Please Help! No spark...
Nay
Channel Island Crew
Channel Island Crew
Sat Apr 10, 2010 1:58 pm
the 50 amp bboot fuse, or something else?
Uni is killing the project.
Sat Apr 10, 2010 2:01 pm
daimlerman wrote:Are the plugs getting wet when you crank the engine?
Nay
Channel Island Crew
Channel Island Crew
Sat Apr 10, 2010 6:32 pm
found the ****ing problem!
The wire from the loom to the coil was gently resting on the exhaust, which melted through and was shorting the connection. was a very sly and subtle contact hidddn under the washer bottle.
Thank **** for that! :woohoo:
**BANNED**
Sat Apr 10, 2010 6:45 pm
Nay wrote:found the ****ing problem!
Well,at least it was a new fault,must remember that one!
For your interest,if you had confirmed that the plugs were getting wet(with petrol :mad: )it would have confirmed;
fuel pump
fuel pump relay
fuse 11
all funtioning as required....
Uncle Malcolm
Youth is wasted on the young.
Sat Apr 10, 2010 7:16 pm
fuel pump
fuel pump relay
fuse 11
Uncle Malcolm
And that the fault could only be the coil, the ECU or the wiring between them.
TOMMYSPANNER
Fri Apr 16, 2010 2:38 pm
small battery positive wire has 50 amp fuse hidden in loom it gives lots of trouble feeds ecu, coil fuel pump easy fix slit it open with a stanley knife and jumper the wire,bet it starts!
Fri Apr 16, 2010 5:49 pm
TOMMYSPANNER wrote:small battery positive wire has 50 amp fuse hidden in loom it gives lots of trouble feeds ecu, coil fuel pump easy fix slit it open with a stanley knife and jumper the wire,bet it starts!
Eh, this one's been sorted - and would have been sorted quicker if the tests requested had been done!
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 16, 2010 9:15 pm
I performed all tests as quick as possible. When your garage is a few miles away from your house it can take a while to bring back results!
TOMMYSPANNER
Sat Apr 17, 2010 1:39 am
hidden 50 amp fuse in small positive battery cable bet it starts first time good luck
