My e30 m202.8 build
964russ
Post Sun Oct 07, 2018 5:34 pm
Started years ago, when I join "e30zone" .
Finally made progress, thought I'd share.
Bought a 325i se 2 door in dolphin grey, stood for years, rotten.
Welded shell up, new wings & quarters, swoped roof skin.
Cage in, diff rebuilt with lsd.
E46 rack, with custom hydraulic lines.
Ap suspension kit.
Fully polybushed, whole car.
Calipers rebuilt and powder coated, new lines ECT.
List goes on.
Engine is stripped for rebuild into 2.8.
Shtick 288 cam.
6 branch ECT.
Loads done, still loads to do.
964russ
Post Thu Oct 11, 2018 10:25 pm
Give us a clue, how do I post pics?
Gert
Post Fri Oct 12, 2018 12:51 pm
http://www.e30zone.net/modules.php?name ... ost+photos
This is a topic for posting photo's good luck. I'm looking forward for the 2.8 build.
964russ
Post Sun Aug 04, 2019 9:49 pm
964russ
Post Sun Aug 04, 2019 9:50 pm
Ended up being a 2.7
964russ
Post Sun Aug 04, 2019 9:51 pm
Only just got her legal.
Well chuffed!
steve_k
Post Mon Aug 05, 2019 6:57 am
looks good,
whats the full spec (engine,etc)?
Post Mon Aug 05, 2019 7:58 am
Will hopefully see you at Oulton Park sometime, BMW Car Club day in November is one of the best organised track days going, me and a few others will be there :D
964russ
Post Mon Aug 05, 2019 10:52 am
BMW track day sounds good, oulton pk being my local track.
Original m20b25, 2.7 eta crank, 2litre rods, standard pistons.
Schrick 288 cam, big bore throttle body, 6 branch tubular manifold, m3 exhaust.
Everything was lightened and balanced, pistons crank ect.
Not run her in yet, but it sounds broken on tick over, when you rev it lights up like a bike engine!
Feals like a power band on a 2 stroke, great fun 2 drive.
Post Mon Aug 05, 2019 6:22 pm
I noticed the Manchester phone number on the garage sign :D
steve_k
Post Mon Aug 05, 2019 7:50 pm
964russ wrote: ↑
sounds like a good spec,
as for the sound at tickover, mine sounds like a v8 with the schrick cam & X pipe lol but start to open it up & the sound :drool:
964russ
Post Fri Aug 09, 2019 7:12 pm
After 20/30 mile thrust bearing is making a racket.
It's new, so must be faulty! Brilliant!
Luk clutch kit as well.
Anyway, any thoughts on front brake conversion?
Not now, but I'm looking at either the 7series brembos or willwood dinilites.
BMW brembos are cheaper, more messing.
Willwood lighter, bespoke kit no messing.
Any advice?
steve_k
Post Fri Aug 09, 2019 7:29 pm
well i use hi-spec billet 4 calipers, 4 x 41mm pistons, with ds3000 pads, vw g60 282mm discs & braided lines though out.
had this set up for over 10yrs but aint got a clue what price they are now,
Post Sat Aug 10, 2019 8:25 am
I fitted a new LUK release bearing to an S50 conversion last year and that is also now screaming..
When looking at brake kits look at the disc rather than the caliper, I have built a oem style single piston caliper setup that stops better than the 4 pot kit it replaced
reggid
Post Tue Sep 24, 2019 5:51 am
964russ wrote: ↑
decked head?
E30 325is with M20B31
964russ
Post Sun Sep 29, 2019 7:45 am
Yeah.
Removed 1.7mm I think
964russ
Post Mon Dec 02, 2019 11:18 pm
Head gasket is now leaking oil.
Small puddle, 1" or so after a drive.
Proper upsetting ☹, head off now!
Any recommendations for head gasket?
Cant remember wot brand I used last time.
964russ
Post Sat May 30, 2020 9:41 pm
All rebuilt now.
New cam shaft seal sorted oil leak.
Still pulled the head thou to fit uprated valve springs.
Allso fitted mazda front calipers.
964russ
Post Sat May 30, 2020 9:43 pm
Rx7 calipers, vw g60 280mm discs.
Track pads and fluid
shedrool83
Post Sun May 31, 2020 5:27 am
964russ wrote: ↑
All rebuilt now.
What caliper brackets did you use and did you use a 2mm spacer between the hub and the disc?
964russ
Post Sun May 31, 2020 7:11 am
I had the brackets made.
Downloaded the diagram gave to my engineer pal, made them out of alloy.
Pretty much a straight bar, allmost.
No 2mm spacer behind disc, had the centre bore opened up a smidge.
7mm spacer to allow wheel to spin.
Easy
shedrool83
Post Sun May 31, 2020 7:26 am
Easy
[/quote]
Is this the one you used ?
964russ wrote: ↑
964russ
Post Sun May 31, 2020 9:38 am
Yes.
That's the 1.
I run a flap disc over the caliper face to remove the mazda logo.
Bit of blue enamel paint, look spot on.
Have you got the mazda calipers?
I've got a spare pair sumwhere.
shedrool83
Post Sun May 31, 2020 1:19 pm
964russ wrote: ↑
Yes.
That's the 1.
Getting the same one made too. I have a bracket that is just straight without the recessed bit but it meant a few washers here and there and is a pain.Also have the mazda ground off painted them red and added a brembo decal. I need to get stud conversion as putting the wheel on and off is a mare with bolts.
964russ
Post Sun May 31, 2020 2:03 pm
Studs are loads easier, especially with a spacer ect.
How your find em?
Cant be any worse than standard, allmost dangerous with standard calipers.
rix313
Post Sun May 31, 2020 2:21 pm
shedrool83 wrote: ↑
The 2mm spacer was required for the Wilwoods kit I have. The disc didn't sit in the middle of the caliper without it. I had some replacement brackets drawn up for my Wilwoods but the prices I got back to manufacture them made it a bit daft to spend the money on them. The standard ones are 'alright' but one day I'll swap them.
964russ wrote: ↑
To be fair to standard callipers, the Production BMW lot race using them.
These brakes look really good though :D
shedrool83
Post Sun May 31, 2020 2:47 pm
964russ wrote: ↑
How your find em?
I haven't driven it yet . I have had standard 325i calipers on all my other e30's including a m52b28 and m30b35 and found they were fine ,i am sure these will be better than oem .
964russ
Post Sun May 31, 2020 9:44 pm
I found the standard brakes to be poor.
Mayb it was the pad choice?
I rebuilt them as well, new everything.
Had to use a lot of force to slow car down.
My car is a lot quicker than standard, dunno.
Had no confidence in the standard brakes, and you need to trust your brakes.
Not had chance to use the new set up yet, had lots to do.
964russ
Post Sun May 31, 2020 9:47 pm
Rix313 have you got a drawing for your adapters you want making.
I can pass it on to my mate, get a price for you.
Hes done loads for me, all on track.cars, all had plenty of abuse.
rix313
Post Sun May 31, 2020 11:11 pm
964russ wrote: ↑
Ah that would be great thanks. Yes I have the drawing and the .Dxf files for them somewhere.
964russ
Post Wed Jul 01, 2020 3:15 pm
Old wheels
964russ
Post Sat Nov 28, 2020 6:15 pm
Done a few bits more
964russ
Post Sat Nov 28, 2020 6:16 pm
Need to sort fuel gauge.
Still not working?
Any ideas on how to adjust variable cam ?
rix313
Post Sun Nov 29, 2020 8:50 am
I've never had anything but problems with my fuel level sensors in all of my cars. Out of interest have you ever run it without that duck tail? It will be creating quite a bit of drag I'd have thought?
You get out much in this car? Should give us a shout if you ever come to Silverstone.
964russ
Post Fri Dec 04, 2020 5:24 pm
Owned car for 5 years.
Probably done 50mile, ha ha!
Been a very drawn out build!
Got it running loads better, adjusted cam, adjusted co.
Sounds very angry.
Snowing at the moment, so no test drive.
