You can fit complete E30 tie/track rod ends to the 46 rack. The stock E30 uses locking tabs onto the rack, but they won't fit the E46 rack. RealOEM shows no locking tabs at all on the 46 so it must just do without....
Make sure you don't reuse your old tie/track rods - replacing them alone will massively improve steering feel!
Rack Question
mwggriffiths
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
ross2009
That's good then I'll do that as I've just had a measure up e30 rod end are roughly 37mm dia e46 are about 39mm which may touch my disc as they are bloody close as they are
All my ends on my e30 rack are all new anyway well only done 3k miles so still new ish ;)
