Turbo m20 talk.
DanTheMannn
Post Tue Jan 20, 2015 3:53 pm
I'm just trying to get my head screwed on before i begin this project.
2 major questions that are stopping me from sleeping at night. I've gone through the wiki and done a search but can't seem to find answers.. i've also asked our good friend google.
1) I have a 1986 high compression engine, is this ok to turbo or do i need to somehow lower compression?
2) Megasquirt, do they do a plug and play for this model? i can only find from 1987 onwards?
Thanksss much loveeee <3
age
Formerly twist316
Post Tue Jan 20, 2015 4:52 pm
1. depends on your power goals
2. its better to convert to later management anyway
M40 rightness if you can get to 6000rpm noone can hear your tappets
DanTheMannn
Post Tue Jan 20, 2015 5:16 pm
around 300 id like.
later management?
German-Whips
Post Tue Jan 20, 2015 5:37 pm
Early High Compression engines used the earlier management systems, which aren't as effective as the later management system.
The later management system is the Motronic 1.3
My engine is also the earlier pre 1987 high compression engine, but I have the later Motronic 1.3 management on mine, which is better.
Once converted to Motronic 1.3, you may be able to plug and play the Megasquirt
German-Whips
Post Tue Jan 20, 2015 5:38 pm
http://www.e30zone.net/e30zonewiki/inde ... Management
The above link contains some good information about management systems.
ross_jsy
Post Tue Jan 20, 2015 5:43 pm
The megaspuirt plug and play kit is for Motronic 1.3 which has several differences to Motronic 1.1. If your car is using 1.1, it would make sense to upgrade to 1.3.
I would also stick in a low comp engine at the same time or build a proper low compression lump. Not sure how well m20's stand up to 300hp without uprating pistons, rods and head bolts. Ross2009 is the guy to speak to for turbo m20's
DanTheMannn
Post Tue Jan 20, 2015 5:53 pm
i would have to change the loom if i upgraded to the 1.3 ecu wouldn't i?
ross_jsy
Post Tue Jan 20, 2015 7:07 pm
