Pels Machine
Tondeur
Post Sat Jul 28, 2012 12:05 pm
pel wrote: Tondeur your a legend.
I know mate lol.
Sorry i can`t help myself mate you know that.
never have never will be able to leave motors alone.
And you are most welcome.
we really need to get that brake servo now.
once we have that ill fab up a manifold by the time thats done ill have the turbo rebuilt.
BATTS the only help ill need is advice on where best to plumb the oil and cooling in for the turbo.
Cheers chaps
Tondeur
I have good sources of new parts give me a shout if your stuck i may be able to help
pel
Post Sat Jul 28, 2012 12:42 pm
Yeah just looked on the wiki said a servo from a renault clio 2000 or later. should be easy to find mate.
leeparkes
Post Sat Jul 28, 2012 1:27 pm
Might be a reet bastid to fit though now the engine is in. :(
pel
Post Sat Jul 28, 2012 6:47 pm
Should be ok we're gonna take it all out for paint so we can fit it on the way back in.
Tondeur
Post Sat Jul 28, 2012 8:09 pm
leeparkes wrote:Might be a reet bastid to fit though now the engine is in. :(
Lee no problem
I`ve got a realy big hammer :D
Pel ill get one monday chap
Tondeur
Tondeur
Post Mon Jul 30, 2012 9:32 pm
Right i`ve got 5 mins so for future refrence a bit of a better update
During pels trip i managed to...
prop e36 325 front section 328 auto rear section new e30 center bearing and mount fitted backwards(unsure on balance we`ll see)
tidy`d wiring all uneeded e30 wire removed, M50 loom individualy soldered insulated and cased to look standard.
Bracket removed and air box fitted, for temp purposes
Alarm immobiliser removed
Rad repaired cowlings removed
Clutch bled and tested
Steering coloum refitted
Clio servo still to be sourced
turbo manifold still to be fabricated
turbo bearing need replacing
coolant and oil lines for turbo
exhaust system fabrication
Pics to follow
Tondeur
BATTS91
Post Fri Aug 17, 2012 5:15 pm
Any updates ?
pel
Post Tue Aug 21, 2012 11:19 pm
Sorry BATT the cars taken a back seat for a few weeks Tondeurs bought the house next door to the one he's already living in and the garage is coming down to make room for a bigger one across the two gardens, But soon as its up and finished we'll be back on it.
