Lhd faster than Rhd
oze30
Wed Jul 23, 2008 10:27 pm
Linkages have slop over time. You should see the linkages I've got in the garage! sloppy as fook!
dannyboy759
Wed Jul 23, 2008 10:28 pm
You're an above average driver then?
Lol Were going down that road, Take it with a pinch of salt mate!
tomson
Wed Jul 23, 2008 10:31 pm
oze30 wrote:Linkages have slop over time. You should see the linkages I've got in the garage! sloppy as fook!
Yeah I appreciate that, its not what I meant though.
reggid
Thu Jul 24, 2008 3:53 am
Demlotcrew wrote: 1. Brakes - using a E34 connection rod makes a RHD car have the same brake feel as a LHD FACT
Do you have the part number of the said part that will fit an E30 325i? This is the worse aspect of my RHD car IMO....the brake feel.
Andyboy
Alpina Colada
Thu Jul 24, 2008 8:50 am
I've had a couple of LHD regular E30's (the last being a 320i) and it didn't go any better than a RHD car and I don't recall the brakes being better in a 'Wow! These brakes are so much better!" kind of way. The rack to use is the Z3 unit which is better even than the E36 rack.
To improve the brake feel of a RHD E30, I just wind the cross bar out a few turns to raise the brake pedal 30mm. Job done. I think the E34 rod is thicker?
I would still prefer an original LHD M3 over a RHD car for three reasons. 1.) Resale value 2.) I find the dogleg box much easier to use 3.) It's part of the specialness of an M3.
I have seen an M3 in the US where some enterprising soul put the internals from a dogleg M3 gearbox into a standard H pattern 265 casing (early 528i, 635CSi and the US M3) to have a conventional H pattern gearchange and the closer ratios.
JungleGus
Thu Jul 24, 2008 10:20 am
Hi Demlot
Could you please please please let us know some more info on this? I have not heard of this!
Gus
Demlotcrew
Thu Jul 24, 2008 10:28 am
JungleGus wrote:
Hi Demlot
Gus
The rod is basically thicker than the e30 one and as a result doesn’t deflect no where near as much.
Andrew
oze30
Thu Jul 24, 2008 10:56 am
then what? All moving parts will wear out over time, having the MC on the otehr side means more moving parts.
The E36 upwards had the MC/Servo on the same side as the driver to eliminate this. (They were also designed as handed cars, not predominatley LHD, then RHD as an after thought.
JungleGus
Thu Jul 24, 2008 12:42 pm
do the connecting links that thread into the booster and pedal need to be changed?
only problem is its a bitch of a job!!
any E34 forums around I can spam for wrecked ones?
oze30
Thu Jul 24, 2008 9:46 pm
JungleGus wrote:do the connecting links that thread into the booster and pedal need to be changed?
Just hope that it's not an AC car! I had to drop the pedal box slightly, undo the pins/clevis' and through bolt on the drivers side, then the same on the passenger side. Once that's done, you can kinda pull the rod from right to left, but you'll bend to bend it abit (I had to -AC car) and it will come out the passenger door. Bit fiddly, but doable. Reversing it is harder as the e34 rod is less bendy!
town325i
Fri Jul 25, 2008 10:01 am
a couple of years ago i had a 325i 4door that i thought was ok for the money i paid for it it had done 200k this was to be used as my every day car and then i bought a car the another 325i 4door same sort of money same sort of miles to break and that was shite slow compared to my every day car and they where both rhd
