Pics of my new 325i Motorsport convertible
goldysingh
Post Wed Aug 19, 2009 12:00 pm
ben9040 wrote:if the hood is sitting too high on the horseshoe then you will need to remove some of the shims where the hood frame is bolted to the car body. There are two bolts on the horizontal fixing at each side and one vertical bolt. The shims lift the hood from the car body, it is the horizontal ones that there are probably too many of. Does your electric roof work? I got the one on my motorsport sorted pretty easily once i got the new parts
Thanks for the advise, I removed some of the shims and it did make a difference, think I need to remove a few more..
The motor is busted on the car, think I will go the manual roof way and have the horseshoe open with the motor..
cheaper and less hassle as the motor's are forever breaking..
