This will be a rally car build.
So the shell is a 1988, 2 door, non sunroof model which I am told had an M10 engine originally.
Upon first inspection the rear arches are in brilliant condition to my amazement !
The scuttle area, roof, engine bay, and boot is perfect. The only spots of bother are the osf wing (easy, replace it !), and the outer areas of the front footwells. The usual rear towing eye area has been repaired badly at some point and will need a tidy up.
So, the shopping list initially is;
M42 Engine/loom/ecu (already sourced)
318is Gearbox (already sourced)
318is Radiator/hoses (already sourced)
Heater motor
51mm front struts/hubs/calipers (already sourced)
Disc rear axle (already sourced)
325 roll bars
LSD
4.4 ratio crown/pinion (already sourced)
318is Propshaft (already sourced)
325 Driveshafts
Smiley Headlights
OS wing
Tech 2 steering wheel - the mole grips arent f.i.a approved
Seats
