it's been up in the air the whole timeSimon13 wrote:horay, the tyres will be square by the time this is on the road!
B7's Next Installment. Rear End Action! SHE'S HOME!!!!
Tanks been drained and refurbed. No petrol in it, bone dry. Have 3 cans to fill up in the morning to get her going.The_Diddler wrote:Bloody hell, progress, need some fresh petrol Trevor, it may be stale due to old age
clarko74
That rear end looks fantastic Trev, if I get mine looking half as good as that I'll be more than happy.
Rear trim looks good imo, might try one on mine.
clarko74
Just got back from working on it all day. Not many photos but the end result was that I took it for a blast round the block to put some fuel in it. Drives very nice, feels very tight on the rear and the new Tech 1 wheel feels absoloutely spot on. LSD is lovely and quiet as well.
Feel it needs a wheel alignment though but the tyre pressures may be all over the place. It's not seen tarmac since Sept 09
First off, diff oil. Only the best for this baby:
Probably a bit TOO much OEM homosexuality here but f*ck it eh?? (truth is I got this free off a well known Zoner
next the fuel lines connected at the front. problem is, couldn't remember the flow and return
. A quick check at the rear to ID the pipe connected to the filter and under the bonnet to ID the hose directly to the fuel rail and voila, two fuel clips later AND??:
She lives again after 16 months!!!!!
With the brakes bled and the fuel flowing it was time for it to sit on its GSD2's again:
Heres how she sits after a spin round the block:
I then took the time to replace the auto shifter from one we broke a while ago. Mine had shit wiring loom so this was a nice end to the day.
And how I left her!!!
Cruise control next then MOT!!
Looks Lovely, just imagine when you drive though a puddle on the way to the mot garage
Beautiful looking car Trevor
Congrats on getting it back into running condition, it's had some lay up.
Dezzy
- CR24v it's a lifestyle
Mmmmmm lovely.
Did someone say MOT?
They did. Will need you to book it in Bazla as it ain't taxed or MOT'd. I'll then drive it straight to vines early in the morning (Sat if cane be arranged?) if thats ok? Let you know nearer the time????bss325i wrote:Did someone say MOT?
Royalratch
Early morning covert bredren MOT's yarr?
noice. working light on the selector shaft too? When is i be fitting the cruise innit? You'll love that for the m-way to shows if you don't chase Barry "120mph" Sheward
It was working before Si but was all wanked up.Simon13 wrote:noice. working light on the selector shaft too? When is i be fitting the cruise innit? You'll love that for the m-way to shows if you don't chase Barry "120mph" Sheward
When you're ready witht he cruise mate. The box of bits is all in the boot of it waiting. And yes, the speedo green adaptor is present
That hoon down to Gaydon the first year Barry and I went together was hilarious. I can't remembr the actual time it took but lets just say we were early
oguz327
- Captain Armco
Great work Trevor, looks stunning mate! Close now
Looks mint Trev
Wish I could be bothered to put mine away clean!
It's not been washed since 2009 DanDanThe wrote:Looks mint Trev![]()
It's covered in oily fingerprints and waxoil overspray. It needs totally detailing before it sees any shows etc.
tesco wax its only £1!
Simon13 wrote:tesco wax its only £1!
This came about when Si brought the C2 touring over for the arches to be TFR'd. We decided to see what could be done with the drivers side with a bit of elbow grease. Si asked what polish I used and we proceeded to discuss Meguires and Autoglym, pre cleaners and clay bars. I stated it was all b0ll0cks really and proceeded to pull out a bottle of (was it Tescos?) car wax which was in offer for a quid a bottle. It may have been Halfrauds own but bottom line was it was cheap shite. The difference was amazing and it has to be said, for a quid, even Si was astounded!
Have to add, I do NOT use it on this car!!! Well maybe under the bonnet and in the shuts
powelly
Looking good Trev, I reckon you should get some Zaino on there.
Le Mans Classic 2006-
powelly wrote:Looking good Trev, I reckon you should get some Zaino on there.
Hoorah!! She's back at my gaff!
Do appear to have an issue though. Under hard acceleration from standstill turning right I'm getting a nasty vibration from the offside rear (I think). Good as gold pulling out left and ok straight ahead. Only turning right
I'll need to get under it check it out. Drives a straight line as well. Maybe I've missed a bolt to tighten or something.
But at least shes back home
Awesome ! ready for some good weather summer cruising
might be a loose driveshaft bolt Trev?
Dezzy
Glad to here it. Chromie's FTW
It's gonna be something like that. Funnly enough, thats the side I had to keep dropping the beam on to get the rear arm in and also the side I dropped the bottom of the shock a few times as well. I'm sure I bolted it all up properly though. Must have missed onee30topless wrote:Awesome ! ready for some good weather summer cruising![]()
GC318
always thought you had a nut loose Trev
MOT time soon!
Yes pleasebss325i wrote:MOT time soon!
Must be nice to look forward to MOT's rather than dreading themB7 wrote:Yes pleasebss325i wrote:MOT time soon!
ah
B7,Your car just gets better and better.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Thanks guys.
Spent 5 mins under there this morning and everything appears tight and as it should be. Spoke to Si this evening and we agreed that as the vibration (tramping almost) happens when the weight is off that wheel, it could be Shock top mount. These I replaced about 4 years ago with genuine items and have probably covered no more than 2k miles.
This evening I was out there so i grabbed the rear arch on the passengers side and lifted and droped the car. Nothing! Did the same the drivers sdie (where I suspected the issue was) and??? Knock Knock Knock Knock!.
Being a 'vert, these are a piece of p1ss to check so quickly un latched the hood, lifted the rear hood and horseshoe, pulled the rubber covers out the way and? Shreds of rubber everywhere. Did the same pulling on the arch with my fingers under the top cup on the mount and theres bags of play in there. Passengers side also has rubber shards but no play. YET
So I'm hoping I've sussed it!
2 X E46 M3 (although it appears they are the same on all verts and Z4's) cab top mounts being ordered tomorrow.
Can anyone confirm the part number. I'm reading it as:
Part 33526779670 (Guide support) was found on the following vehicles:
E46: Details on E46
E46 318Ci Convertible, Europe
E46 320Cd Convertible, Europe
E46 320Ci Convertible, Europe
E46 323Ci Convertible, Europe
E46 325Ci Convertible, Europe
E46 330Cd Convertible, Europe
E46 330Ci Convertible, Europe
E46 M3 Convertible, Europe
E46 M3 Coupé, Europe
E46 M3 CSL Coupé, Europe
E85: Details on E85
E85 Z4 2.0i Roadster, Europe
E85 Z4 2.2i Roadster, Europe
E85 Z4 2.5i Roadster, Europe
E85 Z4 2.5si Roadster, Europe
E85 Z4 3.0i Roadster, Europe
E85 Z4 3.0si Roadster, Europe
E85 Z4 M3.2 Roadster, Europe
E86: Details on E86
E86 Z4 M3.2 Coupé, Europe
E46: Details on E46
E85: Details on E85
E86: Details on E86
E46 M3 Convertible, Europe - looks to be the same for all of them though!
Picked two up this morning. £38 the pair.Simon13 wrote:E46 M3 Convertible, Europe - looks to be the same for all of them though!
Will be fitted tomorrow all being good.
goosiegander
- Zonegoose
These are the top mounts that i chose for the moordoor,B7 wrote:Picked two up this morning. £38 the pair.Simon13 wrote:E46 M3 Convertible, Europe - looks to be the same for all of them though!
No issues whatsoever
I've probably put 60,000 miles on my set been on about 4 E30's now! they've done 70 laps of the ring too
winx
yeah but you don't drive as fast as TrevSimon13 wrote:I've probably put 60,000 miles on my set been on about 4 E30's now! they've done 70 laps of the ring too
I had the day off work last week so took the chance to fit the new E46 convertible top mounts on the rear and generally do a few other jobs.winx wrote:yeah but you don't drive as fast as TrevSimon13 wrote:I've probably put 60,000 miles on my set been on about 4 E30's now! they've done 70 laps of the ring too
The mounts I removed had indeed started to split but not horrifically. It seems to have cured the issue on a quick test drive round the block. Will need to get used to the LSD though. I was very close to laying the car up again with it requiring a new front end
I then spent the day prepping and painting a new cam cover, fitting the refurbed alternator and generally detailing the engine bay. I also fitted a pair of armrests that had zero wear or discolouring due to the fact they came out of an indigo interiored 60k 318i
All very HOMO but thats it! Just the cruise to fit and we are done!
Except a certain deviant will be having it on the ramp on Monday 14th at 2pm for an MOT. I'll post how he fairs it.......
