Anyone looking for an airbox needs to have a look at these before you make any other commitments.
2013 group buy for carbon intake systems (aka CF airbox), currently in progress, production ending Dec. 31, 2013.
These CF airboxes are hand made here in Germany. Applications range from "fast road" to race. The airboxes have been deployed on many different cars and run at tracks around the world, including the famous Nuerburgring Nordschleife.
Production of airboxes has begun and orders are being processed. The airboxes are shipping as they complete (in batches), so if your order is in early, you will receive your airbox earlier. Typical lead time from order to dispatch is approx. 2-3 weeks. The closing date for this group buy is Dec 31, 2013.
If you are interested in participating and wish to have your name on the list, please send an email with your details (name, shipping address, part, etc.) to: info@s14power.com
There are various carbon fiber airbox systems and air plenum intakes available. The airbox systems include snorkels and install kits where required. Some of the versions available:
- E30 M3 S14 DTM CF airbox for 46, 48, 49 or 50 mm throttle bodies
- E30 M3 S14 DTM CF airbox for S38 50 mm throttle body conversion
- E30 M3 S14 DTM 8-injector CF airbox ('92 type with bottom mount injectors)
- E30 M3 S14 CF replica plenum (weighs just 1.5 lbs)
- 2002 M2 S14 CF airbox
- E92 M3 S65 (for stock engine management)
- E60 M5 S85 (for stock engine management)
- E46 M3 S54 CF airbox (for Alpha N type engine management, 120 mm or 200 mm snorkel inlet)
- E46 M3 S54 CF airbox (race version with central kidney intake)
- E46 M3 S54 MAF CF airbox (for stock engine management, 120 mm snorkel inlet)
- E36 M3 S50 CF airbox (for Alpha N type engine management)
- E36 M3 S50 MAF CF airbox (for stock engine management)
- E34 M5 S38 CF airbox (for Alpha N type engine management)
- E34 M5 S38 MAF CF airbox (for stock engine management)
CF Replica Plenum S14 : 620
CF Airbox S14 46/18 with CF snorkel and install kit : 1145
CF Airbox S14 48/18 with CF snorkel and install kit : 1145
CF Airbox S14 49/18 with CF snorkel and install kit : 1189
CF Airbox S14 50/18 with CF snorkel and install kit : 1189
CF Airbox S14 50/18 (S38 TB) with CF snorkel and install kit: 1277
CF Airbox S14 8-injector version with CF snorkel and install kit:
CF Airbox S14 2002tii 46-50/18 with install kit : 1036
CF Air Filter Housing for S14 (optional) : 150
CF Airbox installation kit only : 150
CF Airbox S50 : 1250
CF Airbox S50 MAF : 1320
CF Airbox S54 / 200 mm CF snorkel (internal filter) : 1525
CF Airbox S54 / 120 mm CF snorkel (internal filter) : 1525
CSL airfilter : 135
CF Airbox S54 / 120 mm CF snorkel (external filter) : 1525
CF Airbox S54 MAF / 120 mm CF snorkel : 1613
CF Airbox S54 race with CF central intake snorkel : 1870
CF Airbox S54 version II race with CF central intake snorkel : inquire
CF Airbox S65 (E92) : 1495
CF Airbox S85 (E60) : 2150
Maxx Alpha N V2.0 with WBO2 closed loop: 705
TE WBO2 kit with WBO sensor LX1 remote display: 370
Chip for S14 motronic: inquire (engine configuration dependent)
Note: Schrick cams and other Schrick valve train parts available.
Inquire for package deals which include Schrick parts and Maxx Alpha N.
ECU software is available for S14, S50, S54, S65 and S85 using factory ECU. Options for engine installations into different chassis: EWS delete, speed signal delete, DSC delete, Cat monitoring delete, Alpha N mode, VMAX disable, etc. Drive-by-wire (electronically controlled TBs) can be retained when installing engines in different chassis.
For S14 (E30 M3 and 2002tii) specific applications:
Maxx Alpha N V2.0 with Wideband O2 closed loop control & lambda target map: 705 euro
S14 DTM CF Airbox System -- large volume plenum, long runners, 46 or 48 mm diameter (49 & 50 mm also available, see above):
- CF airbox with install kit: 940 euro
- CF snorkel kit: 145 euro
- Brake reservoir relocation kit: 60 euro (not required on race cars with dual master cylinders)
Total CF Airbox kit: 1145 euro (Total minus install kit: 1040 euro)
optional:
CF air filter housing for inside front bumper (for use on non-AC cars or with custom AC radiator): 150 euro
2002 S14 airbox (requires 2002tii brake booster):
- CF airbox with install kit: 1015 euro
- extra large air-hose: 20 euro
CF replica plenum for stock (AFM) installations: 620 euro
Pictures of CF Airboxes / installations:
S14 airbox:
2002/S14 airbox installation:
S14 CF replica plenum (for use with AFM / MAF / or Alpha N):
E46/S54 airbox for use with MAF/HFM or Alpha N (also versions using alternate snorkels and internal or external air filters):
E46/S54 airbox with central air intake from the "kidneys":
E92/S65 CF plenum installation:
E36/S50 airbox for use with MAF/HFM or Alpha N:
E34/S38 airbox installation:
Alpha N kit:
Maxx Alpha N Wideband O2 closed loop control:
Pictures can also be found here: http://s14power.com/airboxes.html
sales@maxx-automotive.com
