1990 320i m20 Touring 2.7 mtech 2
Sasquatch
Post Sun Feb 26, 2017 7:12 pm
Cheers, I haven't had much to update on.
I had issues with my fpr going bad. Killing the already failing pump. So changed the pump out, just general service items. Also acquired a CD43 BMW Business CD head unit and added that today, meanwhile adding AUX for mp3 and whatnot. Going to go back and flush mount it at some stage.
Apart from that, still haven't done much in the way of turbo, was planning on changing out to headstuds but as mentioned before, stuff happened :)
Djordje
If we hit that bullseye, the rest of the dominoes should fall like a house of cards. Checkmate!
Sasquatch
Post Sat Mar 25, 2017 10:56 am
The turbo project is under way, but I wont bore you guys with that. maybe this will do for now:
Djordje
Olie92
Post Sat May 13, 2017 8:12 am
Lovely touring...inspired me with my own project!
Sasquatch
Post Sat May 13, 2017 9:37 am
Olie92 wrote:Lovely touring...inspired me with my own project!
Nice! I'll take that as a compliment :)
Djordje
Sasquatch
Post Sat May 13, 2017 10:31 am
The exhaust starts with some bits and bobs. Bends, pipe, bosses and v band clamps :)
Some messing abount and sticking together to make sure it all fits
And them we can see that there are problems with the oil filter housing. Also for the astute observer, this was all test fitted on my friends cabrio.
then get it all stuck together
A quick description, the oil filter housing needs to be rotated 90° so that the oil filter faces down. Hoses will need to be made to have this work. Further more there is a Lambda (O2 sensor) boss ~1m away from the turbo - this is per instructions for O2 sensors. Also the ETG sensor should be before the turbo, however no room and in case of maintenance it would be a pin to get at. I have been informed that they burn out.
The WG should also be perpendicular to the exhaust at 90° - again no room due to A/C
Then the time came for a change to ARP head studs but first some more bits just in case - I didn’t plan on taking the head off because the engine is a budget stroker with ETA pistons and 2.5 head. I bought a new head gasket just in case and then I was offered a MLS head gasket for a pittance.
Took the turbo apart to inspect it and clock it
Then, well lets just say fun times were had by all. We put a stud in and it tore out the thread between 6-5 cylinder on exhaust side.
So with some hesitation went with helicoils - the idea is to but time serts here but I was afraid that it would require too large of a hole - and on the m20, there is limited room
With MLS and head studs
The stuts are tighhtened to 95nm - note that everything was cleaned in detail :). So while there (famous last words) I added some assurance.
Then it came time to make some holes.
The oil pain is currently being wielded, it will have a baffle and I will be adding a windage tray. Also just cause it will need it, I bought a Sachs performance clutch. It should be good for ~450nm (as per testing from a friend)
Djordje
Post Sat May 13, 2017 12:05 pm
What will you do about having a spark plug lead so close to a red hot turbo?
Sasquatch
Post Sat May 13, 2017 12:10 pm
The turbo will have a blanket. Furthermore the leads will be going in another direction as I will have wasted spark as coil near plug set up. If it decides to melt the lead. Then cut the flange for the turbo and rotate it towards strut. I guess we will burn that bridge when we get to it. :)
Djordje
Post Sat May 13, 2017 1:56 pm
Might be worth wrapping the plug lead with some heat insulation wrap of some sort...
Sasquatch
Post Sat May 13, 2017 2:06 pm
I have that on hand as well, might do that. Thanks!!!
Djordje
Sasquatch
Post Wed Jun 21, 2017 5:54 am
Added the baffle to the sump
And while there added the windage for the crank
With the sump all nice and done, it was time to wrap the exhaust mani, and down pipe
Then moved onto fitting a thinner A/C(AUX fan) and intercooler
Then it came time to chop the front valance to allow room for all this stuff and see what do to about the oil cooler
The factory oil cooler was used with banjo fittings (m22 x 1.5). Sitting just below the factory location, but not too low as to have it get damaged (I hope)
A new cooler has been ordered as this was basically a mock up.
It fits...
With some editing of the mtech front valance :(
While at it, changed the radiator out
It all a very tight fit, with air con and all and checking the clearances it is going to be fun when the turbo sits in there. Speaking of that, that would be next, including 90% of the exhaust and making a start on charge pipes.
Djordje
Sasquatch
Post Wed Jun 21, 2017 7:20 am
Djordje
Sasquatch
Post Sun Oct 15, 2017 1:55 pm
Its all a tight fit, when I want to have AC and stuff. Ahh well it might all fit under the bonnet.
Dont have a swedge so made some something.
Some electrical work, adding coil near plug, sequential injection and all that happy fun stuff.
After some consideration we will add a cam sensor.
I will need to do something about brakes and have decided to look at the wiki. Grabbed the Chrysler front disks and renault megane 225 front calipers . Will need to make up a braket but the offset is good and it fits under a 16" wheel. Will also be trying 300mm single pot rear dics from a 120d :) The hats are almost identical to the e30 in size. Will see when we get to that.
This is currently how it stands, at 0.8 bar and a slipping clutch. Should be sored in a day or two. Will be pushing 1.2 bar hopefully might try 1.4 bar but we will see.
Found a solid set of French hedlights and fogs, well actualy a friend bought a car with them. He dosen't like them so we made a trade.
Djordje
mani
Post Thu Nov 02, 2017 11:26 pm
Cool build mate
Sasquatch
Post Sun Apr 29, 2018 9:19 am
Been driving around for a few weeks now. Managed to fit the recaros. The main downside as it is getting hotter is that there is not enough airflow over the a/c condencer due to the intercooler. It cools, but when not moving it seems to be in the high teens. Note that it was converted to from r13a to r134a or what have you. Anway here aew some pictures.
Djordje
