20170419_141959 by e30 m3, on Flickr
A wise purchase while back was a complete timing chain and tensioner kit. Prices for this parts now are expensive !
Image20170420_135949 by e30 m3, on Flickr
Exhaust bracket ( along with spare bellhousing bracket ) replated and new nuts.
Image20170419_140156 by e30 m3, on Flickr
New exhaust hanger parts.
Image20170419_140713 by e30 m3, on Flickr
The car came to me with a non cat ( larger ) header. This has been away for a heat coating paint.
Image20170722_133511 by e30 m3, on Flickr
New gaskets, new Bosch lambda sensor and Turner Motorsport stud kit.
Image20170722_133004 by e30 m3, on Flickr
New ignition wires , 8mm Turner parts.
Image20170722_133908 by e30 m3, on Flickr
The original lower Evo airbox section had a hole worn in it. More credit card flexing for an expensive bit of plastic.
Image20170722_134230 by e30 m3, on Flickr
Airbox parts and new filter.
Image20170722_180603 by e30 m3, on Flickr
Old intake.
Image20160903_115917 by e30 m3, on Flickr
Image20160903_115904 by e30 m3, on Flickr
Cleaned with new mounting clips and gasket.
Image20170722_182628 by e30 m3, on Flickr
Finished item.
Image20170723_103455 by e30 m3, on Flickr
BMG
Sat Jul 22, 2017 10:32 pm
The driveshafts felt good, but the outer CV has a crimped on metal cover which means that can't be disassembled without wrecking the cover, which isn't available. Despite this I was interested in seeing the condition of the parts and if they could be reused.
The outward condition was tatty.
Image20151231_154357 by e30 m3, on Flickr
Image20151231_154338 by e30 m3, on Flickr
Image20151231_154420 by e30 m3, on Flickr
ABS rings removed and replated.
Image20151127_162811 by e30 m3, on Flickr
Shafts have been away for powder coating.
Image20170723_103702 by e30 m3, on Flickr
I found a similar outer CV cover from a Dodge truck which gets cut down and a slight flare added to stop the CV boot sliding off. I'll have to work out a way to crimp the cover on. As yet to be plated.
Image20170722_151419 by e30 m3, on Flickr
I bought new inner CV joint kits as they are cheaply available and replated the tin covers.
Image20170419_143453 by e30 m3, on Flickr
The new parts laid out with the powder coated shafts along with the cleaned and painted outer CV parts.
Image20170722_151359 by e30 m3, on Flickr
When the modified covers come back from plating we'll see if the experiment works out.
