Found some rust - advice
ross_jsy
Post Sat May 03, 2014 7:27 pm
So sanded it back and it's all good metal:
Popped the grill off and it all felt pretty good till I pulled off a blob of seam sealer which revealed this hole :(
The metal around it is all solid though so thinking sand as much as I/Frenchie can, then use some of that Bilt Hamber Deox Gell before etch priming it to stop any further rot? I can live with that small hole for now
jimmyspeed
Post Sat May 03, 2014 7:30 pm
when you do weld it that bronze stuff won't join so you have to edge it back
maxfield
Post Sat May 03, 2014 7:31 pm
The deox gel is very good stuff. It would be what I use aswell as some decent etch primer.
You'll have fun welding the hole, you'll get spat at when you're close to that braising :)
