Can I turbo an e30 1.6L!!
kbm
Post Sat Aug 09, 2014 12:48 pm
I'm looking to buy an e30 and I'm wondering whether I can turbo it easily or not. As it will be only 100 HP and I want more?? Help!
Nobby_N
Post Sat Aug 09, 2014 1:32 pm
Yes u can but why would you as it still be slow!
kbm
Post Sat Aug 09, 2014 1:33 pm
Well I'm not looking for it to be stupidly fast. But maybe 140hp or so?
ross2009
Post Sat Aug 09, 2014 11:11 pm
if you want it faster put a bigger engine in it would be easier and cheaper
Turbo M20
v8 project 6.0 twin turbo
Kos
Post Sun Aug 10, 2014 1:19 am
Just put an m20 m30 or m50/2 into it
Post Thu Aug 28, 2014 10:04 am
My brother got 318hp and 413nm out of his M40B16, but he runs 2.5 bar of boost.
Kos
Post Thu Aug 28, 2014 10:20 am
23732 wrote:My brother got 318hp and 413nm out of his M40B16, but he runs 2.5 bar of boost.
Must have a bit or lag lol
ross_jsy
Post Thu Aug 28, 2014 10:23 am
Bet that's got nice power delivery/reliability
Acaciastrain360
Post Mon Jan 12, 2015 7:47 pm
The point in this thread was to get information on HOW TO TURBO IT, not... Put a different engine in it jeeeeeeeze
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Post Mon Jan 12, 2015 8:04 pm
Buy this - http://www.ebay.co.uk/itm/Design-Test-I ... 5d53d2432d
It will be money well spent
ross_jsy
Post Mon Jan 12, 2015 8:09 pm
Great book and well worth a read.
You aren't going to get a walkthrough on how to do it as there's many ways to skin a cat
Acaciastrain360
Post Thu Jan 15, 2015 1:07 pm
No need to lower compression though is there? So no head gasket or arp to do?
Mikey_Boy
Post Thu Jan 15, 2015 2:09 pm
I've got an M40B16 from a facelift with just 100k miles on it if anyone fancies turboing that?? PM me for details!! :thumb:
Anything is possible - 150hp per litre should be easy enough, which equates to 240hp or thereabouts - should be fun!
Acaciastrain360
Post Thu Jan 15, 2015 8:01 pm
What about gearbox's? Will an m20 one fit? Will the 1600 box just blow?
Topblag
Post Thu Jan 15, 2015 8:04 pm
I'd suggest you'd be better off sticking a turbo on an M10 instead of an M40.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Acaciastrain360
Post Thu Jan 15, 2015 8:15 pm
Why? I've got an m40 though... Makes sense for me!
jmc330i
Post Thu Jan 15, 2015 8:23 pm
Acaciastrain360 wrote:What about gearbox's? Will an m20 one fit? Will the 1600 box just blow?
An M20 gearbox won't fit easily and really not worth the hassle.
The M40 gearbox will cope with an M52 and an M40 turbo won't make M52 power.
There was an M40B18 turbo on here a few years ago making 170bhp on standard compression (8.8:1).
I think the M40B16 has a slightly higher compression ratio of 9:1 so coupled with 200cc less, I reckon you'd struggle to get 160bhp.
To me it all seems a bit pointless on a B16. If you must stay with the M40, at least turbo a B18.
James
'91 325i Sport
'93 318i touring 16v
Acaciastrain360
Post Thu Jan 15, 2015 8:38 pm
Fair enough, yeah you're right but it's not about loads of power, it's just about having a turbo b16 man... Just gonna put a t28 on it from a 200sx
ross_jsy
Post Thu Jan 15, 2015 8:50 pm
Just go for an m10. They love boost, m40's less so. It doesn't matter if you have the engine or not, you are going to have to buy a lot so add an engine to that list. It's not like m10's are pricey
Acaciastrain360
Post Thu Jan 15, 2015 9:31 pm
So a m10b? And what engine management?
ross_jsy
Post Thu Jan 15, 2015 10:45 pm
That i up to you, my advice is start researching.
I am leaning towards VEMS for my m50, but a basic Megasquirt will be fine for an m10. Decent rods, pistons, stock head gasket and ARP's should make for a cracking boosted build.
Acaciastrain360
Post Fri Jan 16, 2015 7:15 am
Okay dude, sounds like a plan.... So does anyone want to buy a m40b16? Haha
Acaciastrain360
Post Fri Jan 16, 2015 7:18 am
Oh yeah, do I have to change the loom to fit in my facelift?
Mikey_Boy
Post Fri Jan 16, 2015 8:46 am
I wouldn't be so fast to ditch your existing engine - this needs more research before a decision is made. Looking at the fundamentals:
4 cylinder engine with loads of room around it for a decent exhaust manifold and decent sized turbo.
Loads of space at the front of the engine bay for a large intercooler, which is absolutely key for decent boost figures.
The fact the Compression ratio is a bit higher is not so relevant - if you have a decent 'open' ECU like megasquirt, OMEX or Emerald, you will be able to control everything well enough - compression ratios were low back in the day because engine control was rubbish. Off the shelf ECUs these days are superb.
Also, remember that Cylinder PRESSURES (and/or temperature) destroys turbo engines, NOT BOOST. I learnt this lesson developing Sierra and Escort Cosworths and other boosted engines when I worked as an engineer at Cosworth back in the day. SPARK has a far greater effect on cylinder pressure compared to boost, so as long as your spark numbers are right, you can boost, boost and boost some more... :thumb:
8 valve heads tend to better for boosting compared to 16v heads - for ultimate power, you need 16v, but for a nice torquey engine that makes decent power, 8v is great. Also, as there are less valves, there's usually larger waterways in the head keeping things cool meaning you can boost more.
Lots to think about - buy a book or read articles online as there's loads.
Most of all, have fun with it and don't follow a conventional route if you don't want to!
Supercharged 1.6 anyone?? winkeye
ross_jsy
Post Fri Jan 16, 2015 9:37 am
Mikey, m10's are 4 cylinders and are a stronger block.
This is a monster of an m10 build, well worth a read through. Overkill for your needs but there is some brilliant engineering within.
http://www.e30tech.com/forum/showthread.php?t=70595
As for loom. You could either adapt the existing loom to work with the engine management or use a generic loom from the supplier of the management. For example:
https://shop.vems.hu/catalog/v3twinshie ... 9d13c5d7dc
Mikey_Boy
Post Fri Jan 16, 2015 9:46 am
Smashing - always keen to learn something new...! :thumb:
Acaciastrain360
Post Fri Jan 16, 2015 4:35 pm
I'm gonna keep the m40 i think as I'm not after amazing power, just a bit of pokie and just a laugh. Thanks for the information Mr mikey... I do like a ford as you can see in my signature lol
What exhaust manifold can I use to convert to turbo, which will fit an m40. E36 318ti? It's mild I think...
ross_jsy
Post Sun Jan 18, 2015 9:18 pm
Acaciastrain360 wrote:What exhaust manifold can I use to convert to turbo, which will fit an m40. E36 318ti? It's mild I think...
A custom one most likely
jmc330i
Post Sun Jan 18, 2015 9:52 pm
The 16v M42/M44 manifolds have a different stud pattern so won't fit the M40. Will most likely need to be custom.
James
'91 325i Sport
