snapped lollipop bolt in chassis HELP!
Demlotcrew
Fri Feb 03, 2012 4:17 pm
To be honest, that will hold ok, i just cant leave you to drive around like that. If you have an off, its the first thing the Insurance assessor will pick up on. :wink:
Demlotcrew
Fri Feb 03, 2012 4:19 pm
BATTS91 wrote:the bush is the same other side mate and this is better ?
The bush is not correctly aligned, its not worn but its not designed to be loaded like that.
BATTS91
Fri Feb 03, 2012 4:20 pm
ok thanks ill do another 2 then i have smacked this with a hammer goes nowhere , the captive nut is fooked so i might drill straight through and nut and bolt it aswell if that makes people happy ?
Demlotcrew
Fri Feb 03, 2012 4:21 pm
Why is the captive nut damaged?
BATTS91
Fri Feb 03, 2012 4:27 pm
nope snapped off again so ok this didnt work granted bad idea !!!!
so next call will be drilling straight through and nut n bolt it ? or objections to that aswell then ?
Fri Feb 03, 2012 5:07 pm
It's probably worth drilling it using progressively larger drill bits until you're very close to the thread edge, then try and collapse the remainder of the bolt in on itself.
Perhaps use a junior hacksaw or padsaw/jigsaw blade to cut through the thin wall to the thread edge.
Jos
Fri Feb 03, 2012 5:14 pm
If it's cross threaded then trying to save the threads on the chassis side isn't really worth it. As speedtouch said small drill 1st, keep the speed down when drilling hard steels, if you can get coolant on it all the better. Work your way up the sizes. Don't try and go too fast or you'll just cook the drill bits.
'94 e36 tree climber
BATTS91
Fri Feb 03, 2012 5:56 pm
thank guys going to get a couple of new drill bits tomoz 5m 8m 10m and going to helicoil it as the captive nut is defo fooked oh and a new can of dw-40 lost the nozzle of mine lol
Nobby_N
Fri Feb 03, 2012 6:10 pm
Brianmoooore wrote:Please disregard the above post.
I've just looked back at the previous page!!!!!!!
Do we really have members this retarded?? Words fail me.
Best reply off the thread! Nearly really did piss myself, someone help this lad out before he hurts himself or someone else lol
GunnarJenson
Fri Feb 03, 2012 6:17 pm
An interesting read from a mechanical engineer's point of view, if this link works give it a read batts.
http://www.markthewelder.co.uk/id69.html
BATTS91
Fri Feb 03, 2012 6:34 pm
thanks buddy ill have a read , the thing is i had welded a nut on today and it sheared off again further into the hole :(
penton08
Fri Feb 03, 2012 8:07 pm
Normal drill bits will make a bad situation worse!! you need "Dormer" drill bits for a job like this, Start off small and work up to an 8mm (iirc) and tap the remains out. If you get it right you should not need to helicoil it. Be warned though, do NOT snap the drill bit in the hole!! If you could get the car to me i would sort it for you FOC in the interests of road safety.
Dezzy
CR24v it's a lifestyle
Fri Feb 03, 2012 8:20 pm
penton08 wrote:Normal drill bits will make a bad situation worse!! you need "Dormer" drill bits for a job like this, Start off small and work up to an 8mm (iirc) and tap the remains out. If you get it right you should not need to helicoil it. Be warned though, do NOT snap the drill bit in the hole!! If you could get the car to me i would sort it for you FOC in the interests of road safety.
Bat and Ball get your shed around to BBB asap!
Best offer your going to get!
BATTS91
Fri Feb 03, 2012 8:37 pm
thanks penton ill have a look around clacton in the morning for dormer drill bits whats the diffrence between that and a normal drill bit ? the strengh ? or the way they cut?
Duke137
Fri Feb 03, 2012 8:44 pm
Dormer is the manufacturer. Try your local Cromwell Tools. There is one in Basildon, don't know how far you are from them
kam-325i
Fri Feb 03, 2012 8:45 pm
Or Trubor.....
BATTS91
Fri Feb 03, 2012 9:03 pm
yea just had a google and realised after i asked im in clacton which is 60miles away and not driving at mo have to try around a few diy and car shops here cheers bud
Duke137
Fri Feb 03, 2012 9:05 pm
They are a bit more of an engineers tool rather than a B&Q special tbh mate
Clacton is miles from anywhere!
BATTS91
Fri Feb 03, 2012 9:51 pm
i know it is this place is a joke seriously haven't lived here long if not ill have to get the best i can find
VW-will
Sat Feb 04, 2012 12:51 am
Batts, if u can't get it out tomorrow, let me know... I'll get some new bolts, tap etctetc and come up next weekend think me n Kellyn rox was gona come up that way anyway :-)
BATTS91
Sat Feb 04, 2012 11:22 am
all i can get is 8 or 9mm colbolt drillbits or a whole set for £40 which i dont think has an 8.5 in it either :/
rhubarb
Sat Feb 04, 2012 12:56 pm
Scraps £120 a tonne at the moment :D
BATTS91
Sat Feb 04, 2012 2:31 pm
update ...............
BATTS91
Sat Feb 04, 2012 2:32 pm
just got to clean the shite up from welding :)
mattycoops43
Sat Feb 04, 2012 2:34 pm
You took the bracket off, and welded the head of a bolt on from behind? winkeye
Good call!
1990 325i se "weinrot"-How did they know?
Nobby_N
Sat Feb 04, 2012 2:37 pm
Finally the thread is done and we can all go back to our boring lives! welding bolt on from behind is a good touch lol
BATTS91
Sat Feb 04, 2012 2:54 pm
nahh no welding it this time i realise now that was never going to work managed to get a lift into colchester to get some tools clacton is shit drilled and tapped :)
Sat Feb 04, 2012 3:05 pm
Finally :woohoo:
Sat Feb 04, 2012 3:19 pm
Well done, looks like a nice job. Now get some paint on the chassis leg quick!
BATTS91
Sat Feb 04, 2012 4:16 pm
already done that with some schutz underseal and a brush :)
bodger
Sat Feb 04, 2012 6:15 pm
any pics of your car?
BATTS91
Sat Feb 04, 2012 6:34 pm
can get some up tomoz when its light if your that insterested lol
Dezzy
Sat Feb 04, 2012 8:45 pm
It only took 10 pages :eek:
redcar
Sat Feb 04, 2012 8:53 pm
Dezzy wrote:It only took 10 pages :eek:
winkeye
BATTS91
Sat Feb 04, 2012 10:24 pm
i know mainly bickering , and bout two pages of poss buying a welder lol i cnt believe it neither funny
