Roof Skin - Composite
Enter a group buy or look here for zone discounts
ABSMotorsport
Post Fri Jan 20, 2012 4:34 pm
Ok, we have a new product - E30 Composite Roof skins
link to all options - http://www.absmotorsport.net/bmw/e30.html?p=8
fibreglass - http://www.absmotorsport.net/bmw/e30/bm ... glass.html
RRP prices
Fibreglass - £225.00 + VAT = £270.00
Carbon Composite, White finish - £400.00 + VAT = £480.00
Carbon Composite, Showing Weave - £500.00 + VAT = £600.00
Pure Carbon - £850.00 + VAT = £1020.00
prices are plus Delivery £30.00 + VAT = £36.00 (mainland UK)
If we can get 10 people, the prices will be -
Fibreglass - £150.00 + VAT = £180.00
Carbon Composite, White finish - £290.00 + VAT = £348.00
Carbon Composite, Showing Weave - £390.00 + VAT = £468.00
Pure Carbon - £700.00 + VAT = £840.00
prices are plus Delivery £30.00 + VAT = £36.00 (mainland UK) elsewhere, please ask.
the 10 dont need to be the same type, so if your interested, please put your name, and type below..
Jimbob
Post Fri Jan 20, 2012 7:57 pm
Do you know what the weight differences are between each option? And also what the original steel weight is?
ross_jsy
Post Sat Jan 21, 2012 9:43 am
You wouldn't be able to use these in FIA events would you?
rix313
Post Sat Jan 21, 2012 4:13 pm
Who's racing an E30 at FIA level?
Brian28
Post Sun Jan 22, 2012 7:11 am
PBMW do once a year (most european rounds are FIA scruted). I'm not sure about meeting blue book regs for UK series though. Something like "If the sunroof is removed it must be replaced with similar material of similar thickness". Fantastic idea for a track day car though, and prevents any potential future grot in the roof. Does anybody have a blue book to hand? Would be great if I'm wrong and they could be used for MSA racing as well.
ABSMotorsport
Post Mon Jan 23, 2012 1:32 pm
Jimbob wrote:Do you know what the weight differences are between each option? And also what the original steel weight is?
Fibreglass - 4 kilo
Carbon Composite - 3 kilo
full Carbon - 2 kilo
these are approximate weights, i have only weighed the 1st 2 options.
ABSMotorsport
Post Mon Jan 23, 2012 1:34 pm
ross_jsy wrote:You wouldn't be able to use these in FIA events would you?
I wouldnt of thought that there are any E30's running in FIA Championships now?
I am sure these can be run in most championships, but it would pay to check with each organisers 1st. The E46 have run composite roofs in many championships for several years now..
ABSMotorsport
Post Mon Jan 23, 2012 1:49 pm
Carbon Composite Roof, White Finish - http://www.absmotorsport.net/bmw/e30/bm ... inish.html
Post Mon Jan 23, 2012 2:01 pm
How does this work with rigidity etc? The roof plays a large part in that..
ross_jsy
Post Mon Jan 23, 2012 2:09 pm
rix313 wrote:Who's racing an E30 at FIA level?
Sorry, meant MSA
ABSMotorsport
Post Mon Jan 23, 2012 2:33 pm
Jhonno wrote:How does this work with rigidity etc? The roof plays a large part in that..
obviously these are only for use with cars that have rollcages, which brace the shell.
mccarthy
Post Sat Jan 28, 2012 1:45 am
Finally, someone picked up where performance trim left off... :)
Please stick me down for a fibreglass one
What is the best method of fitting and why is trimming down and bonding in not the preferred method?
Also can it be finished in gloss black?
ABSMotorsport
Post Sat Jan 28, 2012 10:44 am
mccarthy wrote:Finally, someone picked up where performance trim left off... :)
Ok, i will start a list
if you happy with a 'step' edge then trimming down and bonding on top is fine, and a lot less hassle to fit. but if you want the original factory look, full replacement is the only way.
we can make in black at 15% more, and it could be polished.
ABSMotorsport
Post Sat Jan 28, 2012 10:46 am
List started, McCarthy, if you dont want the black option, please edit.
any one else, please copy and paste as you add your name.
thanks
1 - mccarthy - Fibreglass - Black @15% extra
2 -
3 -
4 -
5 -
6 -
7 -
8 -
9 -
10 -
Hoobs
Post Sat Jan 28, 2012 11:33 am
Anyone know how much a steel roof & sunroof weighs please?
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
mccarthy
Post Fri Feb 03, 2012 12:07 am
Bump
mccarthy
Post Sun Feb 12, 2012 11:01 am
im surprised these aren't more popular
are people anti-removing roof for rigidity?
i was going to only remove the roof skin and leave the actual frame and cap it with the fibreglass..... bad idea?
Hoobs
Post Sun Feb 12, 2012 11:49 am
mccarthy wrote: i was going to only remove the roof skin and leave the actual frame and cap it with the fibreglass.
I was considering the same thing myself. I'd planned to cut around the outer edge leaving an inch or so, to bond the fiberglass roof panel to. It just depends on how much weight it'll actually save me?
2002
mccarthy
Post Tue Feb 14, 2012 6:45 pm
Prob not much weight as the roof skin seems pretty flimsy. It's just I ruined the roof getting the sunroof cage out and the skin tends to flap about more than I hoped. It also saves me having to mess about with riveting a sheet over the sunroof hole.
ceige85
Post Sun Jun 03, 2012 5:26 pm
i take it when bonding the roof you ideally want to strip out everything of the old one i.e drill out sport welds etc then bond edges of the grp roof to these points.
Have been planning on getting one of these anyway as my roof has seen better days plus i messed it up when removing the sunroof. Will be handy when putting a cage in too.
Hoobs
Post Mon Jun 04, 2012 12:26 pm
Check what you plan to use the car for first though, as won't be legal for MSA events.
2002
gooseygander110
Post Sun Jul 15, 2012 9:20 am
Hi Guys, does anyone know anyone who has fitted one of these ? Fibre Glass, GRP or Carbon ? Any documented "how to's" or failing that, can any one recommend a body shop in the West Sussex area who is up to the job and reasonable on price ?
regards
Gus
Hoobs
Post Sun Jul 15, 2012 9:50 am
PM'd
2002
Driftben
Post Sun Mar 17, 2013 3:30 pm
is this group buy still active?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
S600sli
Post Mon May 12, 2014 9:34 pm
Im interested , any one else?
