e46 M3s are getting cheaper
Post Mon Feb 17, 2014 10:09 pm
spook wrote:Is it true that if the car is under Ten years old it would still come with an anti corrosion/subframe warranty ?
Cars less than 10 years old will be covered for the axle carrier panel (boot floor/subframe) cracking.
Car's built before 1/1/04 have a 6 year anti corrosion warranty and 12 year warranty from 1/1/04 onward.
If you try to make a claim for corrosion and the car has had paint outside of a BMW approved body shop, any claim will be rejected.
Andyboy
Alpina Colada
Post Mon Feb 17, 2014 10:18 pm
Aah, that old get out clause. How many 10 year old cars have had paint, and how does that affect a rust through?
Post Mon Feb 17, 2014 10:19 pm
Exactly.
Laith
Post Tue Feb 18, 2014 1:23 am
Had an LSB e46 m3 subframe replaced at Stephen James in Bromley that had a bit of treatment on rear quarter panel rust. I would only take any suspension changes back to OEM if you find a crack under there.
ucpsale
Post Tue Feb 18, 2014 4:46 pm
H&H Auctions lot 25. E46 Alpina B3 3.3 / year: 2000. Could be a good investment.
spook
League two here we come !!!
Post Sun Mar 02, 2014 8:09 pm
Post Sun Mar 02, 2014 8:22 pm
A bit expensive for the age and mileage but not a bad spec and one of the best colour combos.
It's for sale at the same place as a zoners E30.
Post Sun Mar 02, 2014 9:15 pm
Heated seats really are a must.
Andyboy
Alpina Colada
Post Sun Mar 02, 2014 9:27 pm
spook wrote:What do we think of this?
http://www.autotrader.co.uk/classified/ ... ?logcode=p
That's really nice.
Post Sun Mar 02, 2014 9:32 pm
Blitz wrote:Heated seats really are a must.
+1.
I didnt even bother viewing cars without them but thats me personally.
jimbom30cab
Tech 1 freak
Post Sun Mar 02, 2014 10:37 pm
Can't agree more, mine have been on permanently since October now
spook
Post Sun Mar 02, 2014 11:39 pm
Is that a repair near the rear light cluster,or am i seeing things.
pony
Post Sun May 04, 2014 6:26 am
steve_k wrote:If pony see's that he'll go into fit's & it could get messy winkeye
Just seen this and things are about to get messy
pony
Post Sun May 04, 2014 6:35 am
bss325i wrote:Trust me, E46 M3's are very close to the point where perfectly usable examples will get fragged because its more economically viable to.
Thats where we were with E36 M3's only a couple of years ago and they're starting to get thin on the ground now.
I think is soooooooooooo sad when a nice M3 or any nice BMW gets fragged when it doesn't deserve such a life
You don't see Porsche 911s fragged or driven by council types or vermins even the old Porsche 911s
The only Porsches fragged or possibly driven by council types are the front engined Porsches or that mid engined Porsche/VW 917 (I think?)
pony
Post Sun May 04, 2014 6:40 am
bss325i wrote:
harry_p wrote:Yep, we're due a rapid thinning in numbers of e46 m3s very soon.
Already lots with nankangs and eBay tat being glued to them. People with that sort of budget / mind set won't stomach proper servicing or boot floor repairs.
If you want one, its a good time to try and seek out a decent one for sensible money and I doubt you'll ever lose anything. Although there are also a lot of dreamers out there asking too much for very average cars. Not sure where e92 m3s are these days, but can't be long before they're putting pressure on top end e46s
There certainly seems to be a split with E46 M3 owners. Non enthusiast types seem to be the ones who scrimp on running costs where as people that are into them seem to spend a bit more.
The M3 cutters forum has many members spending a lot on expensive modifications, easily adding up to the initial purchase price in some cases with things like AP brake kits, CSL style intakes, decent coilovers and other stuff along like top brand tyres. Obviously there are some people with ebay coiloverz and verdestien/nankang tyres but they are in the minority.
E9x M3's are into the high teens now. Winx sent me a link for an early E92 M3 manual that was up for £13k but had zero service history so that obviously reflected in the price.
For me give me a late low owner low mileage E46 M3 over early E92 M3 hands down everytime
Plus I have never ever had a late vehicle before always had an early prefacelift BMW so makes a nice change
pony
Post Sun May 04, 2014 6:44 am
Simon13 wrote:pretty quick, they're geared up pretty short though so the revs are up on motorway
I have taken on 2012 AM Vantage S Coupe and F355 Spider (dad and kid) on motorways and they were moving out of my way not the other way round and they were pulling away either
Academically looking at the stats they should be a bit faster (not massively just maybe half a second or tenths between gear changes etc)
They both sound nicer than the E46 M3 CS though and both handsome cars like the E46 M3 CS
pony
Post Sun May 04, 2014 6:48 am
bss325i wrote:
timmzey wrote:No-ones mentioned the fact that Headgaskets are prone around 120k... Garage where I took mine had done about 15 Headgaskets already!
Indeed they do go and in extreme cases can erode the cylinder head and/or piston or even in one very extreme case crack the block between the cylinders.
The head gasket failing is down to a couple of things, first of all the main cause is not being run on super unleaded, this a must!
If they are continuously run on normal 95 ron then the combustion temps are raised due to the leaner mixture and the weak point in the combustion chamber is the head gasket between the cylinder.
Once this is breached then if the car is continued to be driven, which often happens as the initial symptoms of the gasket going is a lumpy idle which surprisingly some people have thought is normal for an "performance engine" and pinking which most people dont even notice, then the other further piston/head/block damage can happen.
Quite often it wont even put on the EML light on.
Again, its another thing that can be prevented by not being a tight fisted owner running it on 95.
When buying one, its something you need to try and gauge, quite often in for sale ads it may say things along the lines of "always run on super", enthusiast cars tend to be and overall i would recommend buying a car off a forum member as there is a higher chance its been looked after, had money spent on it and in a lot of cases you can read a thread about the car.
I run mine on Shell V Power all the time
Only in emergency and I cannot find Shell will I use something else but I will go out of my way for Shell petrol
Also I keep all petrol receipts to prove I have used Shell and the few occasions I have not
pony
Post Sun May 04, 2014 6:54 am
bss325i wrote:E39 M5's are an even more expensive prospect to maintain and run. They also have more engine issues in old age.
I nice one is a great thing but most a rubbish and even the nice ones can swallow £2k with ease.
I would have to check but I have spent about £2.5k on servicing and maintenance on the E46 M3 CS since July 2012 and I have covered 3800 miles
2x Oil Services, M-Diff Oil, Manual Gearbox Oil, Air filter
1x Double VANOS Filter, Fuel filter, Coolant, Brake fluid, E46 M3 CS brake discs and pads all round
And £1800 at BMW Cotswold Group bodyshop getting a few things tidied up
And has been valeted several times 4 hours of labour per valet @£150 each
pony
Post Sun May 04, 2014 6:59 am
Laith wrote:It's nice to have don't get me wrong, its just really heavy. I noticed the difference in a car without one
I think is 15kg might be 45kg I can't remember
I am sure you can find out somewhere
pony
Post Sun May 04, 2014 7:01 am
spook wrote:Are the E46 M3s all the same? ie gearboxes/ engines.
Could shift a couple of turds and treat myself.
They didn't change that much thought the life cycle
http://www.bmwmregistry.com/model_faq.php?id=19
pony
Post Sun May 04, 2014 7:03 am
Blitz wrote:I've always preferred E46 M3s on 18" wheels. I quite dislike the popular 19s.
I have a 1:18 E46 M3 Coupe model in Imola Red / 18s Kyosho
And also 1:18 E46 M3 CS Interlagos Blue Kyosho
1:18 E46 M3 CSL SG Autoart
1:18 E46 M3 GTR Kyosho
1:18 E30 M3 Sport Evolution Jet Black Autoart I think
pony
Post Sun May 04, 2014 7:06 am
spook wrote:So 6k should find a nice car with decent spec ?
£6k will buy a poor example
You want to be spending between £10-15k or more
pony
Post Sun May 04, 2014 7:09 am
pacerpete wrote:SMG = don't . It's nasty when it works, it is REALLY nasty when it stops working :(
I have driven SMGII a lot as my old man had E46 M3 Coupe SMGII as company car from New
Is a fantastic gearbox
I sometimes wish I had SMGII but sometimes when I had SMGII I wish I had Manual
Just don't use Auto mode as doesn't replicate automatic well
Oh and launch control is very fun
Do it more than 4 times and the computer won't let you do any more without giving it a rest
Has launch control and burnout mode
pony
Post Sun May 04, 2014 7:12 am
pacerpete wrote:
£6k is a mine field. You may get lucky but most at this price will be a bit rubbish and will easily eat another £2k in tyres, brakes and an inspection 2.
THIS ! You may get lucky but most at this end of the market are ticking bombs. The serious performance for much cheapness attracts lotz of scum who when faced with big bills get them served on pronto. The ideal car will usually have a mature owner (dead cooont, think Trevor !) ) with lots of bills and four quality tyres.
What you really need Chris is a M3 CS , you would then be a serious ********* executive but more importantly,your new best mate Pony would send you regular updates on his throbbing grapes AND undraped pics of his nan AND access to his extensive PHIL COLLINS collection ! :D
LOL I have seen the word "executive" used a few times in the Zone what does that mean ????
And don't diss my Phil Collins!!!!
pony
Post Sun May 04, 2014 7:15 am
spook wrote:So how much should one pay for a good CS? :cool:
£15k plus
Get one
Everytime I drive I feel the journey was too short
And I always have to look back at it when I park it
That's how good it is
pony
Post Sun May 04, 2014 7:20 am
suchy wrote:
wait a few years Chris they will be fook all :D
if you really have to have an M3 then 6k will buy a very good E36 M3 or a poor E46, the E36 is going up and the E46 is going down.. no brainer really as they both drive really well :D
But how much more of a weapon is the E46 M3 over the E36 M3? I've driven neither so have no idea, but I'd be fairly confident in saying the E46 is a league ahead of the E36?
All the mags rate the E46 M3 over the E36 M3
E36 M3s nice ones starting to look cool now
E46 M3s had a big Yuppie/City boy image
Now have a bit of chavvy image with a lot of them being modded
pony
Post Sun May 04, 2014 7:31 am
pacerpete wrote:
bss325i wrote:
Blitz wrote: I like CSL's but not nailing all the bits on a standard M3. Lights and plate make it seem worse.
Thats it techno violet is the colour I mean.
Each to their own Mo but answer me this, E30 M3 sport evo spoilers?
Ah ,but Sport Evolution spoilers were fitted for homologation purposes, are functional and can be adjusted so that they are not in the Southall Ring 'max attack' mode and barely visible.
CSL 'aerodynamic' bitz were more likely to have been dictated by the marketing departments need to distinguish the much more expensive CSL from the ordinary M3s than a quest for superior aerodynamics.
The CSL aero bits actually contribute towards downforce / reduce lift on front and rear with a roughly even aero balance
There is info on the Internet somewhere
The M3 or M3 CSL don't contribute positive downforce overall ie is not sufficiently to competely cancel all the lift
pony
Post Sun May 04, 2014 7:33 am
bss325i wrote:Aaaaactually....... this is official from BMW, the CSL boot lid creates sufficient down force at speeds of 120+mph that if the front does not have the splitters which also create down force, it creates unbalanced characteristics.
Basically, if you fit the rear you need something up front.
RE Sport evo, every sport evo owner (generally pretentious cocks who think they have the crown jewels!) has their spoilers rampant in the Southall ring road position.
I thought all sport Evo owners were treated like Gods and kings especially so in the E30 world and the BMW world especially £80k for 30k mileage Sport Evolution!!!!
pony
Post Sun May 04, 2014 7:35 am
And who inSouthall can afford a sport Evo ????
I thought they like councilwd up BMWs
I got a mate from Birmingham he bought his E46 328Ci and councilwd it not long after I bought mine
Tinted windows
Facelift MV 18 alloys
Nasty Private number plate and worst with no BMW Dealer lettering!!!!
pony
Post Sun May 04, 2014 7:38 am
Indeed, as the values have ran away from lesser E30 M3 values, Sport Evolution buyers are increasingly a sad bunch , nearly, but not quite as sad as E46 CSL knobbers who are generally weapons grade up themselves tools :)
They can be pretentious on CSL Registry
I got a mate with CS
He got a ride in someone CSL from CSL Register as he was thinking of getting one
And he thought they were nice cars but overpriced
Mind you his CSL was a bit knackered at 80k mileage
My mate 's CS in Interlagos Blue is 50k and is basically a cream puff
pony
Post Sun May 04, 2014 7:43 am
Anti corrosion warranty
2001-2003 6 years
2004 onwards 12 years
pony
Post Sun May 04, 2014 7:47 am
pony
Post Sun May 04, 2014 7:48 am
ross_jsy
Post Sun May 04, 2014 5:35 pm
21 replies, see you went out and got a life in your absence pony :D
