Your generosity is exceeded only by your personal beauty!Speedtouch wrote:Fair enough, I'll let you off lightly this time.
e34 525iX very sad day
- **BANNED**
Tell me about it!
well it appeared last friday the handbrake wouldn't adjust up on one side,
hmmmm, i swear it did have half a handbrake before i stripped it how but anyhow
euros got me one for £11 so not the end of the world but it was a bit of a pain to get the old one out rusty old shit
Nicely adjusted handbrake, these are a right twat becasue the disc drum or the offset on the ix means the adjustment wheel is about 100mm away for the hub so when tryting to see through the wheel nut hole with a torch to find the wheel is harder to spot even you know where it is! Note fruited interior with liberal splashings of optional extras, there are more out of eye sight in this shot.
Brand spankers new genuine wishbone off german ebay, old stock for 65 euros plus the post.
These are weird the outer ball joint is a normal steel one but there is a circle of rubber between it and the arm, a bit like e36 ball joints but not
So i think its ready for an MOT as far as my knowledge and "skillz" so its going in Monday for a test. i've insured it today
Place your bets pass or fail...........................................
I'm defo going to get a few tugs from the old bill in it
I've got another bloody leak, its coming in through this corner. The sunroof drain is unblocked so i'm a bit lost, anyone any ideas? My money is on that black lip attatched the sunroof panel in some way
I've still got that late M-tech wheel that was on my E34. It comes with the modified slip ring wiring and switch bracket to fit E34s with that wheel.
ok talk monies then mo, you want to sell it? So it works on air bag fitted cars like mine then? ie no bag light on?
It all works. I had it on my E34 and no air bag light. Late E34's with that standard 3 spoke steering had the same set up.
How about £70.
How about £70.
Mo i'll have it bro.
Its only gone and f**kin passed
A few advisorys, namely that the wheels look a but square, 3 have flat spots on the outer lip like they have hit a kerb etc. An anti roll bar drop link on the rear and slightly frayed stitching on the rear seatbelts.
I'll take all that, i've just taxed it so its off to work tomorrow see how i get on with it. In fact i'll go out for a spin tonight
It was last taxed in 2008! Not many of these old things come back from the dead eh but its one more thats gone back on the road not up the scrapper
Bring it down the Ace and we can check out the memory leatherzzz !
Jesus325iTouring
- Frog freak !
Well done Si, always a nice feeling to ressurrect an old heap
gooner1
- Out humping Reindeer
Fair play Si.
You get out of life exactly what you put into it.
I should of come to ace but couldn't be bothered! I'll smoke it about for a few months see how it gets on or something else tickles me fancy
jimbom30cab
- Tech 1 freak
Well done Si, respect !
Well done indeed. We are not worthy.
spook
- League two here we come !!!
No messing
Duke137
Well done for saving, you must be mad
i am mad, bloody mad and stupid its just dawned on me. Its a bit of a road block, the things revving high on the motorway 80mph is 3500RPM in 5th! I bet it would struggle to do 120. I've spoiled myself using the e36 as a daily
I've got a dodgey cruise control actuator, it sometimes when cruising pulls the throttle wide open when you accelerate with the stalk OR just by itself randomly. Which is interestings, luckily M50's quite happily bounce off the limiter until you can shut them off.
an M5 or bi turbo would of blown themselves to bits!!
I've took the pollent filters out as there was hardly any airflow from the fan, they were dated 98
no wonder there then
So what are you going to do with it?!
I struggled to get a pollen filter for my E34 last time round, the whole thing is a crap design with poor airflow for such a big car
well i've taken them out and i'll leave them out.
What am i going to do with it, i'm not sure, really i should sell it. Anyone interested?! I've done all the sh!t stuff
If you're going to sell then it needs smarting up.
The filler needs to go!
Pray for snow !
So the fun has started, last week it managed 2 days of daily use before it threw a challenge at me.
It took about 30 seconds of cranking to get it start when it was warm the other day. Car fully loaded at Howdens for my kitchen alterations. Got it going and home i went. Next morning it wouldn't fire up, just endless cranking like the night before but wouldn't go. Hmmm first thought was fuel pump as i couldn't hear a noise from it when cranking over. It wasn't the pump but the fuel pump relay had gone.
So i picked up a relay today and fitted it and now its running again, but with a weird kind of miss now and then on idle, and hunts a little or when driving it can do the same and its a momentary loss of power. I went for a spin earlier for 15 mins, cruising round its fine. Only seems to happen under load or at idle. I shall take it to work tomorrow and see what happens any brain waves
Theres not alot on these? Cam sensor or MAF going awol. I guess after 7 years off the road it was going to throw out a few curve balls
The ECU's on the M50's are very delicate now they are old, they can chuck their toys out the pram at any time.
Try disconnecting either the ECU or battery, leaving it for an hour or so to reset the ECU then let it idle for at least 10 minutes to enable base idle settings to be learnt. Switch off, then take it for a drive throughout the rev range.
Sorry, but this is -Speedtouch wrote:Try disconnecting either the ECU or battery, leaving it for an hour or so to reset the ECU then let it idle for at least 10 minutes to enable base idle settings to be learnt. Switch off, then take it for a drive throughout the rev range.
Worth a try, surely? It works with the M20 ECUs, and they use the same EPROM chip.
Aye, should work OK.
Andyboy
- Alpina Colada
Those 405 ECU's are gold dust. Sadly the 2.0 ones won't fit - they're Siemens, not Bosch ...... different plug innit.
why's that?
alpina123
If your car is single vanos it should have a 413 ecu
no its non vanos and the ECU is a 402 with a brown sticker
spook
The Lambda Sensors on the E34s share different plug connectors,either Seimans or Bosch.
I know it dont help ya mate just a thing we picked up after working on our lads car.
Jesus325iTouring
- Frog freak !
PYF!!! Legend!
