Steering linkages. Update to UJ build page 5
- Contact:
Got round to fitting one on an E36 rack with an M50, the bolt/nut heads were fouling the manifold so I helicoiled one side and made a grub screw that would tighten down to its shoulder. Also massaged the manifold with some heat and hammer action.
I will look into some neater screws with allen key type heads
Remember, I will mod the UJ's for anyone who has bought a linkage if you pay postage both ways and donate to my Stella fund
Any left Dan?
StefanAnghel
- Contact:
giva a call to quarrymotorsFMH wrote:How much are the e34 uj's?
quarrymot ebay id
£15 each. PP will be £10 on the lot. Please call spares on 0114 275 5916,
stup86
I'll remember this as Iill be buying a linkage off you soon.DanThe wrote:If you have bought a linkage off me and want this doing send me one UJ, the top bit of the E30 linkage and a tenner to cover postage/beer etc
(Just need to get an e34 uj)
Parts needed:
M40/M20 ignition coil with high voltage lead
Do the UJ's wear, or is it a needless expense buying new ones?DanThe wrote:Modded UJ with a low profile clamping bolt
town325i
Only Dezzy is that anal to buy new onesN00b wrote:Do the UJ's wear, or is it a needless expense buying new ones?DanThe wrote:Modded UJ with a low profile clamping bolt
- cruizin4dirty1s
do ya need one or two
StefanAnghel
- Contact:
two (2)
one connects to the rack and one needs modified to fit the e30 coloumn
StefanAnghel
- Contact:
- Contact:
Some nice hammer wounds going on there
There is no need to hammer anything on the linkage, all you need to do is drop the RH rack bolt out, slacken the other and then swing the rack forwards a bit, easy
StefanAnghel
- Contact:
Hammer was used when I remove them from the e34
my problem was the screw that secure the low part of the linkage to the rack
I had to modify it
I had to modify it
StefanAnghel
- Contact:
now I know...what I don't know is how to split the e30 linkage to send it to you? what do i need to cut?DanThe wrote:Just drill the hole out to 10mm, the bolt will then pass the notch in the spline
sorry taken me so long to post pics Dan...
My original dilemma... where to fit 3" of love down there.
and thanks to Dan .... 3" of love fits easily!
*FIXED*
*FIXED*
[/img]
