Twin Seq. Dry sumping for beginners :D
Turbo-Brown
Boost Junkie
Post Tue May 10, 2011 8:17 am
Woo hoo! Started welding things into the sump last night! :D
Started off by finding out exactly how high the pump needs to be using these conveniently sized brass bars. There are some little spacers under the bars just to bring them up a bit.
Next up is to take everything apart and jig it up for welding. Even more convenient than the brass bars was the fact that the mounting plate needed to be exactly 3" from the side of the sump, hence the big block of ali over in the back there.
Last job of the evening was to start making little arms to weld in place:
Where space allows, there will be full width bridging pieces spanning the sump.
The basic idea was to find the height of the pump, replicate that on the jig, then secure the mounting plate to the underside of the jig and weld it in place. Once it's all in, I'll skim the plate flat and any final adjustment of the pump will be done using shims.
Hopefully, more to follow from tonight!
Turbo-Brown
Boost Junkie
Post Tue May 10, 2011 9:21 pm
Gleee! We have minimal warpage! :D
Have finished off the lateral braces for the plate this evening:
And also knocked up a more substantial vertical brace. This runs over a main bearing cap so there's nothing moving too near to it :)
Next up is making the crank scraper and welding this in place. There are two clashes to resolve too where number 1 and 2 conrods hit the plate. No1 can be resolved by a simple pocket in the plate, No2 needs the middle of the plate to be removed so will have to reinforce it again.
Once all the welding's done, the plate will be skimmed flat and drilled and tapped to accept the pump :D
Post Tue May 10, 2011 10:21 pm
Nice nice, re the casting job, wouldnt you be better off with a small gas bottle? Loads about and they are made from steel rather than ally
Turbo-Brown
Boost Junkie
Post Wed Oct 12, 2011 1:54 pm
Well, still going! Moving house again soon, so that's taken priority, and once we're all moved in (assuming everything goes to plan with the move) there'll be DIY galore!
In the mean time, have been fiddling around with castings for the inlet system.
Wanted to reduce the size of the throttles (48mm is way too big for the M20 unless you're making serious N/A power!)
This was just a proof of pattern casting so it's rough, but things never work out how you expect (when you're a rank amateur like me anyway!)
So you start out with a pattern:
Mold it up:
You need something to make the hole through the middle:
And that's it!
There's a great big hole over the other side, the core needs modifying to give equal wall thicknesses all round :)
Next up, making the throttles and oil breather!
MotorKnyttet
Post Thu Oct 13, 2011 4:02 pm
Aaaaa! There You Are! :D Now me are very happy. :cool:
:wink:
// Tobbe
Post Thu Oct 13, 2011 5:57 pm
What, no pictures of fire and molten metals? :cry:
Turbo-Brown
Boost Junkie
Post Sat Dec 24, 2011 2:07 pm
Can ya tell what it is yet? :D
Still no house unfortunately!
Merry Christmas everybody! :D
Post Sun Dec 25, 2011 11:06 pm
Looks like a bit of old tree from here :D
Dezzy
CR24v it's a lifestyle
Post Tue Dec 27, 2011 9:33 pm
Wood turning is for the close to death!
Coyote_ar
Post Wed Dec 28, 2011 2:15 pm
nice throttle body core :)
MarkT
Post Sun Jul 08, 2012 9:03 pm
Update? :)
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
Turbo-Brown
Boost Junkie
Post Sun Jun 02, 2013 6:04 pm
It's been a very long time since I last got the chance to work on the car, DIY, marriage and changing jobs have all taken priority for a good couple of years.
However, two weeks ago, I threw my back with the consequence that I can't do anything other than sit.
"Not especially conducive to working on a car!" I hear you cry, but having some enforced thinking time has probably brought the project a couple of steps forward.
This is the third revision of my dry sump system.
A while back, the idea was to mount the pump in the sump, chain driven by the crank.
However, revisions 1 and 2 of my design ended up with the sump being no higher off the ground than standard so I had a bit of a re-think.
Then it occurred to me that the jackshaft could be pressganged into driving the pump, still using a chain.
This means that the sump pan itself can be extremely shallow, the pump is out of the way of rock, speed-bumps and road kill and still has a proper, robust drive system.
Will be making sure that the pump will clear the block properly and then sending drawings out this week, the idea being to have the tinware made by others, then weld it together myself. Machining will also pretty much have to be subbed now as I don't have the facilities I used to :(
Wish me luck!
maggspower
Turbo Farmer Tractor Driver
Post Sun Jun 02, 2013 6:11 pm
Jesus, Mary and Joseph, a blast from the past :D
Sorry to hear you have done your back in, but glad its put the car back on the agenda :thumb:
Turbo-Brown
Boost Junkie
Post Mon Jun 10, 2013 7:59 pm
Well, made some revisions to the oil pick-up areas so that they fill with oil quicker, and did some full size mock-ups to check everything will fit.
Drawings produced and have just sent them to all my favorite machine shops (all 9 of them!)
Believe it or not, there's 18 machined parts and 12 sheet metal parts to be made in there!
It's taken pretty much a full 40 hours to design and document all of that, although for once (for once on one of my own projects that is!) there's proper documentation and I've resisted the temptation to go "I'll sort that out as I go along". Benefits of the bad back I guess!
Wonder what the prices will come back like! :D
Turbo-Brown
Boost Junkie
Post Thu Jun 20, 2013 1:16 pm
Yikes, looking at around £1k for all 30 parts! :)
gareth
Post Thu Jun 20, 2013 10:51 pm
Ouch! 8O
Should have kept all of your small change the whole time you've been planning this, then the piggy bank could pay happily! :)
Top marks for persisting with it though :)
Post Thu Jun 20, 2013 10:55 pm
8O Welcome back.. :D
gareth
Post Thu Jun 20, 2013 11:04 pm
Not been gone Rav, just not been on here all day every day. :P Life gets in the way sometimes....! :D
Turbo-Brown
Boost Junkie
Post Fri Jun 21, 2013 1:49 pm
Funnily enough, I've an account which I pay £50 a month into. (set this account up, while drunk, as a student!)
Historically the amount in this account has, extremely conveniently, been enough to cover some expenditure on the car or whatever else has taken my fancy at the time.
Guess how much is in the account at the moment :D
Jimbob
Post Fri Jun 21, 2013 2:14 pm
£1,000? :)
Turbo-Brown
Boost Junkie
Post Tue Jun 25, 2013 1:53 pm
Bingo!
Just waiting to hear back on where I can save some costs (splitting orders and the like)
Looking hopeful for orders going out this week with sheets turning up in 7-10 working days! :D
rix313
Post Tue Jun 25, 2013 2:18 pm
I was thinking about this thread the other day and was wondering what happened, good to see you're back :D
Morat
Post Tue Jun 25, 2013 2:23 pm
It's like 2011 all over again!!!
Welcome back, I'm looking forward to more updates :D
Turbo-Brown
Boost Junkie
Post Mon Jul 22, 2013 1:33 pm
Woo hoo!
£430 spent so far, about £600 to go :D
Turbo-Brown
Boost Junkie
Post Wed Jul 31, 2013 1:38 pm
Picking up the first machined parts week after next! :D
goosiegander
Zonegoose
Post Wed Jul 31, 2013 2:42 pm
Turbo-Brown wrote:Picking up the first machined parts week after next! :D
YAY! Updates :D
appletree
Post Wed Jul 31, 2013 7:50 pm
Happy days! :cool:
Turbo-Brown
Boost Junkie
Post Sun Aug 11, 2013 6:15 pm
Yay! Been sent a piccy from a very kind forum member who's doing some of the sheet steel for me :D
appletree
Post Sun Aug 11, 2013 11:10 pm
Any pics of the car this engine will eventually end up in? And the condition of it at the minute or are you going to be searching for another shell/car?
Turbo-Brown
Boost Junkie
Post Mon Aug 12, 2013 2:31 pm
Here's the only pic I can find!
It's in a garage now though, and the quite pink paint you see here is now very faded!
Still plan to paint the fixed panels matt black and re-manufacture everything that unbolts in CF though :)
The shell itself is pretty sound, had new sills before I bought it, but the guy who replaced them said the rust was only cosmetic.....apparently! :lol:
Turbo-Brown
Boost Junkie
Post Wed Aug 21, 2013 2:23 pm
Woo!
Shiny bits! :D
Beautifully made by the good folk of March Precision Engineering, Aldershot :)
goosiegander
Zonegoose
Post Wed Aug 21, 2013 2:32 pm
Nice! :D
Crack on mister!
goosiegander
Zonegoose
Post Wed Aug 21, 2013 2:33 pm
You're not too far away from Kos, just get him to deoxidise the paint, you'll be surprised how well it'll polish up!
gareth
Post Wed Aug 28, 2013 7:18 pm
shiny bit porn! :cool:
Turbo-Brown
Boost Junkie
Post Sat Oct 19, 2013 11:38 pm
Woo! Have done some welding on the new sump :)
An extremely kind forum member profiled and folded these parts for me and they all fit together beautifully!
Got the crank scraper welded in, lots of clamping and very low current kept this flat :)
Uncovered a bit of a design flaw in that something got in the way of the crank turning, not an important part so it could be cut out!
