Condor Speed Shop parts
Enter a group buy or look here for zone discounts
HackEngineering
Post Wed Aug 05, 2015 12:27 pm
Hi all,
I'm pleased to announce that I am now the UK dealer for Condor Speed Shop products! The team there specialise in UHMW and other machined products for classic models, predominantly the E30 of course!
Right now I have a few bits in limited stock (first come first served), other parts listed at bottom of post.
UHMW Power Steering Delete (E30/E36/E46) - £29
This bolts onto any E30, E36/Z3 or E46/Z4 rack. Returns the purity of no power steering, while also allowing the correct flow-through to stop extra-heavy steering, leaks, seal blow-outs etc.
Drilled E30 door handles - £52/pair
Perfect for adding some cool hotrod flair to your E30. These are made from brand new door handles, sold as a pair and come with installation screws.
Engine Riser Kit (most BMW) - £52
Perfect for those of you that run low! This engine riser kit move the engine up 20mm, often enough to move the sump above other components to avoid smashing. Threads to the top of existing engine mounts, stud sometimes needs shortening.
Round Delrin Shifter Carrier Bushes - £29
Reduces gear lever slop by solidifying join between shifter carrier and gearbox. Well documented upgrade - oval versions also available and in stock.
Rear Delrin Shifter Carrier Bush - £14
Works best in conjunction with above carrier bushes to get rid of that annoying side to side sloppy play in your shifter.
All of the above are subject to a £5 postage charge and are in stock, ready to ship.
The following are also available, by pre-order only. Due to the delays this could mean, I am willing to offer a 10% discount on the shown prices. I will be placing the order for anything you guys want at the end of the month, and need payment before then.
Aluminium Power Steering Delete - £47
Solid Brake & Clutch Pedal Bushings - £20 (per pedal set)
Centred UHMW Control Arm Bushings - £70
Offset UHMW Control Arm Bushings - £70
Solid Rear Beam Bushes - £116
Solid Rear 12mm Beam Raising Bushes and Diff Spacers - £139
Solid Rear Trailing Arm Bushes - £116
Solid Rear Diff Bushing - £64
Solid M10 Engine Mounts - £104
Solid M20 Engine Mounts - £52
Solid M30 Engine Mounts - £52
Solid M40/M42 Engine Mounts - £116
Solid S14 Engine Mounts - £64
Solid 24V Swap Mounts - £116
Condor Weighted 'Shorty' Shifter - £110
Condor Weighted 'Tall' Shifter - £133
Other parts are available, just contact me for details!
Last edited by HackEngineering on Wed Aug 05, 2015 12:56 pm, edited 1 time in total.
steve_k
Post Wed Aug 05, 2015 12:52 pm
looks good, might be looking into the engine riser kit in a little while :D
HackEngineering
Post Wed Aug 05, 2015 12:56 pm
steve_k wrote:looks good, might be looking into the engine riser kit in a little while :D
Sounds great, just let me know. Pics now fixed :wink:
catuned
Post Sat Jul 09, 2016 7:04 am
A+ seller
