My M30 conversion
Bristol_Jer
Post Sat Nov 19, 2011 7:20 pm
Ok nice one cheers :) I forgot until the other day that I still have the LSD that I bought off of you to fit!
Is yours still running well mate?
leeparkes
Post Sun Nov 20, 2011 11:41 am
In a way i wish id kept that LSD, seems to lock up better than the one i have now. :( sometime next year it will be sent off to Gareth for a freshen up plus i have a 3.38 crown & pinion to drop in. :)
Yes mines running fine now apart from an annoying blow in the exhaust.
Bristol_Jer
Post Sun Nov 20, 2011 5:42 pm
Nice, hopefully that might help with your traction issues with the lower diff ratio!
Got the new CPS and blue temp sensor fitted now, not checked clearance of the CPS to trigger wheel yet though as it was getting too dark! And yes, feeding the CPS wire upto the socket isn't the most enjoyable job I've done on the car!
How do you adjust the clearance, as it is just the allen key headed bolt that you do up isn't it? Do you have to shim it, or can you adjust the distance on the part that bolts to the block?
leeparkes
Post Sun Nov 20, 2011 9:33 pm
Yes undo the allen bolt (5mm i think) then it will slide up and down on the mount.
Bristol_Jer
Post Mon Nov 21, 2011 8:45 pm
CPS, blue temp sensor and spare coil now fitted......
And it runs again! :woohoo:
It fired up straight away, idle still isn't right though. It holds at roughly 1200 rpm for a second or 2, then drops down to about 600 ish and then picks upto 1200 again for a second, and then drops, and so on. Should I still be checking for more air leaks (have replaced a few hoses with new ones already) or would this be an issue with the ICV? I have cleaned the ICV out a month or so ago and is nice and clean inside.
Post Mon Nov 21, 2011 8:52 pm
Sounds like an air leak
Bristol_Jer
Post Mon Nov 21, 2011 9:18 pm
Yep thought as much! Time to get spraying hoses with carb cleaner to find out where the leak is! I've already replaced all the hoses that looked split and that made it run better, but obviously still not right
johnl320
Post Mon Nov 21, 2011 9:22 pm
Car needs a good drive for the ecu to sort itself out. If its just fired up and sat there then I wouldn't panic too much about the idle
johnl320
Post Mon Nov 21, 2011 9:23 pm
Glad you got it going :cool:
Bristol_Jer
Post Mon Nov 21, 2011 9:48 pm
Thanks, glad it's going too! Yes the car has only been started and run for short periods of time, not driven with the new engine in. I'll have another check for air leaks and then take it for a drive, can't wait!
Post Mon Nov 21, 2011 10:26 pm
Ecu needs about 15 mins on idle, then go for a drive, that's what I was told when I put my chip in the old M20
leeparkes
Post Mon Nov 21, 2011 10:38 pm
It should still idle pretty steady even if the ECU has been stood for ages.
If its idling that bad introduce an air leak and see what happens, ie take the filler cap off.
What does it do if you unplug the ICV? Does the ICV 'buzz with the ignition on? (ill repost what the resistance should be between the three terminals.)
Is the TPS set correctly and butterfly shut tight?
Glad to hear its fired up btw. :)
leeparkes
Post Mon Nov 21, 2011 10:54 pm
leeparkes wrote:(ill repost what the resistance should be between the three terminals.)
Between the two outer terminals it should be 40 ohms, from outer to centre terminal you should get 20 ohms.
Does it smell like its running rich?
Bristol_Jer
Post Tue Nov 22, 2011 10:49 pm
Thanks for all the info Lee :)
ICV buzzes when igntion is turned on and it doesn't smell like its running rich, no smoke or anything from the exhaust and the TPS seems to be set up properly. Should get a chance to test the ICV resistance values tomorrow evening
rix313
Post Fri Nov 25, 2011 12:32 am
Good stuff dude, looking forward to seeing more!
Bristol_Jer
Post Fri Nov 25, 2011 10:00 pm
Thanks Rich :) Need to get some more progress photos sorted out soon, haven't taken any for a while!
Bristol_Jer
Post Wed Nov 30, 2011 8:19 pm
Had an hour doing a few things on the car tonight, found the small vacuum hose from the FPR to the inlet manifold is badly perished where it goes under the manifold, hoping this is the cause of my air leak! BMW-fans lists the hose as 3,5X1,8, guessing the 3.5 is the internal diameter of the hose?
Also trying to tidy the ECU wiring where is passes around the top of the clutch pedal. How have other people covered the wiring to stop it rubbing on the top of the pedal when it is pressed down? I was thinking some of that corrougated plastic conduit type stuff like plumbers use around copper pipes, not sure if this would be too bulky though. Insulation tape or loom wrap would wear through in no time I reckon.
Also I've ordered a set of 280mm front brakes with 4 pot calipers from Keri (WMS) :cool: Cost more than I paid for the car but I'm sure they will be worth every penny with the heavy old lump under the bonnet!
leeparkes
Post Wed Nov 30, 2011 10:48 pm
Bristol_Jer wrote:Also trying to tidy the ECU wiring where is passes around the top of the clutch pedal. How have other people covered the wiring to stop it rubbing on the top of the pedal when it is pressed down? I was thinking some of that corrougated plastic conduit type stuff like plumbers use around copper pipes, not sure if this would be too bulky though. Insulation tape or loom wrap would wear through in no time I reckon.
It is tight but you can lengthen the loom a bit by unraveling (sp) the tape around it but you only gain about 2". First time round i used part of the big gromit on the end of the E34 loom where it goes into the ECU cubby hole, cut the small corrougated piece (about 4" long) and use that.
You can also move it up (or down) a bit so when you press the pedal it wont harm it.
Bristol_Jer
Post Fri Dec 02, 2011 7:46 pm
I've got all the tape off and the grommet has been cut off, I can fit the ECU fine in the standard position but was a bit worried about the clutch pedal rubbing through the wires.
Ordered some of this: http://www.ebay.co.uk/itm/5M-3mm-ID-4-3 ... 2a150fcd90
Got the vacuum hose ordered too, if it runs ok I will be booking MOT for middle of this month. How many times have I said that over the last couple of months lol?!
Post Fri Dec 02, 2011 8:01 pm
My ECU is facing backwards to my M20 one, and none of the wiring if anywhere near the pedals 8O :D
Bristol_Jer
Post Fri Dec 02, 2011 8:12 pm
Maybe it's another curse of the later wiring loom as my ECU is the opposite way too! :cry:
Post Fri Dec 02, 2011 8:17 pm
Just bolt it up with the plug facing towards the front of the car, it makes no difference anyway.
Bristol_Jer
Post Fri Dec 02, 2011 8:23 pm
Yeah thats what I've done, but the wiring rubs on the top of the clutch pedal when it is moved as it is tight against it. The loom stuff i've ordered should sort it I reckon :)
Post Fri Dec 02, 2011 8:29 pm
Have you threaded the wiring loom through the origional grommet??
Bristol_Jer
Post Sun Dec 04, 2011 5:27 pm
No grommet in there at the moment, but the wires go through the same hole. Im sure I'll have it sorted with that loom wrap stuff though :)
The new vacuum hose should be delivered Tuesday, that will be all vacuum hoses and intake rubber boots replaced. So close to finishing it now! :twisted:
Bristol_Jer
Post Fri Dec 09, 2011 8:27 pm
Received a 30th birthday present that I've given myself today winkeye
Vacuum hose only turned up today so I'll fit it over the weekend, I really hope that sorts the idle out!
leeparkes
Post Sun Dec 11, 2011 12:30 pm
Any news?
Those brakes look lush! :cool:
Bristol_Jer
Post Sun Dec 11, 2011 6:13 pm
No news, ended up working today and went to a mate's daughters christening yesterday which turned into an almighty p iss up! So no time to work on the car :(
Yeah, the brakes look spot-on cheers, can't wait to get them fitted!
leeparkes
Post Sun Dec 11, 2011 6:47 pm
Id choose a p1ss up over working on the car any day of the week. :)
Bristol_Jer
Post Sun Dec 11, 2011 6:50 pm
Me too! As much as I want to get the car done, yesterday was more important, especially as I am her godfather!
leeparkes
Post Sun Dec 11, 2011 6:51 pm
Bristol_Jer
Post Fri Dec 16, 2011 4:15 pm
Idle is still all over the place after changing the last remaining vacuum hose. Think I'm going to change the inlet manifold gaskets, and if that doesn't work I'm going to admit defeat and get it towed to my Dad's mates garage for them to sort :(
leeparkes
Post Fri Dec 16, 2011 4:52 pm
Before you start pulling the inlet mani off (which is a royal pita to do) spray carb cleaner or get a butane burner around the joints to see if its leaking, blank off the brake servo pipe too to rule that out.
Without going through your whole thread what parts are left to test?
Bristol_Jer
Post Fri Dec 16, 2011 7:08 pm
Yea I'll do the carb cleaner test first :)
So far on the inlet side of things I have changed the AFM-inlet manifold hose, all small vacuum hoses, servo hoses, ICV hose, breather hose, basically every hose lol!
leeparkes
Post Sat Dec 17, 2011 12:11 am
And TPS AFM and ICV in good order? Did you do a compression test? cant remember. :)
