S14 into RHD 325i into LHD 316i
Mikey_Boy
Post Sun Mar 06, 2016 6:02 pm
Time for another update”¦ :thumb:
When I was doing the dry build work, originally I fitted the fiberglass bonnet as this has served me very well in the past, but I really wanted a carbon bonnet on there to save an extra kilo or so, hence why I bought the item shown a few posts above..
I also wanted to ”˜tip my hat’ to some DTM stuff that looked nice and function well (more will be highlighted as we go through the final build) ”“ one of which is using the standard rear bonnet mounts with bonnet pins up front ”“ the carbon bonnet I ordered was the full factory copy with all the fixing points underneath ”“ rear mounts as you know look like this:
So after taking a brave pill, I thought about how I was going to drill some holes in a really nice carbon fibre bonnet.
The pins for the front were using the original pin locations I had decided upon for the fibreglass bonnet ”“ these were already welded into place (although quite a few I have seen are drilled and reinforced with body washers, which is also fine):
First up, I made sure that the wings were fitted somewhere near right and the rear mounts adjusted to give a decent panel gap all around the bonnet. Lots of masking tape later, the mocked up bonnet can rest on the pins so you know where to make the first cuts:
And these are marked like so:
Leaving you with something like this (my Dremel is definitely my friend at this stage!), which shows where the holes in the outer skin need to go and these are marked up:
Taking another brave pill and measuring everything again and again just to make sure I haven’t dropped a clanger, cut the smallest holes you can for the pins to poke through like this (you can just see the pins poking through):
Once this is done, there’s more measuring to be done ”“ this is to determine the position of the bonnet pin trims ”“ I like using lockable aerocatches as they come with a handy template to help:
I used 3 reference points on the bonnet to ensure that the catch is straight and symmetrical side to side ”“ note that my original red marks were incorrect in this picture so measuring lots of times really pays off.....!
Once that is done, you can attack the bonnet from the top again to cut out the minimum required for the catch as the fixing bolts are quite close to the edge:
But you’ll see that the reinforcements underneath also need to be trimmed back to allow access for the fixing plate and bolts:
All nice and tidy so now all that’s needed is to fit the catch itself:
And finally you end up with something like this, one of the final jobs before the car heads off for final prep and paint, which hopefully should be in a couple of weeks:
Plenty to get along with in the meantime! 8O
rix313
Post Mon Mar 07, 2016 7:49 pm
Ah it's always fun cutting large holes on expensive stuff 8)
Mikey_Boy
Post Fri Mar 11, 2016 5:57 pm
Whilst I am waiting for the car to go into the body shop, I've been thinking about the final spec of the car. I'm going to replace the rear screen and rear side windows with plastic, probably from Plastics for Performance.
I'm looking at the fronts and thinking they could do with replacing too, but I want to keep the window winders. Front windscreen will stay as a laminated glass item.
Question is for those who know better than me - how much of a job are the front door windows to remove and replace??
Any help is appreciated!! :thumb:
Post Sun Mar 13, 2016 2:28 pm
Can they do curved/scratch resistant plastic that really works Mike? Im a bit sceptical TBH and also like the wind down windows
rix313
Post Mon Mar 14, 2016 7:25 pm
Mine were from Mike Templar (Templar Performance). Appreciated the car hasn't done much but the windows have been in the car a couple of years and are in as new condition. They are 4mm thick hard coated. Heat formed side windows fit perfectly. Rear window is flat as once it's in the rubbers it takes it's own shape. Refitted mine today, defo buy one of these toys makes life so easy!
http://www.ebay.co.uk/itm/111745460135
Mikey_Boy
Post Tue Mar 15, 2016 8:38 am
Thanks guys :thumb:
I'm with you Dan on the scratching - If I do it I'm aiming on getting hard coated windows to try and minimise that problem.
I'm defo going to replace the rear 3 windows with plastic - I still want to keep the window winders so might end up just leaving the fronts as they are... The weight advantage is pretty small I think just on the front side windows?
Mikey_Boy
Post Mon May 09, 2016 6:52 pm
A quick update... :thumb:
After quite a bit of mucking around understanding where everything was going to go, the car is finally off for paint!! :cool:
I've agreed on a colour scheme with the chap who's doing the paint for me but I won't reveal the colours to be used just yet! There was a bit of remedial welding to do on the car, but after this and some minimal seam sealing, some primer was laid down underneath the car:
And some lightweight stone chip paint so the car can be driven in the rain without rusting as soon as it gets wet - the weight penalty should be tiny compared to OEM:
Making progress - the pics don't do the finish justice - a nice fresh underside is a lovely thing!! winkeye
goosiegander
Zonegoose
Post Mon May 16, 2016 1:36 pm
Updates? :)
Mikey_Boy
Post Fri May 20, 2016 7:53 pm
The interior, engine bay and boot paint is progressing nicely... :thumb:
Apologies for the orientation of the pictures - photobucket ain't playin' nice again! :?
Engine bay:
Interior and cage:
Boot:
Wheel arch (this is going to have a coat of the final body colour but just to give you an idea of the finish so far):
Very pleased with how things are turning out so far - can't wait to see the final body colour going on and starting the build proper! :D
Post Fri May 20, 2016 8:46 pm
Nice :D :D
AdamGardner
Post Fri May 20, 2016 9:08 pm
looking good
Mikey_Boy
Post Mon May 23, 2016 1:56 pm
Thanks guys!! :thumb:
I've gone with Ford Grey Matter on the inside of the car for a couple of reasons - White is great for Motorsport interiors but they get crudded up quick and look a bit pants if you aren't constantly cleaning them. The Ford grey is a flat colour so easy to touch up if it gets marked, plus all the interior bits should contrast nicely. Finally, the light grey is going to be a great compliment to the exterior colour... winkeye
Motorhole
Post Tue May 24, 2016 1:41 pm
Looking very tidy mate. Looking forward to seeing it in the flesh.
Mikey_Boy
Post Sun Jun 12, 2016 5:17 pm
After the interior had been painted, the chaps doing the job wanted to get the exterior apint sorted so that the shell could be shown at the Cholmondely Speed and Power weekend ”“ so, in for exterior prep (these shots were take on an iPhone so a bit naff):
Thankfully not too many nightmares found with this ”“ the last owner LOVED her roof rack so getting the dents out of the roof was a bit time consuming!
And finally in primer:
And after a few late nights, the guys at SP Automotive got the car ready for the show ”“ I saw it for the first time painted when I arrived and was really chuffed to see how the car has turned out:
I really like this detail:
This shows the contrast between the cage and exterior really nicely:
And a shameless plug for the guys at SP Automotive in Tattenhall in Cheshire :thumb:
I have a bit of a quandary though now ”“ the owner at SP likes the wheels the way they are but I’m thinking about going to a dark grey ”“ what do you reckon?
The rest of the work on the paint is going to start soon ”“ body kit, front bumper, bonnet and boot before she comes home for the final build ”“ can’t wait!!! :thumb:
