appletree wrote:is it all drivable now then Geoff? what do you think to her, as quick as you'd hoped?
As will always be the case Matt, I have a list of bits an pieces to fettle and fiddle with till the cows come home.
I replaced my locally manufactured AFR gauge last weekend with one made by Stack from the US. The local one is obviously microprocessor based and would simply freeze up (maybe it has windows as its OS
) at the most inoppor
tune moments. Piece of local crap
Likewise, I'll be a while fiddling with the suspension setup till I'm happy. For the time being she has no ARB's (front or rear) but these will be refitted (and enlarged if necessary) as dictated by any noted tendency towards oversteer or understeer. I still have to do skidpad (roundabout) tests to verify.
I also need to get her to the dyno for a proper tuning. I have been promising her this for months but have been unable to get there due to licensing issues with my new trailer (mostly down to the fact that the licensing authority has been on a strike for almost a month, and what must have been a substantial go-slow before that as my paperwork kept coming back unprocessed. It's one thing to sneak down the track (which is close by) along the back roads with an unlicensed trailer, it's another altogether to take an unlicensed trailer down the motorway to Johannesburg
In short, however, in her current state of tune she is living up to all expectations. I am particularly happy with the electronic boost controller I fitted, which works a real treat at controlling the turbo wastegate. Through the ECU I can specify how much boost I want at a given engine speed, and so long as the turbo is sufficiently spooled-up at that moment in time to deliver the demanded amount of boost, then that's the amount of boost I'll get. This system is incredibly useful at smoothing out that hectic transition from off-boost to on-boost that can cause a loss of traction while shifting gears on the track. While it is true that more torque results in better acceleration, it's only through the smooth application of that torque to the wheels that this acceleration can be physically realised. I remain convinced that it is not the sudden application of a large amount of torque that wins track events, but rather the smooth application of a necessary and sufficient amount of torque. This is why, despite the fact that I have a great love and fascination for turbocharged engines, I also have a great deal of respect and admiration for well-tuned normally aspirated engines.
Apologies for the long-winded answer Matt, I guess I just felt like writing something today
EDIT: For everyone intersted I'll post up the dynograph once I get her dyno'd, and acceleration times and cornering forces once I get my DAC installed in the car. It's the DAC data that always interests me since 600bhp on a hub-dyno means bugger all when you try to put it down to the ground through a set of bicycle tyres. Regardless of what my engine can deliver, it's how much of it my chassis, suspension and tyres can put to the ground that interests me, and how much of its "performance" it can sustain when forced to negotiate a corner.
