ChrisiS
Sat Nov 08, 2008 2:24 am
richard-the-nutter wrote:324td wrote:richard-the-nutter wrote:should have gone for the 2.5vm in my opinion much more suited and plenty fast enough, especially with a few tweeks and an intercooler
but you had the engine already so....
bin in a discovery that had the 2.5 its not a patch on this engine
the grunt and sound is awesome i love it.
no disco was fitted with the vm
only the rangie and it would blow the doors off tdi
Your right, no disco was fitted with the VM, and the rangie was only for a very short period of time....Reason being in standard trim the 2.5 wasn't such a good engine as the Tdi- whilst being a little more refined they didnt tend to be as strong either. They also lacked the torque of the Tdi. A decent Tdi out of a disco when tweeked isnt too bad at all- I ran one for just over a year and wound the turbo, and the pump out a little ant to be fair to it, it performed really well. Having driven both my disco and a VM (2.5) rangie offroad I would tend to agree with the general consensus that the Tdi was more torquey, and more flexible through the rev range.
Wouldve thought that sticking the lump out of a 525Tds would be the way to go for E30 diesel power...... But if you can squeeze that lump in it should be Mightily impressive!!!! If not I have a mate with a RR Bobtail looking for an engine!!!!!
Chris
ric325i
Sat Nov 08, 2008 10:33 pm
what a great project!
may i just say you are a nut job. not a performance engine etc bla bla bla its just a lump you had around and an e30 so stick them together
free fuel so crack on. i like crazy ideas like this
lets have a few pics of this cause i wanna see how this big lump fits
that cossie is the nuts too!
336tdse
Sat Nov 08, 2008 11:28 pm
il take more pics as the major components come together. ordered an adjustable fuel pressure reg today im gonna try use existing in tank fuel pump and just set reg to 5 psi for diesel pump feed
so far i cant see any reason it wont go in and work. hopefully have the engine in for a dummy run again with gearbox fitted next week and then mark the sump up for oil pan relocation then hopefully the 3rd time engine goes in it will fit properly and i can make engine mounts
thanks for the comments guys, it should be the only 336 tds in the country id of thought
336tdse on Sat Nov 08, 2008 11:30 pm, edited 1 time in total.
Sat Nov 08, 2008 11:29 pm
in the world prehaps
Sat Nov 08, 2008 11:44 pm
Only 160kg heavier than an M30B35, or more than twice the weight of an M20B25 then - should make for interesting handling...
Wacky creations like this are cool though - best of luck
336tdse
Sun Nov 09, 2008 2:45 am
Speedtouch wrote:Only 160kg heavier than an M30B35, or more than twice the weight of an M20B25 then - should make for interesting handling...
book says 380 kg for the engine but tbh it doesnt seem that heavy. heads are alloy. maybe theres some extra gubins involved when its a boat engine that increase the weight ? worst case senario i may need some different front shocks and springs and with a couple of psi more boost and an intercooler should see 170 hp 250 lb ft easy enough if needed. i think these engines are set up very conservative as in a boat its a constant pull and much harder work than turning wheels on a little old e30
i have a local r/r that i will tweek it on when its finished.
Sun Nov 09, 2008 12:36 pm
What will it rev to, or is it the sort of sloggy torque-monster where you just leave it in 5th gear?
336tdse
Sun Nov 09, 2008 12:43 pm
Speedtouch wrote:What will it rev to, or is it the sort of sloggy torque-monster where you just leave it in 5th gear?
max revs are 4200 rpm 150 hp and 2400 rpm 300 nm torque. and thats with no intercooler. the e36 325 td is 115 hp then the 325 tds is 143 bhp and only difference is slightly bigger turbo and a intercooler so 180 hp should be easily achievable.
336tdse
Sun Nov 09, 2008 12:45 pm
just done speed calculator with the getrag box, 205 50 16s and a e36 325 tds 2.56 crownwheel and pinion at 4200 rpm speeds are 1st 30 mph, 2nd 56 mph, 3rd 85 mph, 4th 113 mph and 5th 142 mph. that should be pretty good gearing to use the low end grunt i reckon.
Sun Nov 09, 2008 12:50 pm
324td wrote:ive cut the crossmember out between headlights and the lower part so engine will go in easy
What will stop the front chassis legs from splaying apart, or did you leave the bottom section in place?
336tdse
Sun Nov 09, 2008 4:10 pm
Speedtouch wrote:324td wrote:ive cut the crossmember out between headlights and the lower part so engine will go in easy
top and bottom sections removed, ive bolted a beam on where the bumper mounts
Sun Nov 09, 2008 6:45 pm
Good thinking, I like the idea of an engine you can just push in and pull out with an unboltable front crossmember - saves alot of awkward juggling
336tdse
Mon Nov 10, 2008 6:15 pm
picked the flywheels and adapter up today, bit of fettling and drilled new mount holes on bmw flywheel and its on fits perfect
just waiting on reducer bush now for gearbox input shaft. got some 4mm plate aswell to make adapter for between bellhousings to fill the gaps in. engine with no sump and gearbox on properly should be in again for dummy run 2 hopefully friday
- Homo Hair
Mon Nov 10, 2008 6:20 pm
I hope you will be having this flywheel 'arrangement' will be being balanced with all this drilling etc going on
336tdse
Mon Nov 10, 2008 7:02 pm
Jhonno wrote:I hope you will be having this flywheel 'arrangement' will be being balanced with all this drilling etc going on
its 4 holes drilled dead opposite dead square so shouldnt make any difference. and all machining has been done perfectly square on a mill and lave.
336tdse
336tdse
Tue Nov 11, 2008 7:09 pm
Alex wrote:looking good
cheers mate. fingers crossed its gonna work
gonna get flywheel balanced its cheap enough so best for peace of mind. im glad someone mentioned it else i wouldnt of thought
town325i
Tue Nov 11, 2008 7:21 pm
erm i might of missed something but where is the starter going to go and how will you start the engine?
336tdse
Tue Nov 11, 2008 8:50 pm
town325i wrote:erm i might of missed something but where is the starter going to go and how will you start the engine?
starter sits below exhaust manifold. needs a tiny bit taking out of gearbox bellhousing to fit. i cant do that till gearbox is fully mounted
vinni
Tue Nov 11, 2008 9:09 pm
Nice to see something differant being done. Good luck with it mate
town325i
Tue Nov 11, 2008 9:31 pm
i think your raving mad but it will be good to see how it goes together very different
GrindCulture
Tue Nov 11, 2008 9:34 pm
town325i wrote:i think your raving mad but it will be good to see how it goes together very different
+1
Total lunatic but it's awesome to see someone trying something totally different and off the wall. I wanna see how this motor sits in the bay.
Not in E30s any more
336tdse
Tue Nov 11, 2008 11:01 pm
cheers guys hopefully have some pics of engine suspended in the bay by saturday. fingers crossed i can get it in there
town325i
Tue Nov 11, 2008 11:08 pm
324td wrote:cheers guys hopefully have some pics of engine suspended in the bay by saturday. fingers crossed i can get it in there
nothing a very big hammer wont sort im sure
336tdse
Wed Nov 12, 2008 7:10 pm
struggled tonight
ive got box as square as i can for input shaft to be inline and put 2 pins in to act as dowels. got 1 bolt at the top and one to the left. need to figure out how to mount the bottom tmrw evening. if i figure that out tmrw and get sump oil pan cut off friday engine should be in again saturday. will know for sure then if it will fit. i need a bit of luck now
DRIFTBOY
Wed Nov 12, 2008 10:21 pm
This is fantastic, proper Scrapheap Challenge stuff!
I love it, good luck to you!
336tdse
Thu Nov 13, 2008 12:29 pm
DanThe wrote:I hope those 4 bolts aren't 8.8's
using the original bolts from vm engine
same as old auto v8 range rover
336tdse
Thu Nov 13, 2008 6:22 pm
gearbox is mounted enough to try engine in the bay. got the sump off and got me bit of luck
with a piston down big end cap is an inch above the face of the block where the sump bolts to. so if i have clearance issues above the crossmember i can have a flat piece of plate for a sump to clear it
and pan will move forward easy as its all universal
BigBavarian
Thu Nov 13, 2008 6:36 pm
Making good progress, looking forward to see it in the engine bay.
Richard
336tdse
Fri Nov 14, 2008 12:23 pm
diff just arrived from a e36 325 tds 2.56 ratio. hopeing to use crownwheel and pinion in my diff for gearing to a theoretical 142 mph flat out
336tdse
Fri Nov 14, 2008 12:24 pm
BigBavarian wrote:Making good progress, looking forward to see it in the engine bay.
should have a pic for you tmrw mate
