Just fitted turbo to 2.5 have a few questions.
bmwonly
Unapproved Trader caution
Post Sun Jan 08, 2012 6:09 pm
Hi, Just completed the fitting of the turbo and megas squirt. I have had it all mapped and runs really sweet. All i have done so far is fitted the turbo and ancillaries, fitted ms2 extra and got it running. I have done nothing to the engine yet. I have ran it round for the weekend at 5 psi sweet but ive done the clutch. I'm looking to run around 300 horses. So my questions,
1. Whats the best clutch for 300bhp? Bear in mind its got a welded diff so i'm sideways a lot, and it a daily drive.
2.I have arp studs on order. How do i find out the compression ratio of my engine to work out if i need 3mm headgasket??
3. What injectors do i need to run?
Any to anyone thing of doing the conversion, do it! Ive spent about £1500 to date. The sound and feel of driving a car that generally isnt turbo'd is ace.
Just so everyone knows i'm not a trader in anyway.
Killer of e30's - yes!
Trader - No!
HairyScreech
Post Sun Jan 08, 2012 6:36 pm
what year 2.5 is it?
how have you had it mapped running standard injectors?
ross2009
Post Sun Jan 08, 2012 6:47 pm
bmwonly wrote:Hi, Just completed the fitting of the turbo and megas squirt. I have had it all mapped and runs really sweet. All i have done so far is fitted the turbo and ancillaries, fitted ms2 extra and got it running. I have done nothing to the engine yet. I have ran it round for the weekend at 5 psi sweet but ive done the clutch. I'm looking to run around 300 horses. So my questions,
mate your bit behind on the turbo scene lol ive got a 6 puc paddle clutch in mine but mines not a daily driver just a weekend and summer car
as for injectors you need at least 32lbs for 300 bhp
you wont need a 3mm head gasket a stock late engine will take a bar of boost on standard internals with your arp head studs a stoc bottom end will hold over 400 bhp for sure witht the right tune
but like screech said how did you get it mapped with stock injectors surely the duty cycle will bog out
Turbo M20
v8 project 6.0 twin turbo
bmwonly
Post Sun Jan 08, 2012 7:07 pm
Its a Greg so 89/90.
So clutch wise im looking for something better than standard but i dont need to go as far as a 6 puck race clutch.
No there is no bog at 5psi, we had it up to 7psi with no probs. Theres still some more there the fueling is spot on. I havent even touch the spark tables yet. its running 15 -20 degrees across the board.
Trader - No!
bmwonly
Post Sun Jan 08, 2012 7:08 pm
Will definitely need bigger injectors when i start getting the horses up. What do the 32lbs come out of??
Trader - No!
ross2009
in that case you compression is 8.8 :1
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:10 pm
Just had a look its only running 200bhp at the wheels, so around 240 at the fly.
Trader - No!
bmwonly
Post Sun Jan 08, 2012 7:11 pm
Sound, so if i have this correct i do not need to change the compression?? Would you recommend a different gasket from stock or just replace with stock bmw gasket when i do the studs?
Trader - No!
ross2009
http://www.ebay.co.uk/itm/4-X-BOSCH-INJ ... 2a17ea73e4
these but obviously u need 6
stock head gasket is fine if its done a few miles then might be an idea to change it with ya studs
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:14 pm
wow at £10 they gotta worth a punt.
Trader - No!
ross2009
Post Sun Jan 08, 2012 7:15 pm
ive got 42lbs in mine lime greens
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:16 pm
Yer i'll deffo change the head gasket, i'd rather do it now before it goes and causes me more probs. plus doing it sooner rather than later means is just a straight gasket swap, i'll have that done in a few hours. Can sort my leaky oil return at the same time winkeye
Trader - No!
bmwonly
Post Sun Jan 08, 2012 7:18 pm
what lbs are the ons on ebay?
Trader - No!
ross2009
Post Sun Jan 08, 2012 7:19 pm
always a plus you can get uprated clutch covers for the standard friction plate but for the amount they cost it would be cheaper to get some thing like mine i only paid i think it was 250 quid shipped for my clutch from the states
Turbo M20
ross2009
there 30- 32 lbs
thats 350 cc
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:34 pm
£250 not too bad. Ideally though i'd like to get it on before thursday so i can get it back on the dyno.
Trader - No!
ross2009
Post Sun Jan 08, 2012 7:35 pm
youll have to pay quite abit more than that if your to get one over here
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:47 pm
where did you get yours from??
Trader - No!
ross2009
from the usa lol told ya that lol
Turbo M20
bmwonly
Post Sun Jan 08, 2012 7:59 pm
ok i'll rephrase it, which website?? Gonna see how long delivery is?
Trader - No!
ross2009
Post Sun Jan 08, 2012 8:03 pm
Turbo M20
fowler
Boost Junkie
Post Sun Jan 08, 2012 8:49 pm
200 bhp on stock injectors they must of been proper maxed out that sounds like that was running a tad lean.
STD injectors run out of puff on a 180 NA M20 B25 and practically useless on a Na 2.7 runout of grunt, so suspect 200 ponies is not quite there yet... 42 lbs state sis the best TBH but take a few days to come like ross said.
EX A-Tech Workshop bitch !!!
gone but not forgotten
bmwonly
Post Sun Jan 08, 2012 9:27 pm
Nice one. just droped them an email to get some prices and lead times.
Trader - No!
ross2009
Post Sun Jan 08, 2012 10:05 pm
cool there pretty good i think i got mine within 2 weeks i think
Turbo M20
bmwonly
Post Mon Jan 09, 2012 5:47 pm
I'm telling ya the fueling is fine. we took it up to 7 psi and ran 270 and the fueling was fine. In fact there was even some left over to pop a few flames. :D
How your gear box holding up with the 6 puch??
Trader - No!
bmwonly
Post Mon Jan 09, 2012 7:35 pm
well after a day of checking out different set ups ive gone for this bad boy:
http://www.ebay.com/itm/F1-RACING-COMPL ... 255c20c67d
As the clutch has gone and i cant drive the thing :x ive decided to take the head off. Gonna run the head down to cylinder head developments down the road and get the to check the valves and guides. while its there i'm gonna get the exhaust side opened up.
So next question is if im getting standard head gasket is there anything i should look out for or anywhere i should go?
Trader - No!
ross2009
Post Mon Jan 09, 2012 7:56 pm
Already knocked the bearings out but it makes loads of noise but it won't brake
Same clutch as mine
Turbo M20
b12rlw
Post Tue Jan 10, 2012 4:15 pm
Hi, I bought a clutchmasters 6 paddle, took about a fortnight to come. I used CTS Turbo in california for my injectors (440's) and my walbro pump. (contact was a guy called nik -(nik@ctsturbo.com). I've gone for a standard gasket from eurocarparts (reasonable quality one). Ross, have you used the knock link for the squirt? @bmwonly - what size exhaust are you running?
ross2009
Post Tue Jan 10, 2012 4:28 pm
b12rlw wrote: Ross, have you used the knock link for the squirt?
Knock link mate??
Turbo M20
b12rlw
Post Tue Jan 10, 2012 7:15 pm
The knock sensor convertor for spark retard? Are you running knock sensors?
ross2009
Post Tue Jan 10, 2012 7:17 pm
o no mate aint had it put on i think i will this year tho as im going forged bottom end this year
Turbo M20
b12rlw
Post Tue Jan 10, 2012 7:23 pm
It's a guy from Canada at viatrack.ca who does a neat little box for signal conversion. Was wondering where to mount 2off sensors. On my high comp block i'd welded two studs to the side of the block but trying to avoid this time round. Think his name's Boris mohair or something.
ross2009
Post Tue Jan 10, 2012 7:24 pm
my guy makes the boxes mate and i can get them cheap :)
Turbo M20
b12rlw
Post Tue Jan 10, 2012 7:25 pm
bonus ;-)
ross2009
Post Tue Jan 10, 2012 7:26 pm
:wink:
Turbo M20
