Project imposter
Demlotcrew
Post Mon Aug 06, 2012 1:37 pm
redcar
Post Mon Aug 06, 2012 1:38 pm
Is that Ti demlotcrew?
Demlotcrew
Post Mon Aug 06, 2012 1:39 pm
No.
Barx325i
Post Mon Aug 06, 2012 1:44 pm
still cool though :)
Demlotcrew
Post Mon Aug 06, 2012 1:51 pm
It would be easy enough to make in Ti, they would be heat treated and case hardened if I have them made.
Andrew
Hoobs
Post Mon Aug 06, 2012 1:56 pm
Liking that Andrew.
Bought new suspension, brakes & ARB's. (thanks to Andy @ Podium Prep)
The guys at Quest have done the 2 repairs to the front floorpans and work has started on the full cage. Decided to go with imola red on the inside & white on the outside.
Just waiting on a call from Martin to say the fiberglass M3 bumpers are ready. Just need to work out best way to mount them? Any suggestions guys?
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
redcar
Post Mon Aug 06, 2012 1:59 pm
Hmm...Nice coilovers. Have you used them on track before?
Hoobs
Post Mon Aug 06, 2012 2:03 pm
No, not personally, but have read good reviews of BC coilovers and priced well compared to alternatives. They appear to be better made than the more common alternatives too.
http://www.bc-racing.co.uk/c-bci07/bmw- ... -m3-82-94/
I'll continue using Hawk pads with the Wilwoods as I was really impressed with them.
2002
redcar
Post Mon Aug 06, 2012 2:23 pm
Will you be using the 6kg/6kg spring rates on track? Might be a bit too soft.
Although, i suppose the car will be ~900kg maybe?
MarkT
Post Mon Aug 06, 2012 8:06 pm
Demlotcrew wrote:By using one of these bolts through a rose joint :wink:
Andrew
Sexy! Where from? :D
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
Hoobs
Post Sat Aug 11, 2012 11:24 am
Andrew - can you fabricate these to sell or suggest someone maybe?
I've got pretty much everything when it comes to parts. The floorpan is repaired and work has started on the cage at www.questmotorsport.co.uk so it's all coming together.
Have decided to go with S54 power.
2002
Demlotcrew
Post Wed Mar 20, 2013 4:24 pm
Topic moved in here :)
