zd3bx's 1990 E30 325i SE Black Saloon Project Thread
zd3bx
Post Sun Aug 18, 2013 10:55 am
Woah, it's been a while since the last update, but nothing really happened in the meantime, so there wasn't much to post about...
The car was on the ramp the other day and I noticed that the filler plug on the diff was leaking for some reason...
Looks like it's the washer, but for some reason the filler plug's washer is different from the drain plug's?
And by the way, I made a mistake in my other post, when I said the diff plugs were torx - they are 10mm hex :)
Anyway, went to BMW and picked up 2 plugs with 2 washers for about 10 quid, so going to replace the filler plug, but will leave the drain one as it is for now, since it's not leaking.
The new ones have an inner rubber ring and you have to buy the washer separately. The part number for the plug is 33 11 7 525 064 and the washer is 07 11 9 963 355. Also I'm going to get Loctite 5970 (part number 83 19 0 404 517) to properly seal the thing, because I don't want to see that plug leaking again...
While the car was in the air, took a few snaps of leaks underneath...
The sump plug is leaking, which is not a big deal, but it seems like the main leak is from the sump gasket.
This one looks like to be the oil cooler gasket? I've read it's a common issue? Anyway, going to sort out these two when I do the next oil change, so shouldn't be a problem.
The power steering pipes have definitely seen better days, so they will need to be replaced sooner or later and steering in general has to be sorted as well - too much play in it and it's really heavy when stationary.
And finally the worst bit, the front crank seal is leaking...again!
This coupled with the noisy timing belt/tensioner, I feel like it's a good time to do some re-work there...
Was planning to do front disc brakes/bearings and all that soon, but that will probably have to wait, until the timing and the front seals are done.
Will keep you updated :)
G-Bear
Post Mon Aug 19, 2013 9:39 pm
Changing the sump gasket is a timely job, as so much has to be taken away from underneath to get to it, I thin. I think there is a way in the wiki pages to change it without pulling so much out...
http://e30zone.net/e30zonewiki/index.php/M20#Sump
If you want to borrow an engine brace let me know. If you're north-ish london. I could pop down and lend you mine..
As for the oil cooler gasket.. I put a write up on the wiki pages a while back... a bit of a fiddly job, but straight forward enough...
G-Bear
Post Mon Aug 19, 2013 9:47 pm
On second glance at that pic.. sorry I think I miss-read your post. That oil leak looks like it might be coming either from oil filter seal or where the actual oil filter housing attaches to the engine.. but I think that's what to wrote anyway :o
Laher
Post Mon Aug 26, 2013 6:41 am
Great thread for us noobies on how to sort out the standard stuff.
Loving the guibo/gear linkeage post, will be purchasing them parts soon to sort the jerky shifts out !
zd3bx
Post Sat Sep 07, 2013 6:16 pm
Hey G-Bear, thanks for the tips, but most likely I'll be taking it to a local BMW specialist for the sump gasket change, as that's not something I'd want to do myself...
Laher, you're welcome mate!
7th of September UPDATE:
I think I have finally sorted out the filler plug leak on the diff, so I ended up putting the original plug with a new washer there and also wrapped the plug with PTFE tape. Looks clean now:
Kind of got bored of the modern aftermarket Sony radio I had for a while and decided to go back to CD43 :) All working fine, except the left screw cover is missing, but it's covered with a black tape, so I'm not too bothered.
Also went to my local BMW dealer this morning and ordered some parts for the front brake discs job I'll be doing soon, like backing plates, nuts and bolts, etc. Will do a more detailed post, when I've got all the parts.
Still need to order front wheel bearing kits and brake discs from ECP, so once I've got everything, I'll post some pics :)
The timing belt re-work job is on the cards as well - just waiting for one part to come from BMW, and then we'll hopefully get that done this month.
Stay tuned!
spook
League two here we come !!!
Post Sat Sep 07, 2013 8:42 pm
Good thread mate, its a great feeling when you know everything has been serviced correctly. I know the costs mount up but at the end of the day your gonna have a sweet driving car.
zd3bx
Post Mon Sep 16, 2013 11:08 pm
spook wrote:Good thread mate, its a great feeling when you know everything has been serviced correctly. I know the costs mount up but at the end of the day your gonna have a sweet driving car.
Yeah, when you buy a car of this age, it's obviously expected that you'll need to spend quite a bit of cash on sorting out the mechanical bits, and not to even mention the rust/bodywork.
Monday 16th September little update :)
This is the cover that I was waiting from BMW to arrive, which most likely got damaged when we replaced the front seals last year. The guy doing the job thought it was "ok" to pry out the seals with a hammer and a screwdriver...No wonder the seals are leaking now...
The gasket comes separately, so you'll need to specify that when ordering.
Anyway, I've got a new timing belt kit and new seals as well, so I'll see how it goes and we might get this re-work done by the end of the month.
And here are all the parts ready for the front brake discs replacement and few other things...
The discs are standard vented 260mm PAGID from ECP (£20 each), the front wheel bearing kits were around £60 a piece and they came with axle nuts as well. It's quite weird how they were packaged - the outside box is Ruville, then when you open it, there's an FAG box inside and the actual bearing is FAG.
Well, both of the makes are OEM quality, so I'm happy with that.
The rest of the parts are:
Brake dust covers - 34 11 1 154 241 (left) and 34 11 1 154 242 (right), about £35 for each.
The bolts for the covers (6x) - 34 10 3 451 068
Hex bolts for the discs (2x) - 34 11 1 123 072
Front caliper bleeder valves (2x) - 34 11 1 121 206
The inner cups that go behind the bearings (2x) - 31 21 1 126 790
And finally the outer dust caps that cover the axle nuts (2x) - 31 21 1 130 125
All together the BMW bits added up to just over 100 quid, mainly just the dust covers being quite pricy, the rest cost penies.
Planning to do the above hopefully this week, but won't have any pictures for you, as the work will be done by a specialist. However, when we will be re-doing the timing, I'll take a few snaps :)
Thanks everyone.
sunnyr83
Post Tue Sep 17, 2013 1:32 am
zd3bx
Post Sat Sep 21, 2013 6:57 pm
September 21st UPDATE:
Finally got the front discs replaced along with new bearings, new dust covers and new bleeding valves.
Good thing that I bought all the necessary parts, because it's unbelievable how rusty some bits were:
And here's the shiny stuff:
The brakes are now sorted, so I'm happy with that. Checked the pads and they have about 50% life left in them, so will leave them for now, but will probably have to replace next year.
The timing/front seals re-work hasn't been done yet, so planning to do that next, possibly next weekend, but I'll see how it goes.
One quite big job that's left before I move on to suspension side of things is the sump gasket. While I'm there, I also want to replace the oil housing gaskets as well, change oil and filter obviously, plus engine mounts, and a new sump plug+washer.
However, there are a few little things that I'd rather do before that, like replacing the FPR with a new vacuum hose and get the P/S pipes sorted, plus a new steering guibo.
Anyway, whatever happens you'll be first to know :D
Cheers guys
Sanchez
Post Sat Oct 12, 2013 12:14 am
This is proper E30 ownership. Good work great right ups.
jimbom30cab
Tech 1 freak
Post Sat Oct 12, 2013 7:08 pm
This is my favourite thread on the zone right now
keep the updates coming
:banana:
parkin10
Post Mon Oct 14, 2013 10:16 pm
just read this thread
nice work
still finding things to fix , repair and replace after six years of owner ship on mine
got a coolant leek to find on my e30 before winter sets in :cry:
Andy325i
Post Mon Oct 14, 2013 10:23 pm
This is brilliant :) Well done :)
zd3bx
Post Sat Oct 19, 2013 8:41 pm
Thanks for the nice comments guys :)
Saturday 19th UPDATE:
Not much happened lately, as I was planning to do the timing re-work and all that, but this keeps getting delayed due to the garage where I work being busy, so not much time to work on my car.
Anyway, good thing that I remembered about my very tiny coolant leak from the thermostat housing, so decided to pop into BMW and pick-up a new gasket for it, and got a new bleeding screw as well (I rounded my one a while ago). So will get this one, when I re-do the timing, etc.
Thermostat housing gasket - 11 53 1 722 692 (note, this is for the housing, not the outer cover)
Bleeding screw - 11 53 1 275 881
And while I was there, I thought I would get a few more parts for the sump gasket change, so I got the sump gasket, the gasket kit for that plug on the oil filter housing (common problem? 11 42 9 059 338), the o-ring for the housing itself (11 42 1 265 670) and some o-rings/washers for the bolt that holds it all in place.
Amazingly, the sump gasket (11 13 1 730 234) was just £13, so I thought why not? A genuine BMW part for just over a tenner, money well-spent :)
It all looks like this:
So yeah, all the P/S and fueling side of things are still on the cards, but I'll see how it goes and keep you updated for sure!
pikanibbles
Post Sat Oct 19, 2013 10:19 pm
Great quality thread! I really enjoyed reading it. I'm planning on doing a similar thread on my SE, but everytime I do any work I forget to take pictures :roll: It's quite a task keeping up with maintainance and correcting years of neglect but the efforts are definetely worth it. Keep up the good work.
zd3bx
Post Sun Nov 10, 2013 7:11 pm
November 10th :)
Guys, we finally managed to get the time to do the re-work on the front crank seals and installed a new timing belt along with a new tensioner.
It's hard to say why the belt was making a "checking" noise from cold starts, because the belt itself looked fine and the tensioner was ok too. The camshaft timing gear had some minor marks on it, possibly from someone trying to remove it in the past, but not sure if that could be the cause of any timing noises when the engine's cold.
Anyway, the front seals were pissing badly:
So we removed the cover (a couple of 10 and 13mm bolts on the cover, and 3 on the sump) and cleaned the area thoroughly:
Fitting the cover back in place was quite a pain the ass, as you have to be very careful how you push the seals on the shafts. We used an RTV glue for the cover gasket and also on the bottom bit which attaches to the sump.
Checked for any leaks and so far so good. Will drive for a weeks, then will check again to make sure it's all dry.
Unfortunately, we didn't have the time to change the thermostat housing gasket, but anyway it's not a big deal as the leak is very slow.
So now it all runs smooth and quite. However, if you have an E30, it always keeps you busy...
Just as I started thinking about sorting my steering and replacing the sump gasket, I noticed the grease leaking from the driver's side outer driveshaft boot...
And to make things worse, the starter motor started making a grinding noise yesterday, so that will need to be replaced soon too. Don't want to go for any cheapo stuff and the Bosch unit is about 100 quid. Nice!
Oh, talking about Bosch, I remembered that I replaced my eBay quality wipers with Bosch aeros, so now there's no more squeaking and no more wiper marks on the windscreen :)
That's about it. So most likely I'll need to sort the driveshaft boot and the starter motor first, then will move towards the sump, steering and other things.
Busy days :)
Jamie8GTi
Post Sun Nov 10, 2013 7:52 pm
Nice thread :) Very helpful tips! good luck with it :cool:
jimbom30cab
Tech 1 freak
Post Sun Nov 10, 2013 8:54 pm
great work, really enjoyed reading this, keep the pics coming
zd3bx
Post Sun Nov 24, 2013 4:58 pm
Sunday the 24th update!
Changed the starter motor this Thursday and what a pain in the ass job it was...That top bolt that everyone's talking about is a proper bitch - ended up dropping the exhaust to get more leverage to turn the ratchet and it took almost 2 hours to do get it all done.
Here's the new motor:
It's a re-conditioned Bosch unit I managed to get from eBay for less than £100. A pretty good deal, I think. The part number is: 0 986 014 840. NOTE, it's only for 320i and 325i, 4 cyl engines have different starters.
So now no more grinding, just a nice smooth start :)
And here's the driveshaft cv boot leak that I was talking about before:
As you can see, it's the driver's side outer boot, so most likely the next job will be this.
Already bought the Febi kit (febi part 08061) for it, that includes the boot itself, boot clips, a locking clip and the grease. BMW part number is: 33 21 9 067 815. However, on the Febi box it says replacement for 33 21 1 226 264 and I checked they're the same thing.
Not sure if I'll manage to squeeze this job into this year, depending on time and funds, but if not then will get it done early in 2014. Also the new sump gasket is sitting here in the room collecting dust, oil and filter need to be changed while I'm there, so there's plenty of things to do...
Back to work :)
zd3bx
Post Sun Dec 22, 2013 9:58 pm
December 22nd update:
Let's start with the good things! I recently clocked a magic mileage number (111111), although slightly missed it with 1 mile before taking a picture:
Moving on, just as I thought I was done doing "emergency" work on the car after changing the starter motor, the alternator started playing up.
It's been a bit noisy and squeeky on cold starts for a while, but it worked fine and didn't seem to give any problems, so I had no plans for it...
However, the other day coming back from work, the dash lights started to flicker slightly (parking brake, brake fluid and battery), the interior lightening became dimmed and thanks to you guys, I found out that it could well be a voltage regulator on the alternator, rather than the whole unit.
So I quickly ordered BERU one (part number 0 190 005 004), but after checking my alternator and realizing that it's got a plastic dust cover at the back, which meant changing the regulator wouldn't be a matter of removing just 2 screws - so I thought better replace the alternator and just be done with it :)
I decided to go for a re-conditioned Bosch one, rather than second hand, so got one from ECP for £150 (plus £80 surcharge).
Bosch part number is: 0 986 035 820 (that's 90A)
And I got myself a genuine BMW belt as well for only 10 quid (part number: 11 51 1 706 710)
Changed everything yesterday and now it's all running smooth with no issues :)
I guess that's all for 2013, so the first few jobs for 2014 will be the driveshaft gaitor, sump gasket and the steering.
Have a great Christmas and happy New Year to everyone!
Thanks all for your help and advice, I really appreciate it.
Sanchez
Post Sun Dec 22, 2013 10:07 pm
Have fun with the gaitor. Messy job.
appletree
Post Mon Dec 23, 2013 9:09 pm
Brilliant start to a thread and thanks for the pictures, everyone loves shiny new bits! :D
zd3bx
Post Sun Jan 26, 2014 10:46 am
January 26th update:
Hey guys, thanks for the comments.
Nothing really happened lately hence no updates, still gathering parts for the sump gasket change and all that...
Went to ECP yesterday and picked up Mobil 2000 Super 10w40 engine oil (5ltr), Bosch oil filter and front and rear PAGID brake pads with sensors.
Last time I serviced the car, I used Shell Helix HX7, so I thought I would try something different this time - I went for Mobil after seeing that 1 million miles commercial with an E30 featured there :D Have a look >
Also last week I received the Febi engine mounts (part number 06739, equivalent to BMW's 11 81 1 132 321) and a new sump plug with a washer.
Seems like I've got everything needed now for the sump gasket replacement, so hopefully I'll be able to take some pictures for you for the next update and get this job finally done - there should be no more oil leaks anywhere after this :)
Driveshaft gaitor still needs doing and of course my wobbly steering...
zd3bx
Post Sun Feb 09, 2014 7:28 pm
February 9th 2014 update :)
FINALLY, got the sump gasket changed, along with new engine mounts and all the oil filter/housing rings and gaskets.
Unfortunately, I don't have any pics of the actual job, as I took the car to a local garage, rather than doing it myself, but when I checked the car after for the job for any leaks, I took a few snaps.
A proper dry e30 sump...Something rare to see :D As you can see, the steering rack is pissing fluid all over the place, so that's one of the next few jobs I'll need to do.
Oil filter housing is all dry now as well. That cap where you have the oil thermometer is a common leak, so make sure to get the gasket kit from BMW when you decide to replace it (11 42 9 059 338)
Still haven't had the time to change the driveshaft boot, but I've got a feeling I've been delaying this job for a while now...Don't want to end up replacing the whole shaft lol, although the leak is very slow.
It's hard to believe, but I've almost sorted all the leaks around the engine bay area and underneath the car in general. Once the steering rack/pipes are done, there will be no more leaks left.
Need to order a new fuel pump and FPR as well, so possibly that will be the next update...
Stay tuned!
G-Bear
Post Mon Feb 10, 2014 10:20 am
Nice clean sump and oil filter housing :)
If you're changing your rack, it may be worth considering an E36 or E46 rack. The clubsport E46 rack (purple tag ending with part number 067) is the preferred weapon of choice, I think 3 turns lock to lock as opposed to the E30's rack of 4 turns.
Although, you'll need a few other bits..
Modified hoses (you can bend your existing hoses, but its a delicate process).
A linkage bar to replace the guibo bulky linkage, this is to clear the manifolds.
Both of the above are available from DanThe on here.
Aslo you need to mate E30 and E34 UJ's as the spline patterns varies between the newer rack and E30 steering column. More explained in the link below..
http://e30zone.net/e30zonewiki/index.php/Steering
In most cases people use Burton Ford Mexico engines mounts too, which raise the engine a touch for more clearance of the manifold, however I have found that mine have failed a touch so am trying to source something different.
Sounds like a lot, its not too bad ounce all digested. There's a bit more information in the wiki pages too. A good upgrade.
mcbonio
Post Mon Feb 10, 2014 11:51 am
Excellent work, nice to see someone doing important maintenance to get the car performing and feeling as it should instead of spending money on ridiculous wheels and eBay trinkets.
Ah the oil thermostat valve leak, I remember doing mine on my cab. I knew the pin was spring loaded but upon removing the snap ring it shot out and covered my hair with a coke cans worth of warm oil. LOL
G-Bear
Post Mon Feb 10, 2014 12:46 pm
Fortunately I was warned of this before I replaced that gasket. So I and a tray were strategically placed.
mcbonio
Post Mon Feb 10, 2014 5:14 pm
It's ok G-Bear, I caught the valve cap and spring with my forehead. :)
zd3bx
Post Tue Feb 11, 2014 8:35 pm
Thanks mcbonio, that's exactly what I'm doing atm - getting it mechanically perfect, before spending silly money on alloys and other things.
G-Bear, thanks for the suggestion re the rack, but indeed it does sound like a bit of work and to be honest I prefer to get things done to OEM standard, so most likely I'll be replacing the rack with a re-manufactured standard one, if I can find a decent make.
G-Bear
Post Tue Feb 11, 2014 9:38 pm
Make plan and stick to it.. I like it. :thumb:
I think you might be able to source a reconditioned OEM rack.. otherwise there's plenty in surplus amongst the fraggers on here..
zd3bx
Post Sun Mar 09, 2014 4:40 pm
Almost a month later, finally an update :)
Ordered the fuel pump and the fuel pressure regulator, got the VDO pump this week, so the weekend's job was to fit it.
Have to give credit to the thread I found on another forum for fitting the pump > http://www.bimmerforums.co.uk/forum/f92 ... mp-t26375/
I thought I would take a couple of pics myself while doing it, so it might help others...
You can buy the pump separate from the assembly, but I bought it complete, so this is what I got - the complete pump, the rubber o-ring and the bottom filter:
So to change the pump, first of all, you'll need to remove the rear bench, simply by pulling it upwards from the front on both sides, then just slide it forward.
Move the carpet away on the driver's side and you'll see the cover that hides the pump. There are 4 phillips screws holding it - on mine, one screw was missing, meaning someone's been there before me lol :D
Remove the cover and put it away. Now you're going to see this:
You've got 2 plugs here, one is for the pump itself and one is for the fuel sender. They simply pull out, so remove them both and try to keep them away from fuel.
Next I undid the jubilee clip of the hose that attaches to the metal fuel pipe and pulled out the hose.
BE CAREFUL at this point, as some fuel is going to spill out, so put a rag under the hose, so you won't make a mess there.
Now remove the four 8mm nuts that hold the fuel sender in. Careful, as they have washers as well. Then just pull up the sender from the assembly - same thing here, do it carefully, otherwise you'll have fuel pissing everywhere.
Finally, you can now remove the pump assembly. First twist it anti-clockwise to loosen it from its locked position and then start to slowly wiggle it/twist it left-right to remove it from the tank.
It will have to come out on an angle, because of the bottom filter, which is of a horizontal shape. DON'T FORCE the pump up, as the bottom filter could pop out and drop into the tank, so take your time here.
It's useful to remember the angle of how you took it out, so then re-fitting will be easy.
When you get it out, compare it to the new one and make sure they're identical - in my case, they were an exact match.
Now transfer the fuel hose from the old assembly to the new one and make sure to put it the same way or you'll have trouble re-connecting it with the fuel pipe.
Fit the bottom filter to the new assembly, making sure it's fully in, slip the o-ring from the bottom and bring it all the way to the top, as it sits between the tank and the assembly.
Now you're ready to put everything back in. By holding the assembly with the ring from the top, slowly put the pump back in, until it slides fully in. Then put the fuel sender back in as well, so you'll no longer need to worry about dropping anything into the tank...
The difficult part for me was to twist the assembly clockwise, so it would lock into place and allow me to re-connect the plugs. I tried doing it by hand until my fingers said "enough", so I put a flat screwdriver on the protruding edge of the assembly and with a slight tap of the hammer, I kept pushing it until it twisted perfectly to where it should be.
NOTE: While you're doing all this, put all the nuts/bolts away, so you don't accidentally drop anything into the tank. Pretty obvious, but I thought I would mention :)
Now tighten the nuts back on the sender, re-connect the fuel hose and the plugs, but before putting the cover back on, start the car and check for any leaks.
Once you've verified everything's ok and the car's running good, then put the black cover back on, pull the carpet in and re-fit the bench.
Still hasn't properly test-driven the car, but pretty sure this will solve all the random cut-outs and long cranking issues.
Went to BMW yesterday and ordered the vacuum hose for the FPR and some jubilee clips for the PAS pipes.
Already got the Bosch FPR from ECP, so once I get the hose, will replace the FPR and see what happens.
By the way, took the car to my local guy to replace the outer boot on the driveshaft and got told the grease is actually leaking from the joint itself, rather than the boot, so might end up replacing the whole driveshaft...Does this normally happen? Anyway, not good news.
OEM steering rack is still on the cards, so once all of the above is sorted, this is the next job.
Thanks for following :)
zd3bx
Post Mon Mar 24, 2014 12:11 am
After changing the fuel pump, I could definitely tell the difference - the engine worked smoother, wasn't hesitating on low revs and generally felt good.
The next job was the FPR (got it from ECP) and its vacuum hose (part no: 11 72 7 545 323).
Did it last weekend, but didn't have the time to upload the pics and post an update, so here it goes :)
Fresh new parts:
It's a genuine Bosch unit, exactly the same one as fitted on the car (Bosch part number 0 280 160 249).
Anyway, popped the bonnet and took off the pipe that connects the FPR to the inlet manifold. You can see how the end bit of it has perished:
Disconnected the fuel line attached to the FPR (be careful as some fuel will spill out), then undid the 2 bolts holding it in place and pulled the regulator out.
The plastic ring on the end of it fell apart in my hands and I could see the rubber ring was damaged as well.
Anyway, took the hose off the regulator and had a closer look at it and could easily see the massive split on it (wasn't so obvious when fitted).
That was definitely source of an air leak - probably minor, but little things still make a difference.
So then I carefully fitted the new regulator back in place, trying not force too hard on the rubber ring and the job was done!
By the way, the vacuum hose comes at a minimum length of 1m, so you'll have to cut it...
Started the car, checked for any fuel leaks and it was all good :)
The engine still sputters a bit on slight blips of throttle, so I would say it's an air related issue - probably a leak somewhere or maybe a dodgy AFM, yet it idles fine.
Now I think it's the time to finally sort my steering out...Got a couple of clips from BMW to replace the ones on the power steering pipes to stop the fluid leaking everywhere.
Need to get a steering rack and P/S fluid. Most likely will go for REMY one from ECP, as that seems like the best option.
Whatever happens, you'll be the first to know :)
MurphyE30
Post Sat Apr 12, 2014 6:09 pm
Excellent thread really enjoyed reading through this. A great approach to this project
Keep up the good work :)
BrianBimmerHead
Post Mon Apr 14, 2014 5:26 pm
Nice writes well done on all the work, go for the m-tech kit i think black 4 doors look sweet with it
zd3bx
Post Sun Jun 08, 2014 4:50 pm
Hey guys, sorry for no updates for a long time, was a bit busy in the past few months...
So the plan was to fit a new steering rack, but my outer balljoint on the driver's side started knocking quite badly lately, so I decided to replace the control arms, arb bushes, links, etc, before something serious happened...
After a bit of shopping around, here's what I purchased:
Lemforder front control arms (ECP)
TRW front ARB links (ECP)
FEBI control arm rear bushes with holders (Febi part numbers 21472 and 21473)
Genuine BMW front ARB bushes (31 35 1 129 139) with new holders (31 35 1 127 202)
BMW swing bracket that connects the ARB links to the control arms (31 35 1 127 263) - they often snap, so I thought it would be a good idea to get some new ones.
The arms, which were on the car, were genuine BMW, however I doubt they were the original ones and lasted 20+ years - most likely they were replace in the past, but were definitely knackered now.
Here's one troublemaker:
Outer ones, looking tired as well:
Getting the rear holders on the new arms was a bit of a PITA (use soap and a copper hammer). And also be careful, when tightening the bolts on the holders. I made a mistake of doing it with an impact gun and snapped 2 of them...Tighten them with a ratchet! Here are the old ones:
The state of the ARB links:
ARB bushes and holders, old vs new:
Links and bushes in place:
And the last 2 pics, where everything is pretty much in its place, just need to tighten it all:
By the way, try to use new nuts for the ball joints, which should be included with the control arms. However, if the old ones are in a good nick, then it shouldn't be a problem re-using them.
Overall, pretty easy job, if you've got a ramp and the right tools...lol, like with anything you do on the car :D
The steering has become noticeably lighter now and obviously no more knocking from the front when going over speed bumps. The excessive play in the steering is still there and the pipes are pissing too, so need to get that done, but keep leaving it for later...Possibly replacing the rubber guibo will do the trick, instead of getting a new rack? Will see.
I'm slowly getting there...Just a few things left to bring the car to a decent mechanical condition - the rear subframe/trailing arms bushes and links, new shocks/springs all around and a full exhaust system (with new heat shields) :)
Quite a bit of work, so hopefully will get more done later this summer/autumn.
Thanks for following!
