need 10 or more people to get them at $175 (£85.81 depends on the exchange rate)
I dont know how much post will be yet.
Easy to fit.
Have alook here for more pic and info >> http://www.s14.net/forums/showthread.php?t=27009
If you dont want one that is fine
want one! But GRP would do me if this get's the price down.ed325i wrote:If you dont want one that is fine, if you do put your name down.
I will be fitting mine in a GRP single skin bonnet.agreen wrote:i need one which will be ok to fit into a grp bonnet do these >?
you need to take water under the bonnet serious. BMW does not recomment to jet wash your engine. The OEM plugs are not "that" water tight.MJG wrote:Looks good, should give the air coming through the radiator somewhere to go, depending on air pressure there. I'm sure the DTM e30's had a similar vent did they not? You shouldn't have to worry about water on the electrics really, unless you have no rubber boots over any of your plugs etc.
arron not a problem in your case as the m42 uses a coil pack away from that area anyway.
spot on! That's the way to go. I am not quite sure how bad the M3 will be in this case. I will play it by ear.Bob_S wrote:you ought to make a deflection plate that goes under the vent and directs the water away from the engine. Series 2 escorts and Fiesta RST's used to have this type of thing fitted in their bonnets under the ducts
PM sent.@ed325 are you just ordering these from he states, or do you actually get them made in the UK? If you order them from the states we need to talk...
That's an idea, if you can get them made cheaper i'll be up for one.UweM3 wrote:
I am going to put this on hold for now as there could be a uk supplier soon.
They will be GRP.
The vent is on order from the US and copies will be made in GRP
Posted: Sat Jan 19, 2008 4:17 am Post subject: Re: bonnet vent.
so they'll be little cheaper then i take id?
_________________
Have a read here >> http://e30m3performance.com/installs/in ... /index.htmagreen wrote:this is not on the side of the induction
so what benifit does this have dude![]()
or is it just cosmetic mate
*typo edited*
if you fit directly over a turbo put a plate underneath the vent on spacers to allow rain water to run away rather than hitting the turbo. the turbo hotside ends up very rusty and the steam coming from under the bonnet can be quite embarrasing.BadDave wrote:Any idea as to the actual dimensions of the finished product?
I'd be interested,but it would have to fit above the turbo( on the rhs of the bonnet instead of in the middle).
If it's too big, then there's no point in me getting one
OR if you can get ones similar to M3GTR ones i'd have them instead
