Where from, How much??dips346 wrote:yes got some cams at last![]()
V12 meets E30 Touring
stevetigger
dips346
- London Meets Main Man
2 recon ones at Ԛ£130stevetigger wrote:Where from, How much??dips346 wrote:yes got some cams at last![]()
aauser
Fantastic - that's a great price - very pleased for you mate, considering the scary prices being quoted
glenn
- Engine Transplant Services
got the cams delivered today from quarry motors,
so we can carry on rebuilding the motor tomorrow
on the weekend we finished modifying the bracket in side the cabin that holds/supports the master cylinder and relocated the heater pipes.
tonight we made a bracket that holds the power steering reservoir and asc valve
MaaasterBates
- Location: Outside the School gates with a bag of Werthers Originals
Top project - I love it. Hey Dips, there's a space in Total BMW for this when it's done Dude, we'll talk at the Ace next time I'm down.
Whilst the manifolds and cam covers are off, I can feel some satin black coming on, Alpina styleee. That'd look mint.
What are u going to do for a diff? Would the stock 325i big casing unit take the strain? I reckon one good donut would break it. After all, 5 litre V12 has got over twice the torque (332lb.ft against 160lb.ft) of the 2.5. The best option might be a 3.07 LSD from an E28 M535i (Pacerpete's got one). It bolts straight into an E30 rear subframe but the rear diff mount would need some fabricating. Also, the E30 diff flanges don't fit so you'd need to use E28 output shafts and CV's on modded E30 shafts.
How long before the engine is in the car and running? A month?
dips346
hi mate you know what havent even thougth about a diff or brakes yet but your info helps,also got a problem with the gearbox at the moment as it seems to be stuck in gear need to find someone that can fix it apart from that i would have thought couple more weeks it should fire up
at last fame and fortune tbmw feature again
dips346
quick update just paid £1000 for another 6 speed box
as the one had exploded gear and was stuck in gear and was not repairable,hopefully now in couple of weeks it will be done and should be able to drive the car
stevetigger
Costs are starting to mount up!
glenn
little update,
picked up dips new gearbox, all 6 gears are there, like silk!
cams are back in,
inlet manifold gaskets changed
new distributors / rotor arms
new spark plugs
been slow for last two weeks, waiting for the gearbox to be fixed, now replaced, we can crack on again now.
cams are back in,
new spark plugs
Toby_Unna
- Boost Junkie
glenn
thank's mate,Toby_Unna wrote:engine's looking lovely
just thought she should have some tlc while we were waiting on a box
GermanGorilla
Hi Glenn,
I think you are going to have major problems stopping the diff from ripping clean out of the rear subframe, and will more than likely encounter serious halfshaft problems with this engine/drive train.
Brakes, well there are ways to address those when the Car is running, but the Diff and half shafts will be a major headache.
On the rear diff, as there is no cage to bolt the diff to, I would seriously recommend that you weld some 'strengthing gussets' on top of the diff mounting holes in the rear sub frame, maybe some 6mm plate, and then increase the length of the diff mounting bolts by 6mm so as to keep the drive train level.
I would also use solid rear diff mounts not rubber ones.
This will help in stopping the Diff ripping clean out the sub frame.
I would also fabricate a second diff hanger for the offside, something to mirror the nearside, so that as the Torqe trys to twist the diff, it is supported on both sides.
On the half shafts, unless Dibs wants to pay for geniune DTM Half Shafts, around 750.00 each, if you can get them, Z3M Coupe rear trailing arms, half shafts, larger bearings and strengthend hubs, will fit straight in, and also fit a E30 LSD so long as you use the outer diff hubs from a E28 or E36 M3, 6 star type. This should be good for 350/375 BHP, and if you/Dibs can find a complete ZM3 Coupe rear end, then you will also upgrade the rear brakes at the same time.
There is a Guy on S14 at the moment, who has Supercharged his S14 engine, making 453 BHP, last year he sheared 8 half shafts and got feed up with being towed home.
This is a fantastic project, but increasing the volume is one thing, putting all that power to the asphalt, is another.
Hope this all helps in the grand scale of things.
Will call you soon Glenn.
Regards,
The Gorilla.
Regards,
The Gorilla.
burt
THAT IS OFF IT.... you are a truly talented man
WillG
so why doesnt a 9.8 sec 1/4 E30 rip its diff and half shafts out? surely it just gets to a point where wheels spin right, its not like they are even running a locked diff and drag tyres on this touring?, seen tonnes of vids of 400+ bhp on BMW shafts and diff giving it loads, wheel spins in 4th gear at 100 mph and never broke, ticco (500bhp) ragged the bollocks off his e30 and he broke the box first and fitted a e36 box then, yeah the 8 series box probly abit stronger but I cant see him ripping whole subframe off with 300 bhp?, if this is a drag car I might see the point but not on a touring road car.
e21Jason
Hi
e36 twin mountdiff covers fit the diff, so that coudl also give extra support, and i have a mate who makes custom drive shafts for motorsport inc lotus and aston, should be cheaper than the DTM stuff.
Jason
Jason
GermanGorilla
Mmmmmm,
I find it quite amusing how some people read something and then edit it, to dramatise it.
WillG- Not sure if you read my post correctly or not, but would you please edit to me the part where I mentioned that 300BHP would rip off the whole rear subframe please.
WillG- in life you will find that pro-active is much more advantageous than re-active, pro-active is using your brain, re-active is using your wallet.
WillG- why do you think that BMW thought it was a good idea to put dual diff mounting ears on the E36 Diff cover but not the E30 ?
So while I am always willing to accept that everbody is entitled to his or her opinion, and disagreement will always ensue, I can not accept somebody reading what I said and then 'implying' that I said something else.
Nothing personal WillG.
e21Jason- I should have remembered that the E36 diff rear Cover has dual mounting ears as I am in the process of using a similar set up for a E30 road car project that is now nearing completion.
Up-rated shafts will come into play once the power starts to increase in significant amounts.
Regards,
The Gorilla.
Regards,
The Gorilla.
WillG
Hey np germangorilla, I just had a few drinks and got excited, I see your point im pretty new to tuning BMW's anyway and just going on what ive seen and heard about and that is just old shafts breaking not diffs breaking off, havent seen people doing these mods either, would like to see it done tho, I said 300hp because thats what dips said he expected earlier in thread.
glenn
right, ok,
the engine and box is in for the final time, hopefully! (it's been in and out about 6 times, to make sure things were positioned correctly)
so we're now adding the ancilleries to the engine bay, and it's filling up quickly! there's not much room left on the nearside. when it's finished, it's going to look full!
now that this project is coming to an end, i think the engine bay is looking awesome!!
fuzzy
i take my hat of to you glenn for tackling something like this,certainly is a tight fit ,did you grease the sides of the engine with vaseline so it slipped in easier?
bigdek
how long before the first fire up ?
glenn
probably next weekendbigdek wrote:how long before the first fire up ?
Andy335Touring
Have you squeezed the E32 ECU box in to the engine bay ?
It might be just be the pictures but it looks like the engine is sloping down at the back ?
Kos
to be honest i think the dif mounting will need some strengthening, but shafts and actual diff will be ok, in my M3 dips and I abused the shit out of it, burn outs, doughnuts, lunching continusly and never had a prob with any tranny components, (almost 2 years before i took it off the road) and that packs out 315 bhp and 365lb of torque
glenn
i'll be calling you eagle-eyes-andyAndy335Touring wrote:![]()
yes andy, it's leaning back a little, as the gearbox mounting is still to be bolted up,
and yes, again, we managed to get the E32 ecu box into where the battery used to be
Andy335Touring
Cool
julianm40
TW166Y
this is the 1st time ive seen this thread..........
i know, i know.... where have i been
...Hat off to you glenn you have magical hands... wish i could have the knowledge to do something like that with my touring... thats gonna be awsome.. congrats with it all and well done. i can wait to see this car.
Saying goodbye to 4-pot wrongness
m-dtech
- Unapproved Trader caution
amazing, utter amazing
e21Jason
dips346
hmmm temption might ring them
dips346
any luck with my bits jason
e21Jason
Hi Dips
They have been on the kitchen table since last week, i'll sort it out tonight & post them tomorrow.
Jason
Jason
glenn
ok,
this baby is running!
got it fired up tonight, exhaust's not finished, so couldn't let it run for long.
just a couple of bits & pieces to finish it off and it'll be back with it's rightful owner next weekend.
ps,
then i can make a start on the next project i've been asked to do........
E30 with S38B38 power
ps,
Andy335Touring
She lives !
S38b38 nice !! Is it a Zoner ?
How many swaps have you got lined up mate ? May be you could have a new career if it takes off ?
Karan
looking great guys!!!
i think the transmission will be ok as long as u dont use 10inch wide slicks
Karan
Karan
