Overheating M20 :(
gafta
Sun Jan 10, 2010 4:13 pm
Morat wrote:Try bleeding it with the nose pointing gently uphill, it helps the bubbles filter out. You'll want your heater sliders over to the right as well as the temp set to hot while filling. How much coolant did you put in?
thanks for your response , I have poured in 3 and a half litres of coolant, , what I will do tomorrow is jack the front of the car and try again , I asked a friend who deals and breaks e30's , he said to remove one of the pipes coming out the bulk head (top one ) and put a water hose on the pipe and cycle the water , but isn't that pumping out all the Coolant I put in and replacing the rad with only water? Thanks again for all the posts , very usfull site, :)
Sun Jan 10, 2010 4:23 pm
Brianmoooore wrote:Take the top heater hose off, and push it back on when coolant comes out of both pipes.
If it needs a little assistance, pull the little overflow pipe from the coolant bottle back in from under the wing, take the cap off of the coolant bottle, place the free end of the overflow pipe in your mouth, your hand flat across the bottle neck, and blow.
scotttollan
Sun Jan 10, 2010 8:11 pm
could it no be air locked ?
bmw 320i e30
Sun Jan 10, 2010 8:14 pm
scotttollan wrote:could it no be air locked ?
yes.
gafta
Tue Jan 12, 2010 6:37 pm
Ok guys , I have now tryed to bleed the system again, still no hot air , I have removed the glove box and a closer look at the heater matrix unit ,there's a valve which is slightly leaking fluid (coolant) , now I have had the car running with the heaters on full , temp gauge in the middle , I had then disconected the plug from the valve , checked it with my test meter, and there Is no power going to the unit , I have checked the fuses they seem to b fine , there is also a fuse near the matrix unit ( inside the car) 2amp fuse which seems to be ok , dose any body know weather power should be going to that plug constanly? :-x
Tue Jan 12, 2010 7:41 pm
What are you under the glovebox for??
No, there should not be power at that plug, except when the temperature control is fully anticlockwise.
bodger
Tue Jan 12, 2010 8:01 pm
gafta
Tue Jan 12, 2010 9:10 pm
Thanks for your response Mr Moooore, will try that, don't understand why its being such a ball ache to do, i work on bmws for a living but never worked on a e30 before , this is my project that i have been doing for 11 months now, so guys i will post loads of pictures very soon, lets hope we have a good summer this year, Mr Moooore i see your a team member, thanks very much for you response. thanks all you guys for your help, luv this site.
Tue Jan 12, 2010 9:11 pm
Your kidding , Right?? 8O
gafta
Tue Jan 12, 2010 10:34 pm
Hello rav 335uk nice cab mate, no, not kidding , y?
Tue Jan 12, 2010 10:40 pm
gafta wrote:Hello rav 335uk nice cab mate, no, not kidding , y?
Cheers fella.
I ask because the E30 is one of the easiest BMW's to work on.
How long you been working on BMW's and do you work for BMW it self?
m_jermyn
Wed Jan 13, 2010 8:09 am
I had this problem, my car would get hot sitting in traffic but when I moved on it would go back to normal temp..... As advised I replaced the Viscous fan clutch to no avail...... Then one day the bloody thing went to the red and would not come down no matter what....
Turned out to be a blocked thermostat..
Mike
Nay
Channel Island Crew
Channel Island Crew
Thu Jan 14, 2010 4:34 pm
Thanks mate, although Cotswold are taking their time responding to my quote. May just call them...
I'm hoping mine is just the thermostat, but gonna check the rad as well.
Uni is killing the project.
gafta
Thu Jan 14, 2010 4:53 pm
Cheers fella.
I work at the body shop rav ( sytner ) , do the repairs on BMW and mini, been there 7 years nw , don't see e30 at all here , only worked on two ever since I started both m3's , love them absolute stunning ,
Thu Jan 14, 2010 4:58 pm
Ah, well there lies the answer then.
Well your in the right place for help, plenty on here to advise . :D
gafta
Thu Jan 14, 2010 5:05 pm
Rav335uk wrote:Ah, well there lies the answer then.
cheers rav , yea plenty of helpful ppl on here , gr8 stuff, do u go to the meet ups ? Seriously can't wait to get my convertible on the road ,
gafta
Thu Jan 14, 2010 5:06 pm
Most people on here do attend meets.
Where you from??
gafta
Thu Jan 14, 2010 8:08 pm
rav I'm from Smethwick bud, Do you know any good breakers? I'm after a soft top cheers
Thu Jan 14, 2010 8:15 pm
gafta wrote:rav I'm from Smethwick bud, Do you know any good breakers? I'm after a soft top cheers
There's Nigel on Green Lane iirc, behind the Magistrates Court of Toll house way.
Not sure if he has any E30 stuff though.
Or a place called "Don Hoods", who I had mine done from in Erdington. paid £450 for a new hood fitted, not sure how much he charges now.
You work at the body shop on toll house way then?
tomson
Fri Jan 15, 2010 1:14 am
gafta wrote:30mins of idoling, but the pipes dont seem to fill with water, the car was idoling for 40 mins
You need to rev the bugger, idle speeds arent fast enough, I usually go to 3K rpm on and off 8)
gafta
Fri Jan 15, 2010 4:21 am
cheers for your response , I have tryed that , still no good , I have bought a heater valve yesterday from BMW it self £117 new , as my old one was leaking water inside the car , so once I replace that will try again, thanks
gafta
Fri Jan 15, 2010 4:30 am
nigel, yea I know him , midland bm , he's alright sound bloke , he never has n e thing I want , there's also a guy called Jason from Shropshire , complete waste of time , can't seem to find n e one else that breaks e30's local, had to travel some distance to get bits and bobs , yea it's the new bodyshop on brades road oldbury ,that's been there for 2 and a half years now , if you ever need any thing doing just let me know mate , will try get some good discount for you, don hoods , never heard of them , you have the contact number ? Cheers
Fri Jan 15, 2010 8:08 am
Here you go mate.
http://www.donhoods.com/
PM me what parts you need. :D
gafta
Sat Jan 16, 2010 6:22 am
Cheers rav nice one :)
