Subwoofer box design for my cab (12")
Post Wed Dec 03, 2008 4:48 pm
sati
Post Wed Dec 03, 2008 5:18 pm
why is it every link you post is from ebay, lol and space them out please it helps!.
dont waste your money on any of these:
pyle - great for a paper weight
lanzar - not bad subs but over rated.
Vibe - not bad sub quite good design
Infinity - now your talking , installed many of the 12" version's and they can take a good beating. and with two of them wired in parrel, see image below.
you will have a perfect match with your amp:) 1ohm load and 750 rms go for it.
Post Wed Dec 03, 2008 5:20 pm
Sorry dude :o: , what can i say, i'm a ebayaholic :mad:
That infinity is 10" though, will it still sound good? Will the amp be able to handle 2 of these subs?
sati
Post Wed Dec 03, 2008 6:11 pm
yes they will sound just as good and as the box being ported it will be better as you have more cone are then a single 12" , your amp is rated at 750watts rms @ 1 ohms , the subs are rated at 350watts rms each that will be 700watts total so you will have 50watts of head room on the amp which is a good thing. so the answer to your question is : Yes it will run with ease:) i post up a graph showing the output level in there optimium box.
Post Wed Dec 03, 2008 7:20 pm
That's good to know :D . Don't want to have to buy another amp.
Infinity's it is then i reckon.
Car is going in tomorrow for wiring and hopefully by sunday will be completed :cool:
sati
Post Wed Dec 03, 2008 7:26 pm
are you saying its going to take 4days to wire the car up? , or 4days for everything
Post Wed Dec 03, 2008 7:50 pm
4 day's for everything, even i know it doesn't take more than a couple of hours for wiring :mad:
sati
Post Wed Dec 03, 2008 7:58 pm
here is the predicted output level in 3.4 cuft box tuned to 55hz at 1 meter away.
132.16 DB @ 58.55hz
http://i37.tinypic.com/200ablg.jpg
Post Wed Dec 03, 2008 8:11 pm
Is that good?
sati
Post Wed Dec 03, 2008 8:14 pm
lol , "a Jet engine at 100 feet or Gun Blast = 140dB" take a wild guess.
Post Wed Dec 03, 2008 8:19 pm
Lol, should be loud enough i guess :mad:
sati
Post Wed Dec 03, 2008 8:38 pm
only if you had a even more powerful amp , you can just about fit 3x10" sub's....... lets not get carried away now. lol
i just cant wait till i can get my 2x15" dump them in my golf and have an easy 148db ,lol just like this video ,lol
check out the roof flex with the door wide open!
zaust
Zone day release
Post Thu Dec 04, 2008 10:01 am
sati wrote:yes they will sound just as good and as the box being ported it will be better as you have more cone are then a single 12" , your amp is rated at 750watts rms @ 1 ohms , the subs are rated at 350watts rms each that will be 700watts total so you will have 50watts of head room on the amp which is a good thing. so the answer to your question is : Yes it will run with ease:) i post up a graph showing the output level in there optimium box.
If they are 4 ohm sub's. Then doubled up they will be drawing a 2 ohm load. Not 1 at 750 watt's.
M30 Tech 1 Touring on gas.
Post Thu Dec 04, 2008 4:49 pm
Well the car has gone in today for the wiring and hopefully by Sunday the installation of everything will be complete :cool:
Can't wait :D
Rial_e30
Post Thu Dec 04, 2008 4:52 pm
I can't understand why is takes so long. I got my TV, wiring and sub and amp in half a day and by a professional aswell,
secondtimelucky
Post Thu Dec 04, 2008 4:54 pm
Zaust: they are dual 4 ohm per sub lol, so two DVC sub=4coils of 4ohm each= 1ohm overall (wired in paralell :wink: )
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
miniblob
Post Thu Dec 04, 2008 4:55 pm
Perhaps it is not they're only job???
Maybe they need to order in a couple of bits!!!
Maybe they are just a bit slow!! Lol!!!!
Good things come to those that wait!!!
327 Touring with bass!!!
secondtimelucky
Post Thu Dec 04, 2008 4:56 pm
miniblob wrote:Perhaps it is not they're only job???
PARDON??? :wink:
Post Thu Dec 04, 2008 4:57 pm
The guy who is doing the wiring will probably do it in about a couple of hours. The guy who is making the box and fitting can only start this on friday so that's why it going to take a bit longer. He can only work evenings as well so that doesn't help
Post Thu Dec 04, 2008 5:03 pm
The guy who is doing the wiring does this job full time, the guy who is making the box and port does this part time (he works at Costco also)
He will need to get some MDF, Carpet, and other bits and bobs as well
If they are then a good kick up the ar*se should sort that out :mad:
Certainly is, there is no rush :cool:
secondtimelucky
Post Thu Dec 04, 2008 5:09 pm
I retract my previous 'PARDON' lol
I think your gonna have a sweet system when its done mate
Post Thu Dec 04, 2008 10:03 pm
Thanks mate :D , i hope so, its costing me around £600 for the whole lot so i expect it to be sounding very sweet :cool:
sati
Post Fri Dec 05, 2008 3:07 pm
yep £600 is a lot for the job being done, try to keep on top of them , stick around while its getting done, so they cant slack off.
GrindCulture
Post Fri Dec 05, 2008 3:08 pm
secondtimelucky wrote:they are dual 4 ohm per sub lol, so two DVC sub=4coils of 4ohm each= 1ohm overall (wired in paralell :wink: )
PARDON!? winkeye
Not in E30s any more :(
sati
Post Fri Dec 05, 2008 3:11 pm
i guess you missed the picture showing how the subs will be wired up.
i know wat iam talking about "zaust", if you dont understand then iam happy to explain how this works if the picture is not clear.
sati
Post Fri Dec 05, 2008 3:13 pm
see if you can take pics while the system is getting done.
Post Fri Dec 05, 2008 3:28 pm
sati wrote:yep £600 is a lot for the job being done, try to keep on top of them , stick around while its getting done, so they cant slack off.
It is but Derby is expensive for things like this coz not many people can do it, so when you go to someone who can they charge top dollar. Well i only work 5 mins from their unit so i pop in every hour lol. I'll try to take some pics as well
sati
Post Fri Dec 05, 2008 6:45 pm
thats good , maybe sumone esel in your arae should open a shop doing the same but cheaper prices:)
Post Fri Dec 05, 2008 7:06 pm
I wish mate but no-one seams interested. We got Bass Junkies but they charge ridiculous prices. Also Car Electronics, they charged a guy £400 to fit one 8" sub in a e36 cab :eek: 8O
aceraf
Post Sat Dec 06, 2008 11:17 am
ImysE30 wrote:I wish mate but no-one seams interested. We got Bass Junkies but they charge ridiculous prices. Also Car Electronics, they charged a guy £400 to fit one 8" sub in a e36 cab :eek: 8O
Bass Junkies are a joke...really haven't got a clue what they're talking about...Car electronics know their shit, but are way too pricey.. I got quoted £800+ for the box i wanted in my sunny for the 4 15's, and that's without any covering/fibreglass finish to it either, and that was a very basic box...just big with 1 single port at the back firing into the back window!
They're the one's who did the install for Cavalier Mushy's system! But as he used them alot they did him a good price...but to be fair he was making paper back then with his import business so even if they did it expensive he would've still had it done!
Just no scope for it in derby though...the scene isn't big enough to make it worthwhile! Too many chavs out there who are happy to put MotorWorld crap in their cars!
Breaking 325i Touring
zaust
Zone day release
Post Sat Dec 06, 2008 12:28 pm
Sati I did glance the pic but did not take in the dual voic coil bit. My bad..
Although would not wire up the same as the pic, due to one sub drawing more power than the other.
Post Sat Dec 06, 2008 12:50 pm
Thats way too expensive, i didn't even bother going down for a quote. I've heard a couple of cars that they have done and for the money it cost them, the sound wasn't even that good.
I use them often, they did my Honda Civic for me so he did give a good price. If it wasn't for him then i would have tried to do it myself but i know i would have fooked it up somewhere :mad:
Tell me about it man, no-one hardly does car sound systems in derby, all the chavs either do it themselves who go to MotorWorld.
sati
Post Mon Dec 08, 2008 12:30 am
zaust wrote:Sati I did glance the pic but did not take in the dual voic coil bit. My bad..
no probs mate, pics can be rather slow sumtimes , both subs will get the same power from the amp , you cant wire it up any other way to get the 1 ohm load need to get the most out of the amp. but maybe iam wrong so can you explain why you think one will be more powerful then the other when both subs are the same.
my local motor world closed down the shop/stuff is still there but ist never open anymore. as they were cheap on car service parts and the cheapest sub the sold were the "splx" for £8 for 10" and like £12 for 12"
and they were really good for there price and not over rated (350peak on the 10") i still got a pair in a custom bandpass box (50 -70hz) and they still kick nice and lould
mrLEE30
Post Mon Dec 08, 2008 7:34 am
zaust in this application sati is right, you basically short out the inputs/outputs on the DVC making effectively a 2ohm load for each cone unit, wired both in parallel gives a 1 ohm load.
both subs will share the load equally and thus receive the same power (unless you count the voltage drop from one sub to the other - which will be negligable compared to differing internal resistance in the coils/heat generation etc etc)
although quite interesting i would be really interesting to know how much better all this is gonna sound compared to my original and much simpler box, as i am planning a fit out for my tin top i may do a side by side test, mu gut feeling is they will not sound much different when compared to the additional price and hassle.
good luck and please post some pics
mrlee
zaust
Zone day release
Post Mon Dec 08, 2008 8:54 am
Would need the power input's to be on the - on one sub and the + on the other, Or the first voice coil will take as much it want's before the other's. Yes negligable but still will happen. Unless physics has changed.. lol
