big brake caliper brackets 750i 740i 540i £50 a pair pics
Enter a group buy or look here for zone discounts
beefy
Post Wed Mar 12, 2008 11:22 am
hi
Im hoping to get some of these brackets made up. The brackets will suit 750i/some 740i and e34 m5 calipers.
At the min there going to be mild steel cnc machined.
Not sure off price yet im just trying to gauge interest.
So if interested please form a list
E30 M30 Mounts £100 pm me for info.
DaveD
E30Zone Wiki Specialist
Post Wed Mar 12, 2008 11:25 am
to fit which discs under what size wheels :?:
buster
id use stainless steel.Im looking into making these myself at the moment using 304 stainless steel.
DRIFTBOY
Post Wed Mar 12, 2008 11:30 am
These are to fit Audi TT discs with the big BMW calipers.
I'm definately after a set if the price is right.
1 - Driftboy
2 -
beefy
Post Wed Mar 12, 2008 11:31 am
why stainless?
How about alu?
buster
Post Wed Mar 12, 2008 11:35 am
stainless for strength and lack of rust.Theres quite a lot of leverage on that braket.I wouldn't use aluminium as it maybe too soft,holes may elongate or just bend,although it is a strong material.Anyway,im looking into making these in stainless steel,at work on a cnc machine.
Anyone know the thickness of these ? 15 seems to ring a bell.
Andy325i
Post Wed Mar 12, 2008 11:41 am
Are these for E30 or E30 M3 cars guys? :D
Thanx
Andy
buster
Post Wed Mar 12, 2008 11:42 am
standard e30.
George_Of_The_Jungle
Post Wed Mar 12, 2008 11:54 am
could use some ali 7075, easier to machine than stainless.
beefy
Post Wed Mar 12, 2008 11:58 am
yeah alu would be alot easier to make them from.
Would that grade be strong enough?
Post Wed Mar 12, 2008 12:07 pm
its aero space grade!
Post Wed Mar 12, 2008 12:09 pm
but saying that, if there was ever an area on the car you dont want to fail, it would be the brakes. Anybody got the dimensions of the TT disc, and i will work out the forces.
ric325i
Post Wed Mar 12, 2008 12:19 pm
i know we had chats about this last night but will they fit under 16's?
im interested if the price is right. im sure the price is cheaper if more people say yes. would like them lots!!!
1 - Driftboy
2 - Ric325i (dep on price etc)
buster
Post Wed Mar 12, 2008 12:20 pm
George_Of_The_Jungle wrote:could use some ali 7075, easier to machine than stainless.
Yes generally i agree, but it makes no difference to me on such a small part.Also how expensive is the ali 7075 ? i bet more than 304 stainless.
beefy
Post Wed Mar 12, 2008 12:21 pm
what dimensions do you need is it just the diameter.
Post Wed Mar 12, 2008 12:29 pm
Actually will need the OD of the disc, and the dimensions of the pads in the 750 caliper.......
I would have thought stainless and 7075 would be fairly equally priced. For the quantity needed, there aint gonna be much difference in the price. I think if it was for track use only would deff go for ali, but on the roads, the weight isnt going to make much difference.
jaffro
Post Wed Mar 12, 2008 12:31 pm
would titanium be good for these :P
n1tr0_9
Post Wed Mar 12, 2008 12:34 pm
Might be a dumb question, but....presumably these metals expand due to heat and at different rates. Is this enough to give detrimental alignment effects?
Post Wed Mar 12, 2008 12:39 pm
yes they do deform with heat, and ali more so than steel. but the heat conducted into the brackets combined with their chunky dimensions. i doubt that deformation would occur.
Thinking about it, the ali could do with being anodised so an extra cost. yes. i now agree stainless is the way forward.
beefy
Post Wed Mar 12, 2008 12:44 pm
ill do them stainless then.
Andy325i
Post Wed Mar 12, 2008 1:15 pm
buster wrote:standard e30.
:cry:
beefy
Post Wed Mar 12, 2008 1:16 pm
304 stainless can be done but at the min can only buy the material in a 4meter length and it is quite expensive. This would make about 12 sets of these.
Andy335Touring
Post Wed Mar 12, 2008 5:30 pm
Stick me down for a set. Stainless would be nice so hope fully we can get some more people on board to make it viable.
1 - Driftboy
3 - Andy
beefy
Post Wed Mar 12, 2008 6:33 pm
Right an update
The brackets are for calipers from E32 750i/740i and e34 540i.
The discs which are needed are Audi TT 312mm available from gsf for about £33 each for vented or £47 each for X drilled.
The discs will need modifing, 4 holes at 100mm P.C.D, and 1mm from the bore to fit onto the hub.
The brackets will be made from 304 grade stainless steel.
Price of brackets should be £60-70 per as a guide. 300mm de sell these for £107 i believe.
If needed i could have the machining work done on the discs for an extra charge.
Id like at least 10 people to commit to this before i buy the material and make them.
This could equate to a big brake conversion for £130.
Please add and also state if you want me to sort the discs out aswell.
The list so far is;
1- Driftboy
3 - Andy
[/u][/b]
Andyboy
Alpina Colada
Post Wed Mar 12, 2008 6:45 pm
buster
Post Wed Mar 12, 2008 6:55 pm
I'll start my own thread me thinks.Should hopefully be able to do these approx £50 a pair though.
beefy
Post Wed Mar 12, 2008 7:17 pm
ok mate ill keep an eye out to see how you get on!
MickyDojoh
Post Wed Mar 12, 2008 9:31 pm
1- Driftboy
3 - Andy
4 - mickydojoh ( would want full kit)
beefy
Post Wed Mar 12, 2008 9:54 pm
micky i cant supply the calipers just. Only the brackets and discs.
MickyDojoh
Post Wed Mar 12, 2008 9:56 pm
yeah sorry that what im looking for.. meant i would want the discs machined too
beefy
Post Wed Mar 12, 2008 9:58 pm
ok dude.
Quaser
Post Wed Mar 12, 2008 10:03 pm
1- Driftboy
3 - Andy
5 - Quaser.....(how much for disc machining?)
Post Wed Mar 12, 2008 11:51 pm
when would all this need paying for???? after payday????
e30_singh
Post Thu Mar 13, 2008 12:14 am
1- Driftboy
3 - Andy
6 - e30_singh (brackets & TT drilled discs needed)
beefy
Post Thu Mar 13, 2008 8:35 am
about £15 per disc to be machined.
