Think I'd rather fit a boot aeriel, roof ones mean drilling a hole in the roof!polsta wrote: are the roof ones much better, how do they attach ? would they have been around when tech 1 was new in 86 ?
quite urgent guys - ariel hole guide
Kedge
polsta
Duke137
The carpet hides the ariel unit I don't think it is a requirement personally but I bow down to Pacer and B7's superior knowledge
polsta
what woudl you say that is ? like 6 inches back or something ?
but- in them tech 1 pics, they all look around the same place ??
my is one was back a bit
DHFiS
Kedge wrote:Think I'd rather fit a boot aeriel, roof ones mean drilling a hole in the roof!polsta wrote: are the roof ones much better, how do they attach ? would they have been around when tech 1 was new in 86 ?
It's a Tech 1, it should not be difficult to make a hole in the roof
Thats exactly what you need Polsta. You need nothing else. Get the drill out.diable wrote:If a Tech 1 bootlid is the same as a Chromies cab then its 4"
Sorry its upside down I'm getting lazy![]()
But even then it's not central in the panel width proving theres no science in it. Few were I reckon.
I'd have measured mine but I ain't seen it for months!!! And before anyone chips in, my e30 not my c0ck!!!!
Biaaaatch!!pacerpete wrote:Kedge wrote:Think I'd rather fit a boot aeriel, roof ones mean drilling a hole in the roof!polsta wrote: are the roof ones much better, how do they attach ? would they have been around when tech 1 was new in 86 ?
that's a fine chariot Trev
have the Indigo leatherzzz seen any ar5e in the last year or is she still parked up ?
polsta
cheers mate !!!diable wrote:If a Tech 1 bootlid is the same as a Chromies cab then its 4"
so everyone- does that look about right ?
Good tip.
I have a pdf. file of the complete BMW fitting instructions for the radio aerial.
The correct position is 25mm from the inner edge of the boot opening, and 50mm back from the front edge of the boot opening. Hole diameter is 22mm.
Put masking tape on top of the wing for marking out and drilling, remove the tape, debur, and treat the bare metal with zinc paint.
- **BANNED**
Know the 'feeling' Trev,I have to work from memory these days,so often take a step back and end up with wet feet.....diable wrote:B7 wrote:I'd have measured mine but I ain't seen it for months!!! And before anyone chips in, my c0ck!!!! not my E30
Back on topic,just measured up my ariel position on the cabbie,with a ruler positioned as shown above,mine is two inches from the corner of the boot lid front edge....establishing Trev's POV that there is no 'correct' place,just an approximate position.
If I were in the OP's position,I would be following Pete's advice,frankly.
polsta
i dont quite understand that ? where would that be in relation to the one in the pic above ? (does that mean 50mml from the back corner so it would be more to the right in that pic ?Brianmoooore wrote:I have a pdf. file of the complete BMW fitting instructions for the radio aerial.
Still parked up matee30topless wrote:that's a fine chariot Trev
It is coming out though this year. I've been invited to this:
http://www.msaclassics.co.uk/springclassic/index.php
Turns out that the chief exec of International Motorsports Ltd is the husband of a good friend of my wifes. And he likes to see a cross section of stuff at the event, not all 246gt's and 911's. So when I asked if they were sure they didn't mind a young german wippernapper nipping at their heels he felt that was what was needed.
Take a right angle from the line of the side of the boot opening, and measure from where the right angle intersects the curved bit in the corner. About 3mm further forwards than diable has measured from.
polsta
still a bit lostBrianmoooore wrote:Take a right angle from the line of the side of the boot opening, and measure from where the right angle intersects the curved bit in the corner. About 3mm further forwards than diable has measured from.
- **BANNED**
Brian is suggesting that you measure from the boot opening,NOT the position of the bootlid,as is shown on the photo.
Woohoo!
According to Brian's measurements,my cabbie's ariel is spot on the factory's position!
Woohoo!
Youth is wasted on the young.
I'm not suggesting anything! These are BMW's official instructions used by their dealer monkeys, are incredibly detailed, leaving nothing that might require a bit of common sense.daimlerman wrote:Brian is suggesting that you measure from the boot opening,NOT the position of the bootlid,as is shown on the photo.
Woohoo!
FinalD
I've just measured mine:
Hope that helps give you an idea.
- **BANNED**
I bet Mr Moooooooooooooooooooooooooooooooooooooooooore get's a fantastic view from that high horse of his!
Kedge
daimlerman wrote:I bet Mr Moooooooooooooooooooooooooooooooooooooooooore get's a fantastic view from that high horse of his!
DHFiS
Kedge
If it's posted I'll happily add it to the wiki.diable wrote:Can you post the PDF up for reference and maybe it should be included in the WiKi for future discussion.Brianmoooore wrote:I have a pdf. file of the complete BMW fitting instructions for the radio aerial.
polsta
still a little confused, so according to brians dealer instructions, where exactly do i start measuring from and to where ? as im not cuttting i have to give him the instructions and a picture if pos would be a good idea
yellow line, green, blue, or the pink orange or red ?
are these in the same place or different ? which one/both are correct or not ?
gooner1
- Out humping Reindeer
polsta wrote:still a little confused, so according to brians dealer instructions, where exactly do i start measuring from and to where ?
Just fit the fecking thing will you.
polsta
or if this is correct and just to send him this picture ?? (thanks for the pics finalD)
- **BANNED**
Measure from the pink line.
FFS,it's come to something when we go to three pages just to position a bloody radio ariel...stick the bugger in the roof and get better reception and be pretty much vandal free!
