Steering linkages. Update to UJ build page 5
Enter a group buy or look here for zone discounts
Post Tue Oct 06, 2009 12:23 am
Ok ive finally found somewhere that is able to reproduce the fine spline that the power steering racks use.
Plan is to produce a solid steel round bar with fine spline on each end, notched for a pinch bolt to pass through and prevent removal while the bolt is still fitted. These will also be turned down to a nice diameter in between the splined ends.
You will have to obtain a pair of E34 type UJ's and rebuild one half with the column half of your E30 linkage to enable a correct fit onto the column.
I can do this if you supply the UJ's
The first lot will be made for an E36/E46 rack fitted in the rear holes of the cross member as this is what im using, if anybody using an E30 PAS rack is interested all I would need is a measurement
Estimated price is to be in the region of £50 - £60 to your door
I need at least 8 names/deposits before I can talk proper sizes/amounts/costs and get a more accurate price.
Like this but with no welded alloy which can cause possible MOT problems
gareth
Post Tue Oct 06, 2009 12:44 am
hmm, could allow an E36 rack with an M30 maybe?
Post Tue Oct 06, 2009 1:00 am
or e36 rack on an M20!
Post Tue Oct 06, 2009 1:06 am
Simon13 wrote:or e36 rack on an M20!
e36 rack with a 6 branch ? :D
d6dph
Post Tue Oct 06, 2009 11:37 am
Group buy approved, Dan is a trusted zoner so I'm happy for it to go ahead. :)
Post Tue Oct 06, 2009 1:48 pm
Thanks Dave, I did pm Chris but he seems to be in hiding of late :)
d6dph
Post Tue Oct 06, 2009 1:53 pm
It was forwarded to me Dan, So here I am :)
Daf318is
Post Tue Oct 06, 2009 6:18 pm
I'm a name :) !
1. Daf
2.
3.
4.
5.
6.
7.
8.
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
blitz877
AKA ajm-e30
Post Tue Oct 06, 2009 6:21 pm
1. Daf
2. Blitz877
3.
4.
5.
6.
7.
8.
RichIS
Post Wed Oct 07, 2009 3:44 am
1. Daf
2. Blitz877
3.Richis
4.
5.
6.
7.
8.
Injections nice....but I'd rather be blown ;)
hammoj28
Post Wed Oct 07, 2009 9:15 pm
1. Daf
2. Blitz877
3.Richis
4. hammoj28
5.
6.
7.
8.
24v tech2
Bob_S
Post Fri Oct 09, 2009 8:31 pm
joining this band of scummers.. why i'm not sure.
Bollocks to this 24v scrap!
N00b
Post Sat Oct 10, 2009 1:56 pm
Forgive my ignorance, but does this replace the metal/rubber "guibo"? or is this further down the steering assembly?
pikanibbles
Post Sat Oct 10, 2009 4:18 pm
1. Daf
2. Blitz877
3.Richis
4. hammoj28
5. Bob_S
6. Pikanibbles
7.
8.
beardymat
Post Sat Oct 10, 2009 4:34 pm
This looks just what i need to fit my e36 rack with my btb, im in
1. Daf
2. Blitz877
3.Richis
4. hammoj28
5. Bob_S
6. Pikanibbles
7. Beardymat
8.
Daf318is
Post Sat Oct 10, 2009 10:26 pm
N00b wrote:Forgive my ignorance, but does this replace the metal/rubber "guibo"? or is this further down the steering assembly?
Yep does away with it and gives more space :cool:
Post Sun Oct 11, 2009 12:24 am
As Dafs says it replaces the existing linkage, what you are buying is a steel shaft with splines on each end, you will need two E34 type UJ's to connect it to the rack and column.
I will get a drawing done and drop it into the machinists Monday :cool:
essexe30
Post Sun Oct 11, 2009 9:32 am
will using this enable a standard m50 and m52 exhaust manifold to be fitted with no modifications to the manifold
Post Sun Oct 11, 2009 5:44 pm
As you can see in the picture above the rear manifold will just about go on with my welded link and you can still use the standard flange connection, the front one however will need the flange cutting off as it interferes with the steering rack, I just made a sliding joint as you can see in this picture
I suppose you could keep the front flange if you wanted, would just mean a bit of cutting/bending etc
Kedge
Post Sun Oct 11, 2009 7:00 pm
Anyideas whether this would allow the fitment of either the E36/E46/Z3 when using a BTB2 manifold on an M20'd car?
Instagram - Kedge85
Post Sun Oct 11, 2009 7:27 pm
No idea, it would be nice though. If I end up with a spare your welcome to try before you buy :)
mike_sayer
Post Sun Oct 11, 2009 7:52 pm
Sounds great Dan, exactly what I need for my setup, I'm in. Thanks for sorting this!
1. Daf
2. Blitz877
3.Richis
4. hammoj28
5. Bob_S
6. Pikanibbles
7. Beardymat
8. mike_sayer
"And if you are clinically insane, by which I mean you wake up in the morning and think you are an onion, here's your car." - Clarkson
beardymat
Post Mon Oct 12, 2009 7:14 pm
Kedge wrote:Anyideas whether this would allow the fitment of either the E36/E46/Z3 when using a BTB2 manifold on an M20'd car?
im taking the plunge and trying one on mine so i can let you know before you start fannying around, itll be a pain in the arse to fit only to find it wont do the job as that btb covers the steering joint but ill do mine when the engine comes out to make way for the 2.8 at last.
Post Mon Oct 12, 2009 8:06 pm
beardymat wrote: 2.8
:eek:
beardymat
Post Mon Oct 12, 2009 8:34 pm
:eek:
is that in reference to the fact i havnt yet fitted it? lol, you cant rush these things
Nay
Channel Island Crew
Channel Island Crew
Post Mon Oct 12, 2009 11:15 pm
Tempted..
I have a Z3 rack (which I'm assuming is the same), and a spare UJ linkage, but off an E36. Is that different to the E34?
Finally, is this just for that rod, then you split up the spare UJ and attach that to either side of the new rod?
If so, interested so I can remove that rubber bit. Also have a BTB3, but would like added saftey :D
Uni is killing the project.
gcs325i
Post Mon Oct 12, 2009 11:25 pm
1. Daf
2. Blitz877
3. Richis
4. hammoj28
5. Bob_S
6. Pikanibbles
7. Beardymat
8. mike_sayer
9. gcs325i
10.
Post Tue Oct 13, 2009 12:38 am
Similar linkage here with E34 type joints,
Obviously, my linkages wont have any welding :wink:
blitz877
AKA ajm-e30
Post Tue Oct 13, 2009 4:26 pm
DanThe wrote:Similar linkage here with E34 type joints,
so thats what the finished article will look like??
Post Sat Oct 17, 2009 10:07 am
Drawing is in as of Wednesday, waiting on a final price before work starts and a test piece
Finished article will be very similar, slimmer in the centre of the shaft for a start
MarkT
Post Sat Oct 17, 2009 2:24 pm
Looks great, could be very interested when the next group buy comes around!
PS is the 50-60 including the E34 UJ's
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
nickso
Post Sat Oct 17, 2009 6:23 pm
1. Daf
2. Blitz877
3. Richis
4. hammoj28
5. Bob_S
6. Pikanibbles
7. Beardymat
8. mike_sayer
9. gcs325i
10.nickso
ill have one too.
'88 e30 328i M52 track bint.
gareth
Post Sat Oct 17, 2009 8:21 pm
MarkT wrote:PS is the 50-60 including the E34 UJ's
DanThe wrote:You will have to obtain a pair of E34 type UJ's and rebuild one half with the column half of your E30 linkage to enable a correct fit onto the column.
MarkT
Post Sun Oct 18, 2009 5:00 pm
Post Mon Oct 19, 2009 12:18 am
When is that going to be as i would like one to if it will work with my BTB2 and an E36/E46/Z3 rack?
