Wiring M52 into c101
Post Thu Oct 01, 2015 1:26 pm
pm sent
Nick323
Post Thu Oct 01, 2015 1:41 pm
I will have somebody drop their bosch DMS later today, as he claims it will work.
If it does, then fine.
I doub't it will as normally Siemens uses Airflow meters that change the current whilst Bosch changes the voltage on the signal.
Post Thu Oct 01, 2015 2:00 pm
It won't work, you will have to force the plug on as its different and your more likely to fry the ECU as the wiring is totally different
Nick323
Post Thu Oct 15, 2015 1:58 pm
Thanks for your advice :)
Luckily I found somebody in South Africa who could do the neccesary on the Siemens DME.
Hopefully I have it back by next week.
